IE3000 with 100LX SFP to IEM-3000-8FM on SMF
May 24th, 2010
I'm trying to spec out some switches in our industrial environment. I only have single mode fibre to deal with. I'm curious if a IEM-3000-8FM module will connect to a 100LX SFP using a single mode fibre. I know the IEM-3000-8FM module is 100FX for multi-mode fibre. I know they both use 1310nm wave length but i'm not sure if they will work togther? Any help would be aweome.
Cheers,
Phil Thomson
heiko.bialozyt@... Mon, 06/18/2012 - 06:41
I've seen that you dont got an answer. Maybe you found them by your self.
Now i'm on the same situation. and so i ask again: It's possible to use IEM-3000-8FM on SMF or not?
Thanks for any info
Heiko Bialozyt
Related Content
