05-24-2010 09:56 AM - edited 03-06-2019 11:14 AM
Dear all,
The following is the original module on the switch 4507R.
Its version is boot system flash bootflash:cat4000-is-mz.121-13.EW.bin
CMDOWNLOAD#sh mod
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(standby) WS-X4515 JAB071604SU
2 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAB07150552
3 24 10/100/1000BaseTX (RJ45) WS-X4424-GB-RJ45 JAB070905HP
4 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE07081DLY
5 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE07081G8B
6 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE0727102L
7 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE0716065N
Due to upgrade the module on the switch 4507r, I replaced the new Gigabit module for original module 4 (100MB based)
However, I got the error message:
0:06:44: %C4K_CHASSIS-3-UNKNOWNLINECARD: Unknown module (Field Replaceable Unit minor type 340) in slot 4
and saw the module status as following
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAB071604SU
2 2 1000BaseX (GBIC) Supervisor(standby) WS-X4515 JAB07150552
4 0 Unsupported module WS-X4548-GB-RJ45 JAE0918B1S9
I found many information showing that WS-X4548-GB-RJ45V is supported by 4507R......
Should I upgrade my IOS?
Thank you so much.
Solved! Go to Solution.
05-24-2010 10:38 AM
umum00029 wrote:
I found many information showing that WS-X4548-GB-RJ45V is supported by 4507R......Should I upgrade my IOS?
Thank you so much.
Yes you need to upgrade your IOS. You need a minimum of 12.1(19)EW to run that module. From the release notes -
WS-X4548-GB-RJ45 | 48-port 10/100/1000BASE-T Gigabit Ethernet switching module | 12.1(19)EW | 12.1(19)EW1 |
Jon
05-24-2010 11:34 PM
Dear all,
CMDOWNLOAD#sh mod
1 2 1000BaseX (GBIC) Supervisor(standby) WS-X4515 JAB071604SU2 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAB07150552
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAB071604SU2 2 1000BaseX (GBIC) Supervisor(standby) WS-X4515 JAB07150552
Yes you need to upgrade the ios to support for the module check out the below link for more information about the ios supported.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-24-2010 10:38 AM
Thank you so much.
Jon
05-24-2010 11:34 PM
Dear all,
CMDOWNLOAD#sh mod
Hope to Help !!
Ganesh.H
