Internal ACS Error
Answered Question
May 24th, 2010
I am aving trouble getting ACS 4.2 to sync with domain controller running window 2008, I see the error listed below in the CS AUTH Logs when a user tries to authenticate via Windows external database:
CS AUTH Logs: AUTH 05/24/2010 11:08:19 E 2100 49316 0x2 External DB [NTAuthenDLL.dll]: Windows authentication FAILED (error 6L)
Any suggestions
Correct Answer by Jagdeep Gambhir about 6 years 10 months ago
Win2008 is supported from ACS ver 4.2 patch 4 onwards, so you need to upgrade your ACS to 4.2(latest patch).
ACS 4.2.0.124 cumulative patch for windows can be downloaded from this link,
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Also
ACS is currently not supported on Win2008 R2 (ACS running on win2008 R2)
So make sure you are running acs 4.2.0 with latest patch or 4.2.1.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Mon, 05/24/2010 - 11:14
  • Red, 2250 points or more
Also
~JG
