VPN Client not working
Answered Question
May 24th, 2010
Hi all,
can anyone help me in troubleshooting vpn client that have the following configuration:
CLI(config)# ip local pool vpnpool 172.16.1.100-172.16.1.199 mask 255.255.255.0
CLI(config)#username marty password 12345678
CLI(config)#isakmp policy 1 authentication pre-share
CLI(config)#isakmp policy 1 encryption 3des
CLI(config)#isakmp policy 1 hash sha
CLI(config)#isakmp policy 1 group 2
CLI(config)#isakmp policy 1 lifetime 43200
CLI(config)#isakmp enable outside
CLI(config)#crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
CLI(config)#crypto dynamic-map outside_dyn_map 10 set transform-set ESP-3DES-SHA
CLI(config)#crypto dynamic-map Outside_dyn_map 10 set reverse-route
CLI(config)#crypto dynamic-map outside_dyn_map 10 set security-association lifetime seconds 288000
CLI(config)#crypto map Outside_map 10 ipsec-isakmp dynamic Outside_dyn_map
CLI(config)#crypto map outside_map interface outside
CLI(config)#crypto isakmp nat-traversal
CLI(config)#group-policy groupvpn internal
CLI(config)#group-policy groupvpn attributes
CLI(config)#(config-group-policy)#vpn-tunnel-protocol IPSec
CLI(config)#tunnel-group groupvpn type ipsec-ra
CLI(config)#tunnel-group groupvpn ipsec-attributes
CLI(config-tunnel-ipsec)#pre-shared-key key
CLI(config)#tunnel-group groupvpn general-attributes
CLI(config-tunnel-general)#authentication-server-group LOCAL
CLI(config-tunnel-ipsec)# default-group-policy Solidarityvpn
CLI(config-tunnel-general)#address-pool vpnpool
when try to connect using the vpn client it request the authentication and when authenticating it negotiate policies secure the channel but it give me not connected.
can anyone help in this.
THanks in advance,
Ayman
Correct Answer by Federico Coto F... about 7 years 1 month ago
Some comments:
I assume that you changed the outside IP 1.1.1.1?
This unit is configured as a secondary failover unit?
Anyway, I think the problem is this:
Change this line:
To this one:
crypto dynamic-map Outside_dyn_map 10 set transform-set ESP-3DES-SHA
Federico.
According to the logs you're getting authenticated as a VPN user, but then the IPsec SA negotiation fails.
Can you post the current ''sh run'' from the ASA?
Federico.
Correct Answer by Jennifer Halim about 7 years 2 months ago
Doesn't seem that you even attempted to connect from the logs.
I gather your VPN Client is not connected hence nothing on the show outputs.
Can you enable logging on the VPN Client, then try to connect and share the logs on the VPN Client.
Have you changed the crypto map as advised earlier?
Please share the following show output after the changes:
show crypto isa sa
show crypto ipsec sa
Overall Rating: 5 (5 ratings)
Jennifer Halim Mon, 05/24/2010 - 05:24
  • Cisco Employee,
Seems like maybe a typo on the upper case:
Try to remove "crypto  map outside_map interface outside" and changed it with "crypto  map Outside_map interface outside"
If it still doesn't work, turn on "debug cry ipsec" and try to connect again. Please share the debug output. Thanks.
ayman emara Mon, 05/24/2010 - 06:11
how can i get you the debug ??
as i opened it but i do not know how to get the output.
Ayman
ayman emara Mon, 05/24/2010 - 07:06
Hi Halijenn,
i think i got this output
FW# sh isakmp
There are no isakmp sas
Global IKE Statistics
Active Tunnels: 0
Previous Tunnels: 19
In Octets: 48833
In Packets: 138
In Drop Packets: 21
In Notifys: 1
In P2 Exchanges: 19
In P2 Exchange Invalids: 0
In P2 Exchange Rejects: 19
In P2 Sa Delete Requests: 0
Out Octets: 41040
Out Packets: 142
Out Drop Packets: 0
Out Notifys: 76
Out P2 Exchanges: 0
Out P2 Exchange Invalids: 0
Out P2 Exchange Rejects: 0
Out P2 Sa Delete Requests: 0
Initiator Tunnels: 0
Initiator Fails: 0
Responder Fails: 0
System Capacity Fails: 0
Auth Fails: 0
Decrypt Fails: 0
Hash Valid Fails: 0
No Sa Fails: 0
Global IPSec over TCP Statistics
Embryonic connections: 0
Active connections: 0
Previous connections: 0
Inbound packets: 0
Inbound dropped packets: 0
Outbound packets: 0
Outbound dropped packets: 0
RST packets: 0
Recevied ACK heart-beat packets: 0
Bad headers: 0
Bad trailers: 0
Timer failures: 0
Checksum errors: 0
Internal errors: 0
Thanks in advance
Ayman
Correct Answer
Jennifer Halim Wed, 05/26/2010 - 03:47
  • Cisco Employee,
show crypto isa sa
ayman emara Wed, 05/26/2010 - 04:16
Hi halijenn,
Yes i have changed as you adviced.
