Problem WLAN controller 4400
May 24th, 2010
There is a WLAN controller 4400 which controls the access points. There is a collapse of all access points from 00:00 to 00:12.
The link is working properly, no problems with the AC, the point is not restarted.
Logging
1.  May 24 2010 00:01:08 CAPWAP 3 ECHO_ERR capwap_ac_sm.c:5116 Did not receive heartbeat reply; AP: 00:3a:98:5e:f7:80 *
2.  May 24 2010 00:02:38 CAPWAP 3 ECHO_ERR capwap_ac_sm.c:5116 Did not receive heartbeat reply; AP: 00:26:ca:b7:ce:30 *
3.  May 24 2010 00:02:49 DOT1X 3 ABORT_AUTH 1x_bauth_sm.c:447 Authentication aborted for client 00:15:70:f1:e4:b4 *
4.  May 24 2010 00:03:07 APF 3 INVALID_RADIO_TYPE apf_api.c:27324 Invalid radio type 255 received. *
5.  May 24 2010 00:06:50 APF 3 INVALID_RADIO_TYPE apf_api.c:27324 Invalid radio type 255 received. *
6.  May 24 2010 00:06:50 APF 3 INVALID_RADIO_TYPE apf_api.c:27337 Invalid radio type 255 received. *
7.  May 24 2010 00:06:50 APF 3 INVALID_RADIO_TYPE apf_api.c:27324 Invalid radio type 255 received. *
8.  May 24 2010 00:06:50 APF 3 INVALID_RADIO_TYPE apf_api.c:27337 Invalid radio type 255 received. *
9.  May 24 2010 00:07:03 APF 3 INVALID_RADIO_TYPE apf_api.c:27324 Invalid radio type 255 received. *
10.  May 24 2010 00:07:03 APF 3 INVALID_RADIO_TYPE apf_api.c:27337 Invalid radio type 255 received. *
11.  May 24 2010 00:07:10 APF 3 INVALID_RADIO_TYPE apf_api.c:27324 Invalid radio type 255 received. *
12.  May 24 2010 00:07:10 APF 3 INVALID_RADIO_TYPE apf_api.c:27337 Invalid radio type 255 received.
Leo Laohoo Mon, 05/24/2010 - 15:33
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If your WLC firmware is 5.X then I would like to recommend you upgrade to 6.X.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
