05-24-2010 02:02 AM - edited 03-21-2019 02:36 AM
Hi all.
We have a UC520 with the optional T1\E1 card installed and an ISDN30 line attached. I have tried setting up the caller ID via CCA and CLI but I cannot get it to work. We have 20 DDI's available with 11 in use at the moment. The only number that appears on outgoing calls is the Caller ID Main PSTN number entered into CCA. I have tested the translation rules and they are working. I need to get this working so the telecom's company can bill the client based on DDI. Any help on this would be much appreciated. Here are the current translation rules:
voice translation-rule 4
rule 1 /433540/ /201/
voice translation-rule 5
rule 1 /433547/ /551/
voice translation-rule 6
rule 1 /433541/ /701/
voice translation-rule 7
rule 1 /433545/ /400/
voice translation-rule 8
rule 1 /433548/ /751/
voice translation-rule 9
rule 1 /^25\([1-7]\)$/ /433542/
rule 2 /^30\([1-2]\)$/ /433543/
rule 3 /351/ /01333433544/
rule 4 /^40\([1-2]\)$/ /433545/
rule 5 /451/ /433546/
rule 6 /551/ /433547/
rule 7 /701/ /433541/
rule 8 /751/ /433548/
rule 15 /.*/ /433540/
voice translation-rule 10
rule 3 /351/ /433544/
rule 9 /^80\([1-2]\)$/ /433549/
rule 10 /851/ /433550/
voice translation-rule 11
rule 1 /433544/ /351/
voice translation-rule 12
rule 1 /433549/ /801/
voice translation-rule 13
rule 1 /433546/ /451/
voice translation-rule 14
rule 1 /433550/ /851/
voice translation-rule 15
rule 1 /433543/ /300/
voice translation-rule 16
rule 1 /433542/ /250/
voice translation-rule 17
rule 1 /433551/ /501/
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^909[01]......../ //
rule 2 /^9090[89]......./ //
rule 3 /^9098\(.*\)/ //
voice translation-profile CALLER_ID_TRANSLATION-PROFILE
translate called 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_BRI
translate calling 9
voice translation-profile PROFILE_ALL_T1E1
translate calling 10
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
Solved! Go to Solution.
05-24-2010 07:00 AM
You can only have one outgoing translation profile configured per dial peer. What you could do is modify the OUTGOING_TRANSLATION_PROFILE translation profile as follows:
This would keep your existing translation for the called number and add a translation for the calling number (caller ID).
Hope this helps.
Brandon
05-24-2010 06:08 AM
It's not shown in your config, but I assume you have your tranlation profile applied to your dial peers? You might also check with the telco. It's possible that they are overwriting the caller ID that you're sending out with the billing telephone number.
Hope this helps.
Brandon
05-24-2010 06:54 AM
Hi Brandon
Thanks for your reply. I had a look at the dial peers (see below for a few examples). Do I have to add translation-profile outgoing CALLER_ID_TRANSLATION-PROFILE to each of the dial peers in the ALL_T1E1 trunk group?
dial-peer voice 80 pots
trunkgroup ALL_T1E1
corlist outgoing call-national
description **CCA*UK*National Geographic - 11 digits**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 90[123].........
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-toll-free
description **CCA*UK*International Toll Free**
preference 3
destination-pattern 900800T
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_T1E1
description **CCA*UK*Operator**
preference 3
destination-pattern 9100
forward-digits all
no sip-register
05-24-2010 07:00 AM
Hope this helps.
Brandon
05-24-2010 07:13 AM
Thanks Brandon. That makes sense. i'll give it a go later.
05-24-2010 08:01 AM
Thanks Brandon. that done the job!.
05-24-2010 06:10 AM
If you are using CCA, I wanted to ask you if you can try CCA Configuration Drawer, then Telephony-> DialPlan --> Outgoing. There is a 'tab' for associating CLIDs with individual extensions, which are assigned DIDs. That may work, or at least the configuration it pushes can be used to examine the running config to see what it builds.
Steve
