IPCC Express- Changing IP address of CallManager
Answered Question
May 24th, 2010
writing to inquire if anyone has had to change the IP address of the Call Manager with a IPCC Express 4.x server on the network? I have a customer who wants to move thier CallManager (UCM 6.1) but I am not 100 percent sure on the impact on the IPCC Express Box.
To be more clear my question is what are the area of IPCC Express that I need to change i.e. registry settings etc.
Thanks all
Correct Answer by Gergely Szabo about 6 years 8 months ago
there is a number of steps you need to perform BEFORE actually changing the IP address of the CallManager server within the IPCCX configuration.
There is a tool called CRS Serviceability Utility, you can find it in the Start menu on the IPCCX server.
Make sure you plan a maintenance window because this operation needs a CRS node restart.
Take a look at two panels, Cisco CallManager IP address and the CiscoCallManager LDAP configuration (if you use the default LDAP server, "DC Directory").
Take a look at the attached screenshot.
G.
Overall Rating: 5 (1 ratings)
Phuong Hoai Huynh Mon, 05/24/2010 - 21:08
Hi Zamora
So my understanding is that your custoer is thniking of upgrading their Call Manager to version 6.1
If this is the case then you will be forced to perform a upgrade of your IPCC box.
As per the matrix:
End of Sales IPCC Product
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crsmatrxeol.pdf
Version 4.x of IPCC Express is no compatiable with version 6.1 of CUCM.
For compatiable version please refer too:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Now the path would be to first make sure your IPCC Express is version 4.0(5)  and then run the Data Migration Tool.
Once the data file has been created, restore the information back onto a version 7.x IPCC.
Please note that you may need hardware for IPCC 7.x but refer to the guide on what you require.
zamora0800 Tue, 05/25/2010 - 10:23
Sorry Hoai I wasn't clear. The customer is already at UCM 6.1. They are wanting to change the IP address of the Call Manager. The IPCC express IP address will not change however that stays the same.
So to review
Change UCM (Call Manager) IP address - No subscribers since it's Business Edition
Leave IPCC Express IP address the same
Correct Answer
Gergely Szabo Tue, 05/25/2010 - 00:29
G.
Related Content