FW# show crypto isa sa
FW#
FW# show crypto ipsec sa
There are no ipsec sas
thanks for help
Ayman
Correct Answer
Jennifer Halim Wed, 05/26/2010 - 04:30
  • Cisco Employee,
ayman emara Wed, 05/26/2010 - 04:59
this is the logging from the VPN client :
Cisco Systems VPN Client Version 4.8.01.0300
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
Correct Answer
Jennifer Halim Wed, 05/26/2010 - 05:05
  • Cisco Employee,
ayman emara Wed, 05/26/2010 - 05:33
sorry halijenn,
kindly find the below:
150    15:31:57.375  05/26/10  Sev=Info/4    CM/0x63100002
Begin connection process
151    15:31:57.375  05/26/10  Sev=Info/4    CVPND/0xE3400001
Microsoft IPSec Policy Agent service stopped successfully
152    15:31:57.375  05/26/10  Sev=Info/4    CM/0x63100004
Establish secure connection using Ethernet
153    15:31:57.375  05/26/10  Sev=Info/4    CM/0x63100024
Attempt connection with server "196.218.181.234"
154    15:31:58.375  05/26/10  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with 196.218.181.234.
155    15:31:58.375  05/26/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 196.218.181.234
156    15:31:58.375  05/26/10  Sev=Info/4    IPSEC/0x63700008
IPSec driver successfully started
157    15:31:58.375  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
158    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = 196.218.181.234
159    15:31:59.046  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from 196.218.181.234
160    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000001
Peer is a Cisco-Unity compliant peer
161    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
162    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports DPD
163    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports NAT-T
164    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports IKE fragmentation payloads
165    15:31:59.046  05/26/10  Sev=Info/6    IKE/0x63000001
IOS Vendor ID Contruction successful
166    15:31:59.046  05/26/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 196.218.181.234
167    15:31:59.046  05/26/10  Sev=Info/6    IKE/0x63000055
Sent a keepalive on the IPSec SA
168    15:31:59.046  05/26/10  Sev=Info/4    IKE/0x63000083
IKE Port in use - Local Port =  0x1194, Remote Port = 0x1194
169    15:31:59.046  05/26/10  Sev=Info/5    IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
170    15:31:59.046  05/26/10  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
171    15:31:59.750  05/26/10  Sev=Info/5    IKE/0x6300002F
172    15:31:59.750  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 196.218.181.234
173    15:31:59.750  05/26/10  Sev=Info/4    CM/0x63100015
Launch xAuth application
174    15:32:01.375  05/26/10  Sev=Info/4    CM/0x63100017
xAuth application returned
175    15:32:01.375  05/26/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 196.218.181.234
176    15:32:02.031  05/26/10  Sev=Info/5    IKE/0x6300002F
177    15:32:02.031  05/26/10  Sev=Info/4    IKE/0x63000014
178    15:32:02.031  05/26/10  Sev=Info/4    IKE/0x63000013
179    15:32:02.031  05/26/10  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
180    15:32:02.312  05/26/10  Sev=Info/5    IKE/0x6300005E
Client sending a firewall request to concentrator
181    15:32:02.312  05/26/10  Sev=Info/5    IKE/0x6300005D
Firewall Policy: Product=Cisco Systems Integrated Client Firewall, Capability= (Centralized Protection Policy).
