ACS 1113 Access to Command Line
May 24th, 2010
I have a 1113 ACS but I can't remember what type of adapter/cable combo I need to get to the command prompt.  I tried the previous solution (standard serial to RJ45 Cisco cable-Terminal adapter) but it didn't work.  I have the RJ45 to RJ45 Cisco Roll over cable that came with the ACS but I thought that you had to use one terminal (DTE) adapter and one null modem (DCE) adapter to get the login prompt.  The problem is I have no null modem adapters!!!
Overall Rating: 5 (1 ratings)
Chetan Kumar Ress Mon, 05/24/2010 - 07:58
Dear Jason
To configure the ACS 1113 you can use Console Cable.
And Open the ACS 1113 server with Hyper Terminal  using below setting:
Baud = 115200
Databits = 8
Parity = N
Stops = 1
Flow control = None
Terminal emulation type = ANSI
and for more detail please find the below link.
https://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/solution_engine/instalap.html
