CME - direct incoming call from PSTN
May 24th, 2010
Hi Guys,
Is there any way to direct specific incoming call from PSTN to a specific dial-peer range number on CME using COR? - 3 CMEs, only 1 cme connected to PSTN.
for example, public phone number 7771234 that originate from PSTN only allow to ring dial-peer range 7771000-7771005 on CME-A then public phone number 7771235, only allow to ring dial-peer range 7771006-7771010 on CME-C.
please advice
Thanks in advance
Paolo Bevilacqua Mon, 05/24/2010 - 02:02
  • Hall of Fame,
    Founding Member
Do you need to direct on the basis of phone line, or calling number ?
vip80y_cisco Mon, 05/24/2010 - 03:43
Hi, thanks for your reply...
I need to direct on the basis of calling number
thanks,
terrence
vip80y_cisco Mon, 05/24/2010 - 04:06
Thanks for the links.
Do you have any documentation with COR?
Restrict outgoing call seems to be easier than incoming...
Terrence
Paolo Bevilacqua Mon, 05/24/2010 - 04:22
  • Hall of Fame,
    Founding Member
I would use number transaltion in your case actually.
