Using RSPAN to watch a VLAN
Answered Question
May 24th, 2010
I have a switch in building A.  We want to capture all the audio traffic and send it to a switch in Building B.  Can I do that?
It seems simple enough to create the RSPAN VLAN, and reflector port.
Can I say "monitor session 1 source vlan 5" and then "monitor session 1 dest remote vlan 22 reflector-port fa0/21"
Cisco 3560s
The Cisco docs seem a little grey on this matter, but I've had a long day, so it may be my grey cells malfunctioning!!
I know I can monitor ALL traffic from those ports, but just trying to be efficient tells me I don't want the data traffic from the data VLAN, just the VOIP stuff.
Thanks.
Correct Answer by Jon Marshall about 7 years 3 days ago
townofnewmarket wrote:
Yes, but I guess my bigger question is this:
Both buildings (in fact several buildings all connected via fiber) have a VLAN 5 for voice.  So if I do this, even though I am doing it on Building A's switch (issuing the monitor session command), I would be grabbing all traffic from VLAN 5 (all switches) and forwarding it to the reflector port, wouldn't I?  Which would not be what I want, so I would probably go back to just mirroring all data.
Am I correct in that assumption?
No, you will be grabbing the vlan 5 traffic off the switch in building B and sending it to the switch in building A.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 05/24/2010 - 12:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Cisco 3560s
Thanks.
If you have L2 adjacency between your 2 buildings then yes you could use RSPAN to send all the vlan 5 traffic to a destination port on a switch in building A. Is this what you are asking ?
Jon
townofnewmarket Mon, 05/24/2010 - 13:35
Correct Answer
Jon Marshall Mon, 05/24/2010 - 13:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
