osiris_users Mon, 05/24/2010 - 06:53
Показать латиницей
Prompt please - this model, these updates cost money? Where you can download them and read about the installation method.
Many thanks in advance!
Reza Sharifi Mon, 05/24/2010 - 09:26
Hi osiris,
If you have an IP based version and want to upgrade to a different IOS  with different feature set, there is usually a cost involved.  Check with your sales rep for pricing.
In the mean time can you post "sh ver"?
you might already have the IOS you need.
Reza
Ganesh Hariharan Tue, 05/25/2010 - 00:01
Hello!
Can I use dynamic and static routing between vlans
on this switcher?
You can achieve but you need to have ios version supported to do following ios with 3560 switch will support dynamic and staic routing protocol
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEAS E SOFTWARE (fc1)
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
