Voicemail Box on Analog Phone
May 24th, 2010
I have done some searching in the forum but could not find anything.
We have two folks in our warehouse that use analog phones on UC520 and I need to give them voicemail boxes.  I cannot see in CCA were it will allow me to create a voicemail box I only see the voicemail box opion under user extensions.  Can this even be done?
Steven DiStefano Mon, 05/24/2010 - 14:18
  • Blue, 1500 points or more
Yes, you have to set the FXS port as USER MODE PHONE. (it will consume a SCCP license this way, but fear not, we give you 4 extra for this).
Default may be Common Area Phone, which is not a featured setting.
CCA has this in Configuration Drawer.
kgrant3120 Mon, 05/24/2010 - 15:42
Steve,  Thank you you are gentleman and a wizard.  Another one for me to add to my tool belt.
So I got it straight I believe.  Now when I dial that extension or DID it goes to vmail instantly.  I got the foward FNA set to 20 Sec. to vmail DN I am assuming it may because the voicemail box is not not setup yet?  Once mailbox is setup it will follow the CFA rule?
Marcos Hernandez Wed, 05/26/2010 - 03:53
Actually, dialing that extension before assigning a user should just ring the extension. The voicemail is created when you assign a user in CCA to this new "phone".
Marcos
Steven DiStefano Wed, 05/26/2010 - 09:30
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";}
Ahh ... Once it becomes a user mode phone, you need to go into voice menu and configure it, and you need to initialize the voicemail with a pw and recorded name from the phone itself.  Not sure why it woul behave like you mentioned, but try this.
Related Content
