05-24-2010 11:52 AM - edited 03-06-2019 11:14 AM
We have a 3640 with a NW-16ESW that has high CPU when routing between VLANs. We get about 75% CPU utilization when we are only doing about 5000pps with a bandwidth of about 7Mb going through the router. I'm thinking we should be able to handle > 40K pps with this router. Why is the router not handling the traffic better?
Most of the traffic is SCTP going between F3/2 Vlan 61 and F3/15 Vlan 1000.
Here's some relevent info:
Router2#show ver
Cisco IOS Software, 3600 Software (C3640-IK9O3S-M), Version 12.4(25b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 12-Aug-09 12:52 by prod_rel_team
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router2 uptime is 12 weeks, 1 day, 21 hours, 28 minutes
System restarted at 15:20:57 CST Sat Feb 27 2010
System image file is "flash:c3640-ik9o3s-mz.124-25b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3640 (R4700) processor (revision 0x00) with 121856K/9216K bytes of memory.
Processor board ID 19590546
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
18 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname Router2
ip cef
no spanning-tree vlan 1
no spanning-tree vlan 2
no spanning-tree vlan 11
no spanning-tree vlan 20
no spanning-tree vlan 21
no spanning-tree vlan 30
no spanning-tree vlan 50
no spanning-tree vlan 51
no spanning-tree vlan 52
no spanning-tree vlan 60
no spanning-tree vlan 61
no spanning-tree vlan 62
no spanning-tree vlan 70
no spanning-tree vlan 71
no spanning-tree vlan 1000
no spanning-tree vlan 1001
interface Loopback0
ip address 192.168.1.2 255.255.255.255
interface FastEthernet1/0
ip address 172.22.102.247 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
ip address 10.1.1.5 255.255.255.252
duplex auto
speed auto
interface FastEthernet3/1
switchport access vlan 52
load-interval 30
interface FastEthernet3/2
switchport access vlan 61
load-interval 30
interface FastEthernet3/3
switchport access vlan 62
load-interval 30
no cdp enable
interface FastEthernet3/4
switchport access vlan 20
load-interval 30
duplex full
speed 100
interface FastEthernet3/6
switchport access vlan 71
load-interval 30
duplex full
speed 100
interface FastEthernet3/8
switchport access vlan 60
load-interval 30
duplex full
speed 100
interface FastEthernet3/9
switchport access vlan 21
load-interval 30
duplex full
speed 100
spanning-tree portfast
interface FastEthernet3/10
switchport access vlan 51
load-interval 30
duplex full
speed 100
interface FastEthernet3/11
switchport access vlan 30
load-interval 30
interface FastEthernet3/12
switchport access vlan 70
load-interval 30
duplex full
speed 100
interface FastEthernet3/13
load-interval 30
duplex full
speed 100
interface FastEthernet3/14
switchport access vlan 1001
load-interval 30
no keepalive
interface FastEthernet3/15
switchport trunk native vlan 1000
switchport trunk allowed vlan 1,21,1000,1002-1005
switchport mode trunk
load-interval 30
duplex full
speed 100
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.100.2.3 255.255.255.128
standby ip 10.100.2.1
standby timers msec 500 1
standby priority 110
standby preempt
interface Vlan11
ip address 10.205.1.3 255.255.255.128
glbp 0 ip 10.205.1.1
interface Vlan20
ip address 10.203.1.3 255.255.255.0
standby ip 10.203.1.1
standby timers 1 2
interface Vlan21
ip address 10.203.2.3 255.255.255.0
ip helper-address 10.206.1.35
ip helper-address 10.206.1.37
standby ip 10.203.2.1
standby timers 1 2
interface Vlan30
