Login to CME as Administrator failed
Answered Question
I have:
Router 2851
CME version 7.1
Cisco Unity Express version (7.0.5)
The config:
telephony-service
max-ephones 5
max-dn 10
ip source-address 10.10.230.1 port 2000
voicemail 3180
max-conferences 8 gain -6
web admin system name admin password lab
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Apr 14 2010 21:31:39
interface Service-Engine1/0
ip unnumbered Vlan230
service-module ip address 10.10.230.2 255.255.255.0
service-module ip default-gateway 10.10.230.1
ip route 10.10.230.2 255.255.255.255 Service-Engine1/0
ip http server
ip http authentication local
ip http path flash:
From the Cisco Unity Express Initiañization Wizard, it is neccesary to enter the Callmanager Express Login, but an error is receiver:
In the router I can´t see the GUI file
Router#sh flash:
CompactFlash directory:
File  Length   Name/status
  1   46355244  c2800nm-ipvoice_ivs-mz.124-24.T3.bin
  2   660      vlan.dat
[46356032 bytes used, 17869244 available, 64225276 total]
62720K bytes of ATA CompactFlash (Read/Write)
I have the same problem. Do you know how fix it?
Ivan Rivas
Correct Answer by testeven about 7 years 1 month ago
You can download the GUI files from this link according to the version you have:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=7.1&mdfid=277641082&sftType=Unified+Communications+Manager+Express+Complete+Support+File+Set&optPlat=&nodecount=3&edesignator=null&modelName=Cisco+Unified+Communications+Manager+Express&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&modifmdfid=null&imname=&hybrid=null&imst=null&lr=Y
1. Download appropriate tar file to tftp server. cme-basic-x.x.x.tar ? contains basic CME
system files including GUI, MoH and phoneloads
cme-gui-x.x.x.tar ? contains basic CME GUI files only
2. Logon to privileged EXEC mode of router CLI
3. Enter archive command to extract contents of tar file to router Flash memory:
Router# archive tar /xtract tftp://ip-address/filename flash:
Example 1:
To extract contents of cme-basic-3.0.3.tar from tftp server 192.168.1.1 to flash:
archive tar /xtract tftp://192.168.1.1/cme-basic-3.0.3.tar flash:
Example 2:
To extract contents of cme-gui-3.0.3.tar from tftp server 192.168.1.1 to flash:
archive tar /xtract tftp://192.168.1.1/cme-gui-3.0.3.tar flash:
This will update all the gui files in the location which the gui checks on the flash.
Tere
Overall Rating: 5 (2 ratings)
Correct Answer
testeven Tue, 05/25/2010 - 09:47
  • Cisco Employee,
Example 1:
Example 2:
Tere
Related Content
