Warning message
Cisco 4507 as NTP server
Ganesh Hariharan Mon, 05/24/2010 - 04:30
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
      How do i configure a Cisco 4507 switch as NTP Server in my network ?
regards
Neo
Hi Neo,
If you want to make 4507 as NTP server for your network just make the local time up to date and configure as ntp master 3 and for ntp client just make this switch ip reachble and configure in client end ntp server switch ip address.
Hope to Help !!
Ganesh.H
Remember to rate the helpfulpost
Hi ,
        Please let me know how do i verify that NTP is synching ? when i do a sh clock on client switch it is showing me a local time of the switch but when i do sh ntp status or sh ntp association  over there it is showing that NTP is synched ? please help
On server i did
ntp master 3
ntp boradcastdelay 3
on client i did
ntp server
regards
Neo
Senthil Rajendra Fri, 05/28/2010 - 01:44
Dear Neo,
If you are giving sh ntp status, You can get the details of NTP Server IP and Time what you configured in Server..Then what is the problem?
Clock is synchronized, stratum 3, reference is x.x.x.x(NTP Server IP Address)
nominal freq is 250.0000 Hz, actual freq is 249.2265 Hz, precision is 2**24
reference time is CFAA0016.C3958320 (14:10:54.764 IST Fri May 28 2010)
clock offset is 13.4430 msec, root delay is 20.48 msec
root dispersion is 19.18 msec, peer dispersion is 0.67 msec
Tks&Rgds
Senthil
Ganesh Hariharan Fri, 05/28/2010 - 05:46
Hi ,
On server i did
ntp master 3
on client i did
ntp server
regards
Neo
Hi Neo,
show ntp associations  is the command with which you can determine if NTP is working and communicating properly,check out the below link for more information
http://www.ciscoonline.info/en/US/products/sw/iosswrel/ps1818/products_tech_note09186a008015bb3a.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