ip address 8.10.109.1 255.255.255.0
interface Vlan51
ip address 10.206.1.3 255.255.255.128
standby ip 10.206.1.1
interface Vlan52
ip address 8.10.2.131 255.255.255.128
ip helper-address 8.10.3.35
ip helper-address 8.10.3.37
standby ip 8.10.2.129
interface Vlan60
ip address 10.204.1.3 255.255.255.128
glbp 0 ip 10.204.1.1
interface Vlan61
ip address 8.10.103.1 255.255.255.0
interface Vlan62
ip address 8.10.104.1 255.255.255.0
interface Vlan70
ip address 10.160.207.3 255.255.255.128
ip helper-address 10.204.1.19
ip helper-address 10.204.1.21
standby ip 10.160.207.1
standby timers msec 300 1
interface Vlan71
ip address 10.204.4.3 255.255.255.128
standby ip 10.204.4.1
interface Vlan1000
ip address 10.1.1.10 255.255.255.252
interface Vlan1001
ip address 10.1.1.21 255.255.255.252
router eigrp 100
redistribute static
redistribute ospf 1
passive-interface default
no passive-interface FastEthernet2/0
no passive-interface Vlan1000
network 8.0.0.0
network 10.0.0.0
default-metric 100000 10 255 1 1514
no auto-summary
router ospf 1
router-id 192.168.1.2
log-adjacency-changes
timers throttle spf 5 100 5000
timers throttle lsa all 5 100 5000
timers lsa arrival 50
redistribute eigrp 100 subnets
no passive-interface Vlan1001
network 10.1.1.20 0.0.0.3 area 0
network 10.100.2.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.22.102.1
ip route 172.30.18.0 255.255.255.0 8.10.103.4
snmp-server community public RO
control-plane
mgcp behavior g729-variants static-pt
line con 0
line aux 0
line vty 0 4
exec-timeout 3660 0
logging synchronous
login
terminal-type mon
Router2#sho proc cpu sort
CPU utilization for five seconds: 86%/70%; one minute: 75%; five minutes: 75%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
188 7614256 884556 8607 4.99% 0.65% 0.47% 0 SNMP ENGINE
16 456989136 106171824 4304 2.94% 2.94% 2.96% 0 ARP Input
64 4304512 1686473 2552 2.37% 0.30% 0.20% 0 IP SNMP
59 115965776 51699731 2243 1.80% 0.76% 0.69% 0 IP Input
5 34986620 1552834 22530 1.31% 0.26% 0.18% 0 Check heaps
183 1719988 848105 2028 0.98% 0.13% 0.07% 0 PDU DISPATCHER
184 57672684 54767397 1053 0.49% 0.58% 0.57% 0 HSRP (Standby)
54 85767848 7410211 11574 0.49% 0.44% 0.43% 0 tCOUNTER
52 60119908 34976406 1718 0.40% 0.36% 0.35% 0 IGMP Snooping Re
196 1260 557 2262 0.32% 0.02% 0.00% 130 Virtual Exec
95 9096200 73609914 123 0.16% 0.19% 0.18% 0 RBSCP Background
112 1945164 7420532 262 0.08% 0.02% 0.00% 0 RUDPV1 Main Proc
79 4361616 28971622 150 0.08% 0.07% 0.08% 0 SSS Feature Time
30 1405448 7409457 189 0.08% 0.01% 0.00% 0 TTY Background
47 12718124 1551488 8197 0.08% 0.08% 0.08% 0 Compute load avg
107 21986460 12413900 1771 0.08% 0.15% 0.16% 0 CEF process
192 7355868 6431667 1143 0.08% 0.04% 0.06% 0 IP-EIGRP: HELLO
27 4455184 8156560 546 0.08% 0.03% 0.05% 0 Net Background
80 55900 59561 938 0.08% 0.00% 0.00% 0 TCP Timer
Rest are 0%
Router2#sho interfaces switching
FastEthernet2/0
Throttle count 0
Drops RP 0 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 1606754 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 1606296 118888059 1604913 118760471
Cache misses 0 - - -
Fast 80189881 890053776 393675494 439905742
Auton/SSE 0 0 0 0
Protocol ARP
Process 520 31200 520 31200
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 123629 42775634 123623 42773558
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 0 0 741581 44494860
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
FastEthernet3/1
All statistics for this interface are zero.