182    15:32:02.312  05/26/10  Sev=Info/4    IKE/0x63000013
183    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x6300002F
184    15:32:02.984  05/26/10  Sev=Info/4    IKE/0x63000014
185    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 172.16.1.100
186    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_NETMASK: , value = 255.255.255.0
187    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SAVEPWD: , value = 0x00000000
188    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_PFS: , value = 0x00000000
189    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5520 Version 7.0(8) built by builders on Sat 31-May-08 23:48
190    15:32:02.984  05/26/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = Received and using NAT-T port number , value = 0x00001194
191    15:32:02.984  05/26/10  Sev=Info/4    CM/0x63100019
Mode Config data received
192    15:32:02.984  05/26/10  Sev=Info/4    IKE/0x63000056
Received a key request from Driver: Local IP = 172.16.1.100, GW IP = 196.218.181.234, Remote IP = 0.0.0.0
193    15:32:02.984  05/26/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 196.218.181.234
194    15:32:03.328  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
195    15:32:03.687  05/26/10  Sev=Info/5    IKE/0x6300002F
196    15:32:03.687  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 196.218.181.234
197    15:32:03.687  05/26/10  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 43200 seconds
198    15:32:03.687  05/26/10  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 5 seconds, setting expiry to 43195 seconds from now
199    15:32:03.687  05/26/10  Sev=Info/5    IKE/0x6300002F
200    15:32:03.687  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO (FRAG) from 196.218.181.234
201    15:32:03.703  05/26/10  Sev=Info/5    IKE/0x6300002F
202    15:32:03.703  05/26/10  Sev=Info/4    IKE/0x63000014
203    15:32:03.734  05/26/10  Sev=Info/5    IKE/0x6300002F
204    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000014
205    15:32:03.734  05/26/10  Sev=Info/5    IKE/0x63000073
All fragments received.
206    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:INVALID_ID_INFO) from 196.218.181.234
207    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 196.218.181.234
208    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=4280D439
209    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=201F310765753FE5 R_Cookie=90B7636188FDA5A1) reason = DEL_REASON_IKE_NEG_FAILED
210    15:32:03.734  05/26/10  Sev=Info/5    IKE/0x6300002F
211    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=201F310765753FE5 R_Cookie=90B7636188FDA5A1
212    15:32:03.734  05/26/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(Dropped) from 196.218.181.234
213    15:32:06.828  05/26/10  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=201F310765753FE5 R_Cookie=90B7636188FDA5A1) reason = DEL_REASON_IKE_NEG_FAILED
214    15:32:06.828  05/26/10  Sev=Info/4    CM/0x63100012
Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_IKE_NEG_FAILED".  0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
215    15:32:06.828  05/26/10  Sev=Info/5    CM/0x63100025
Initializing CVPNDrv
216    15:32:06.828  05/26/10  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 0.
217    15:32:06.828  05/26/10  Sev=Info/4    IKE/0x63000001
IKE received signal to terminate VPN connection
218    15:32:06.828  05/26/10  Sev=Info/4    IKE/0x63000086
Microsoft IPSec Policy Agent service started successfully
219    15:32:06.828  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
220    15:32:06.828  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
221    15:32:06.828  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
222    15:32:06.828  05/26/10  Sev=Info/4    IPSEC/0x6370000A
IPSec driver successfully stopped
223    15:32:07.765  05/26/10  Sev=Info/4    CM/0x63100002
224    15:32:07.765  05/26/10  Sev=Info/4    CVPND/0xE3400001
225    15:32:07.765  05/26/10  Sev=Info/4    CM/0x63100004
226    15:32:07.765  05/26/10  Sev=Info/4    CM/0x63100024
227    15:32:08.765  05/26/10  Sev=Info/6    IKE/0x6300003B
228    15:32:08.781  05/26/10  Sev=Info/4    IKE/0x63000013
229    15:32:08.781  05/26/10  Sev=Info/4    IPSEC/0x63700008
230    15:32:08.781  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
231    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x6300002F
232    15:32:09.453  05/26/10  Sev=Info/4    IKE/0x63000014
233    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000001
234    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
