Cisco Unity Connection IMAP !!!
May 24th, 2010
Hi all,
I have Unity Connection 7.x, i want to work it with Microsoft Outlook so that i can recive my voice msgs in seprate mail box  !!! can any body tell me how to do IMAP configuration for unity connection 7.x  or if some one can tell me the steps ????
Overall Rating: 4 (1 ratings)
David Hailey Mon, 05/24/2010 - 11:11
  • Purple, 4500 points or more
System Administration Guide - Chapter 20
The document is attached.  Ask questions if you need to.  It's pretty straightforward.
Hailey
Please rate helpful posts!
anis_cisco Mon, 05/24/2010 - 13:19
Thanks david,
I will get back to you if i will face any issues !!!
Thanks alot...
tc
anis_cisco Wed, 06/02/2010 - 02:29
hey david,
I need your urgent help  !!! im not able to login into the outlook .. im using the alias as a username which i configured @ connection & im using cisco PCA (Cisco web application) password but im not able to login ..... I checked the password setting for web application & for voice mail but there isnt any mistake .. the passwords are checked for password never expire ..... I tried by configuring ACL with * ( all subnets are allowed) still no luck !!!
i did the necessary configuration on unity connection & as well @ outlook ????
can you help me into this please urgently !!!
David Hailey Wed, 06/02/2010 - 06:20
Let's try this first:
1) Verify that you can login to Cisco PCA with the user ID and web application password successfully before you try to login via IMAP.
2) For SMTP, allow Untrusted Connections and disable authentication.
3) Verify the SMTP domain name of the your Unity Connection server/cluster.
4) Double-check the settings which you are entering into your IMAP connection via IMAP.
Hailey
anis_cisco Wed, 06/02/2010 - 06:43
Hey David,
Thanx for your reply .. i sorted out the issue .. the mistake was i didnt selected the IMAP client in Class of Service !!!! i just select & it started to work perfectly !!!
Thanx for your reply....
Cheers,
David Hailey Wed, 06/02/2010 - 06:46
Ah, yes sir...that's the most basic item of them all.  That'll do it for sure.  Thanks for the repost.
Hailey
