Server Load Balancing
May 24th, 2010
hi,
I would like to know that how can i load balance traffic across multiple servers in a round robin fashion on MAC base.
I mean that incoming user traffic will get the reply from 1st server MAC ,  2nd request will get the responce from 2nd server
MAC and so on.
If any 1 know about this perticular issue then kindly let me know.
Ali Jaffery
Ganesh Hariharan Mon, 05/24/2010 - 04:36
hi,
MAC and so on.
Ali Jaffery
Ali Jaffery,
Server load balancing in cisco switches for server traffic or separate hardware for load balancing, If cisco ios based load balancing check out the below link:-
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a0080093de3.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Jaffery.28 Mon, 05/24/2010 - 04:47
  thnx for your help and giving me the link, but that will not according to my scenerio, it's giving me the config and concept of L3 base
  load balancing. I want to do the same thing on MAC address base , that 1st request will entertain by 1st server MAC address and
  2nd request will entertain via 2nd server MAC address and so on .... in a round robin way
  Network diagram will exactly the same as shown in this link but wana don that load balancing on L2 base.
  Ali Jaffery.
Ganesh Hariharan Mon, 05/24/2010 - 04:58
  Ali Jaffery.
Ali Jaffery,
Check out the below link
https://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/iosslb5t.html
Hope to Help !!
Ganesh.H
Jaffery.28 Mon, 05/24/2010 - 05:22
  1ce again this is for (IP) base scenerio not for (MAC) base load balancing ,  oki do any 1 have any idea about any L2 redudancy protocol
  for L2 switches , any example configuratation that can be done on Layer 2 switch ???
  Ali Jaffery.