235    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports DPD
236    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000001
Peer supports NAT-T
237    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000001
238    15:32:09.453  05/26/10  Sev=Info/6    IKE/0x63000001
239    15:32:09.453  05/26/10  Sev=Info/4    IKE/0x63000013
240    15:32:09.453  05/26/10  Sev=Info/6    IKE/0x63000055
241    15:32:09.453  05/26/10  Sev=Info/4    IKE/0x63000083
242    15:32:09.453  05/26/10  Sev=Info/5    IKE/0x63000072
243    15:32:09.453  05/26/10  Sev=Info/4    CM/0x6310000E
244    15:32:10.109  05/26/10  Sev=Info/5    IKE/0x6300002F
245    15:32:10.109  05/26/10  Sev=Info/4    IKE/0x63000014
246    15:32:10.109  05/26/10  Sev=Info/4    CM/0x63100015
247    15:32:11.609  05/26/10  Sev=Info/4    CM/0x63100017
248    15:32:11.609  05/26/10  Sev=Info/4    IKE/0x63000013
249    15:32:12.296  05/26/10  Sev=Info/5    IKE/0x6300002F
250    15:32:12.296  05/26/10  Sev=Info/4    IKE/0x63000014
251    15:32:12.296  05/26/10  Sev=Info/4    IKE/0x63000013
252    15:32:12.296  05/26/10  Sev=Info/4    CM/0x6310000E
253    15:32:12.593  05/26/10  Sev=Info/5    IKE/0x6300005E
254    15:32:12.593  05/26/10  Sev=Info/5    IKE/0x6300005D
255    15:32:12.593  05/26/10  Sev=Info/4    IKE/0x63000013
256    15:32:13.328  05/26/10  Sev=Info/5    IKE/0x6300002F
257    15:32:13.328  05/26/10  Sev=Info/4    IKE/0x63000014
258    15:32:13.328  05/26/10  Sev=Info/5    IKE/0x63000010
259    15:32:13.328  05/26/10  Sev=Info/5    IKE/0x63000010
260    15:32:13.343  05/26/10  Sev=Info/5    IKE/0x6300000D
261    15:32:13.343  05/26/10  Sev=Info/5    IKE/0x6300000D
262    15:32:13.343  05/26/10  Sev=Info/5    IKE/0x6300000E
263    15:32:13.343  05/26/10  Sev=Info/5    IKE/0x6300000D
264    15:32:13.343  05/26/10  Sev=Info/4    CM/0x63100019
265    15:32:13.343  05/26/10  Sev=Info/4    IKE/0x63000056
266    15:32:13.343  05/26/10  Sev=Info/4    IKE/0x63000013
267    15:32:13.828  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
268    15:32:14.109  05/26/10  Sev=Info/5    IKE/0x6300002F
269    15:32:14.109  05/26/10  Sev=Info/4    IKE/0x63000014
270    15:32:14.109  05/26/10  Sev=Info/5    IKE/0x63000045
271    15:32:14.109  05/26/10  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 6 seconds, setting expiry to 43194 seconds from now
272    15:32:14.125  05/26/10  Sev=Info/5    IKE/0x6300002F
273    15:32:14.125  05/26/10  Sev=Info/4    IKE/0x63000014
274    15:32:14.156  05/26/10  Sev=Info/5    IKE/0x6300002F
275    15:32:14.156  05/26/10  Sev=Info/4    IKE/0x63000014
276    15:32:14.171  05/26/10  Sev=Info/5    IKE/0x6300002F
277    15:32:14.171  05/26/10  Sev=Info/4    IKE/0x63000014
278    15:32:14.171  05/26/10  Sev=Info/5    IKE/0x63000073
279    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000014
280    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000013
281    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=F3754338
282    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=CBDFD65E6BEF2EC7 R_Cookie=EF8DB6A138C2E1E9) reason = DEL_REASON_IKE_NEG_FAILED
283    15:32:14.187  05/26/10  Sev=Info/5    IKE/0x6300002F
284    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=CBDFD65E6BEF2EC7 R_Cookie=EF8DB6A138C2E1E9
285    15:32:14.187  05/26/10  Sev=Info/4    IKE/0x63000014
286    15:32:17.328  05/26/10  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=CBDFD65E6BEF2EC7 R_Cookie=EF8DB6A138C2E1E9) reason = DEL_REASON_IKE_NEG_FAILED
287    15:32:17.328  05/26/10  Sev=Info/4    CM/0x63100012
288    15:32:17.328  05/26/10  Sev=Info/5    CM/0x63100025
289    15:32:17.328  05/26/10  Sev=Info/6    CM/0x63100046
290    15:32:17.328  05/26/10  Sev=Info/4    IKE/0x63000001
291    15:32:17.328  05/26/10  Sev=Info/4    IKE/0x63000086
292    15:32:17.328  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
293    15:32:17.328  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
294    15:32:17.328  05/26/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
295    15:32:17.328  05/26/10  Sev=Info/4    IPSEC/0x6370000A
ayman emara Sat, 05/29/2010 - 01:20
hi halijenn,
did the logs means something ,or you wanna me do something else?
Thanks in advance
Ayman
Correct Answer
Federico Coto F... Sat, 05/29/2010 - 01:28
  • Green, 3000 points or more
Federico.
Correct Answer
Federico Coto F... Sat, 05/29/2010 - 01:43
Some comments:
Change this line:
To this one:
Federico.
ayman emara Sat, 05/29/2010 - 02:02
Thanks very much Federico it worked
thanks for you all you are really helpful .
Ayman