FastEthernet3/2
Throttle count 0
Drops RP 3909 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 0 Drops 0
FastEthernet3/3
Throttle count 0
Drops RP 10713 SP 0
SPD Aggress Fast 0
Protocol Other
Process 123612 47219784 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
FastEthernet3/4
Throttle count 0
Drops RP 21167 SP 0
SPD Aggress Fast 0
Protocol Other
Process 247207 13596385 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
FastEthernet3/8
Throttle count 0
Drops RP 2242 SP 0
SPD Aggress Fast 0
FastEthernet3/9
Throttle count 0
Drops RP 1257 SP 0
SPD Aggress Fast 0
FastEthernet3/10
Throttle count 0
Drops RP 24166 SP 0
SPD Aggress Fast 0
Protocol Other
Process 247218 13596990 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
FastEthernet3/11
Throttle count 0
Drops RP 1 SP 0
SPD Aggress Fast 0
FastEthernet3/12
Throttle count 0
Drops RP 241 SP 0
SPD Aggress Fast 0
Protocol Other
Process 295624 27494699 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
FastEthernet3/13
Throttle count 0
Drops RP 144 SP 0
SPD Aggress Fast 0
FastEthernet3/14
Throttle count 0
Drops RP 518 SP 0
SPD Aggress Fast 0
FastEthernet3/15
Throttle count 0
Drops RP 7176 SP 0
SPD Aggress Fast 0
Vlan2
Throttle count 0
Drops RP 62 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 12917815 Drops 59
Protocol IP
Process 311090 20013366 310324 19497064
Fast 2699440 162096376 1766101 105966136
Auton/SSE 0 0 0 0
Protocol ARP
Process 12856531 771391860 3754 225240
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 21 1680 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan20
Throttle count 0
Drops RP 26 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 170864020 Drops 25
Protocol IP
Process 7668910 475704532 7422530 460196842
Fast 389284739 9986005 79179155 653772410
Auton/SSE 0 0 0 0
Protocol ARP
Process 171095975 1675823908 62888 3773280
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 234729 14138460 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan21
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 10036 Drops 0
Protocol IP
Process 7647297 473593702 7422692 460212500
Fast 176622731 2839806715 193103180 467221336
Auton/SSE 0 0 0 0
Protocol ARP
Process 9998 602140 2710126 162607560
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 233 329462 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan30
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 2808317 Drops 0
Protocol IP
Process 56 3584 0 0
Fast 0 0 20274149 1589339948
Auton/SSE 0 0 0 0
Protocol ARP
Process 2808317 168558948 6003049 360182940
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan51
Throttle count 0
Drops RP 2927720 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 15772438 Drops 2815542
Protocol IP
Process 6429109 910157615 2470549 153179634
Fast 209354743 3774049520 176645242 2850922825
Auton/SSE 0 0 0 0
Protocol ARP
Process 15772366 946350016 23823 1429380
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 5385 1559364 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan60
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 3341636 Drops 0
Protocol IP
Process 7719393 902981695 2545349 277617298
Fast 329904518 2733552572 340631949 3701461606
Auton/SSE 0 0 0 0
Protocol ARP
Process 3341637 200498220 7082 424920
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 247339 14842560 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan61
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 84450 Drops 0
Protocol IP
Process 9204817 680176034 222668 123284020
Fast 70095026 3973635844 664982555 2069783134
Auton/SSE 0 0 0 0
Protocol ARP
Process 84450 5067032 78206 4692360
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan62
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 101046 Drops 0
Protocol IP
Process 222524 123278296 222541 123279486
Fast 473026379 2436528465 1248128210 1527019850
Auton/SSE 0 0 0 0
Protocol ARP
Process 101046 6062768 74638 4478280
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan70
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 7092096 Drops 13968
Protocol ARP
Process 0 0 2 120
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan71
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 5693699 Drops 0
Protocol IP
Process 6055858 377177859 5966708 369935886
Fast 5711 544967 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 5693699 341621940 932 55920
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 51 4080 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan1000
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 1260 Drops 0
Protocol IP
Process 1602437 118623019 4328858 309473290
Fast 1932870753 804829182 615725003 2786812294
Auton/SSE 0 0 0 0
Protocol ARP
Process 523 31380 527 31620
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Vlan1001
Throttle count 0
Drops RP 205 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 563 Drops 0
Protocol IP
Process 3540867 1012635054 769858 76510068
Fast 111272160 3163087992 1977301 125917204
Auton/SSE 0 0 0 0
Protocol ARP
Process 533 31980 540 32400
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 12315 948136 0 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Router2#show ip cef detail
IP CEF with switching (Table Version 1258), flags=0x0
218 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 2
5 instant recursive resolutions, 0 used background process
221 leaves, 39 nodes, 74152 bytes, 1115 inserts, 894 invalidations
0 load sharing elements, 0 bytes, 0 references
universal per-destination load sharing algorithm, id 1782FBB1
2(0) CEF resets, 144 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 1s)
146 in-place/0 aborted modifications
refcounts: 11066 leaf, 10240 node
Table epoch: 0 (221 entries at this epoch)
Adjacency Table has 141 adjacencies
Router2#show align
Alignment data for:
No alignment data has been recorded.
Total Spurious Accesses 2, Recorded 1
Address Count Traceback
24 2 0x60315230 0x604EF18C 0x6050B52C 0x605AEC8C
0x605AEC70
Router2#show inte stats
FastEthernet1/0
Processor 1130688 114851873 577963 84852860
Route cache 13605 1463761 7093825 1429828267
Total 1144293 116315634 7671788 1514681127
FastEthernet2/0
Processor 82362 7701122 117635 9812316
Route cache 174 44028 6902103 935404127
Total 82536 7745150 7019738 945216443
FastEthernet3/2
Processor 444153254 990538626 495449540 94331715
Route cache 0 0 0 0
Total 444153254 990538626 495449540 94331715
FastEthernet3/3
Processor 300779026 3717677162 310480461 2513167776
Route cache 0 0 0 0
Total 300779026 3717677162 310480461 2513167776
FastEthernet3/4
Processor 19920203 1802497784 360403 25485486
Route cache 0 0 0 0
Total 19920203 1802497784 360403 25485486
FastEthernet3/6
Processor 2723632 178469348 1175480 79254804
Route cache 0 0 0 0
Total 2723632 178469348 1175480 79254804
FastEthernet3/8
Processor 7571699 1499308330 129790 16567181
Route cache 0 0 0 0
Total 7571699 1499308330 129790 16567181
FastEthernet3/9
Processor 3848919 1277090111 5072160 572453048
Route cache 0 0 0 0
Total 3848919 1277090111 5072160 572453048
FastEthernet3/10
Processor 6294469 783755818 3973472 1286991286
Route cache 0 0 0 0
Total 6294469 783755818 3973472 1286991286
FastEthernet3/11
Processor 113194 7244564 358735 24649757
Route cache 0 0 0 0
Total 113194 7244564 358735 24649757
FastEthernet3/14
Processor 16719928 1470627500 43080 5965025
Route cache 0 0 0 0
Total 16719928 1470627500 43080 5965025
FastEthernet3/15
Processor 806356059 2629024827 758498534 1550085454
Route cache 0 0 0 0
Total 806356059 2629024827 758498534 1550085454
Vlan20
Processor 12283275 736996500 354353 21966890
Route cache 6902185 938906470 164 39008
Total 19185460 1675902970 354517 22005898
Vlan21
Processor 55 3400 482598 29661584
Route cache 3848913 1261699109 4217966 497819614
Total 3848968 1261702509 4700564 527481198
Vlan30
Processor 113159 6789540 352842 21170520
Route cache 0 0 0 0
Total 113159 6789540 352842 21170520
Vlan51
Processor 817737 74014504 118680 7356228
Route cache 4976447 652147812 3848913 1261699060
Total 5794184 726162316 3967593 1269055288
Vlan60
Processor 164013 9840780 118010 12024672
Route cache 7066433 1427419466 0 0
Total 7230446 1437260246 118010 12024672
Vlan61
Processor 544000 38931488 14494 6102582
Route cache 443610386 3469406212 495437410 2400890752
Total 444154386 3508337700 495451904 2406993334
Vlan62
Processor 15479 6166622 14265 6093782
Route cache 300586917 2496259380 310471628 1266036642
Total 300602396 2502426002 310485893 1272130424
Vlan71
Processor 1180407 70824420 1169613 72515510
Route cache 1691 165718 0 0
Total 1182098 70990138 1169613 72515510
Vlan1000
Processor 92 6744 490337 34629060
Route cache 805909450 3667001890 757521229 2743052024
Total 805909542 3667008634 758011566 2777681084
Vlan1001
Processor 414503 141596118 36827 3684512
Route cache 16225116 1254014696 362 64016
Total 16639619 1395610814 37189 3748528
Router2#sho cef not-cef-switched
CEF Packets passed on to next switching layer
Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag
RP 706334 0 0 11994 651421 0 0 0
Router2#sho ip cache flow
IP packet size distribution (3990061 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .644 .029 .008 .035 .068 .016 .007 .011 .017 .023 .006 .005 .006 .007
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.005 .004 .004 .073 .023 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 1137 added
320921 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 21640 bytes
0 active, 1024 inactive, 114 added, 114 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 5 0.0 151 40 0.0 54.5 15.4
UDP-NTP 126 0.0 1 76 0.0 0.0 15.2
UDP-TFTP 1 0.0 1 48 0.0 0.0 15.6
UDP-other 485 0.0 192 251 0.0 235.8 15.4
ICMP 217 0.0 4 135 0.0 1.4 15.3
IP-other 303 0.0 12854 182 0.9 561.8 15.5
Total: 1137 0.0 3509 184 0.9 250.8 15.4
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
06-01-2010 03:36 AM
From your output:
I see that first 3 lines are related to SNMP processes.
Try a "show snmp" command. Do you see a lot of errors there?
According to this: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800948e6.shtml
There are two probable causes for high CPU utilization occuring in relation to Simple Network Management Protocol (SNMP):
Large route and/or ARP tables being polled by the NMS station
Polling certain MIBs
How big is your ARP table?
If you are not using SNMP, try turn it off (no snmp-server), and check if there is still high utilisation on the CPU.
Let me know if this helps.
06-01-2010 08:48 AM
Isn't the utilization of the processes only 16% ( 86% - 70% ), and the 70% is interrupts, ie. packet routing.
SNMP is begin utilizated by MRTG which created the graphs that you can see in the original post. The utilization was high before I implemented MRTG, and I setup MRTG to try and get some good data for troubleshooting the high CPU, it is not the cause. MRTG shows that the CPU utilization graph follows the unicast packets per second graph pretty closely.
I do have an issue with ARPs, but the ARP process is part of the 16%, which is insignificant compared to the 70% interrupts. I will address the ARPs after I get the 70% down.
Again, the CPU Utilization graph follows the UPPS graph, so I'm inferring that it is not the ARPs nor SNMP.
06-01-2010 07:01 AM
Hi Johnny,
please attach the output of 'show process 188' and save the output of 'sh run | in snmp' ,
NOTE:
"snmp-server community public RO"
**Your configuration has the community string public which is a security loop hole please do not give out your community strings on public forums**
We can try to reset the snmp engine and check if the High CPU problem fixes or not.
before we try the same please update the 'show process' command output.
Please do try changing the public string to somethink else and if you are using a monitoring tool for this device update the monitoring tool with the changed string, and if you are not using any monitoring tool you can turn off the SNMP ENGINE by using the 'no snmp-server' command on the conf t mode.
Please let me know if this was helpful.
podhillo
06-01-2010 08:51 AM
Please see the above message about the SNMP.
This is in an isolated lab, so I'm not concerned about the read only community strings, but thank you for observing a potental secutiry problem.
