voicemail over vpn problem
May 24th, 2010
help required
i have created a site to site & remote access vpn on my
home network to practice sending voice over encrypted
tunnels everything seems to work okay except for one
thing,the phones attached to the uc520 can ring the
phones behind the cme/cue router but if the call goes
unanswered it is not forwarded to voicemail all i get
is a fast busy signal.
basically the question is this is there any additional
configuration i need to do to the cme/cue router to allow
phones registered with the uc520 to leave voicemail on
cme/cue router.
i don't have this problem in the other direction
unanswerd calls from the phones behind the cme/cue
router to the uc520 are directed to voicemail.
regards
melvyn brown
i have included a network diagram as an attachment
below is the configuration for the complete network
3550
vlan 10
name data
vlan 100
name voice
interface range fastethernet0/1 - 4
cdp enable
power inline auto
switchport mode access
switchport access vlan 10
switchport voice vlan 100
spanning-tree portfast
interface FastEthernet0/24
switchport trunk native vlan 1
switchport mode trunk
CME/CUE ROUTER
ip dhcp excluded-address 192.168.20.1 192.168.20.5
ip dhcp excluded-address 10.1.2.1 10.1.2.5
ip route 0.0.0.0 0.0.0.0 fastethernet0/0
clock timezone GMT 0
clock summer-time GMT recurring
ntp master
ip dhcp pool VOICE
network 10.1.2.0 255.255.255.0
default-router 10.1.2.1
option 150 ip 10.1.2.1
service dhcp
ip dhcp pool DATA
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
service dhcp
interface Loopback0
ip address 100.1.1.1 255.255.255.255
interface fastethernet0/0
no shut
interface FastEthernet0/1
no shut
interface FastEthernet0/1.10
encapsulation dot1q 10
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/1.100
encapsulation dot1q 100
ip address 10.1.2.1 255.255.255.0
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
telephony-service
max-ephones 50
max-dn 50
load 7960-7940 P0030702T023
ip source-address 100.1.1.1
date-format dd-mm-yy
create cnf-files
ephone-dn 1  dual-line
number 1001
ephone-dn 2  dual-line
number 1002
ephone 1
mac-address 0014.1CAA.4E48
button 1:1
ephone 2
mac-address 001B.B9B8.8F97
button 1:2
dial-peer voice 2000 voip
destination-pattern 2...
session target ipv4:192.168.4.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
interface service-Engine 0/0
ip address 192.168.30.1 255.255.255.252
no shut
service-module ip address 192.168.30.2 255.255.255.252
service-module ip default-gateway 192.168.30.1
ip http server
ip http path flash:
ip http authentication local
telephony-service
web admin system name fred password flintstone
dn-webedit
time-webedit
dial-peer voice 1010 voip
description voicemail
destination-pattern 1010
session protocol sipv2
session target ipv4:192.168.30.2
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn 20
number #40....
mwi on
ephone-dn 21
number #41....
mwi off
ephone 1
username melvyn password brown
ephone 2
username terry password smith
EDGE ROUTER
access-list 101 permit ip 192.168.15.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 101 permit ip host 192.168.1.1 host 192.168.4.1
access-list 102 deny ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 102 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 deny ip 192.168.20.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 102 deny ip 192.168.20.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 102 deny ip host 192.168.30.2 192.168.15.0 0.0.0.255
access-list 102 deny ip 10.1.2.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 102 deny ip host 100.1.1.1 192.168.15.0 0.0.0.255
access-list 102 deny ip host 192.168.1.1 host 192.168.4.1
access-list 102 permit ip 192.168.20.0 0.0.0.255 any
access-list 103 permit ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 103 permit ip 192.168.20.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 103 permit ip host 192.168.30.2 192.168.15.0 0.0.0.255
access-list 103 permit ip 10.1.2.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 103 permit ip host 100.1.1.1 192.168.15.0 0.0.0.255
crypto ipsec transform-set BOSTON esp-3des esp-md5-hmac
crypto isakmp key cisco123 address 192.168.4.1 no-xauth
crypto isakmp enable
crypto isakmp identity address
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto map VPN 10 ipsec-isakmp
set peer 192.168.4.1
set transform-set BOSTON
match address 101
ip local pool remote-pool 192.168.15.1 192.168.15.10
aaa new-model
aaa authentication login user1 local
aaa authorization network group1 local
username barney password rubble
crypto isakmp client configuration group London
key cisco
domain cisco.com
pool remote-pool
acl 103
crypto dynamic-map dynmap 10
reverse-route
crypto map VPN client authentication list user1
crypto map VPN isakmp authorization list group1
crypto map VPN client configuration address respond
crypto map VPN 15 ipsec-isakmp dynamic dynmap
ip address 192.168.2.1 255.255.255.0
ip nat outside
crypto map VPN
no shut
interface fastethernet0/1
ip address 192.168.1.2 255.255.255.0
ip nat inside
no shut
route-map nonat permit 10
match ip address 102
ip nat inside source route-map nonat interface fastethernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 192.168.20.0 255.255.255.0 fastethernet0/1
ip route 10.1.2.0 255.255.255.0 fastethernet0/1
ip route 192.168.30.2 255.255.255.255 fastethernet0/1
ip route 100.1.1.1 255.255.255.255 fastethernet0/1
ROUTER-1
ip address 192.168.2.2 255.255.255.0
no shut
ip address 192.168.3.1 255.255.255.0
no shut
ROUTER-2
ip address 192.168.4.2 255.255.255.0
no shut
ip address 192.168.3.2 255.255.255.0
no shut
REMOTE ACCESS ROUTER
ip dhcp pool LOCAL
network 160.1.1.0 255.255.255.0
default-router 160.1.1.1
ip address 160.1.1.1 255.255.255.0
no shut
interface FastEthernet0/0
ip address 192.168.3.4 255.255.255.0
no shut
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
WEB SERVER ROUTER
ip address 150.1.1.1 255.255.255.0
no shut
ip address 192.168.3.3 255.255.255.0
no shut
UC520
after resetting back to factory default below are the
changes i made to the uc520 config
the phones and voicemail ect were configured via
the configuration assistant
no access-list 1
no access-list 104
no ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any host 192.168.4.1 eq 500
access-list 104 permit udp any host 192.168.4.1 eq 4500
access-list 104 permit esp any host 192.168.4.1
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any
access-list 106 permit ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 106 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 106 permit ip 192.168.25.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 106 permit ip host 192.168.4.1 host 192.168.1.1
access-list 107 deny ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 107 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 107 deny ip 192.168.10.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 107 deny ip 192.168.20.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 107 deny ip 10.1.1.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 107 deny ip host 10.1.10.1 192.168.25.0 0.0.0.255
access-list 107 permit ip 192.168.10.0 0.0.0.255 any
access-list 108 permit ip 192.168.10.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 108 permit ip 192.168.20.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 108 permit ip 10.1.1.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 108 permit ip host 10.1.10.1 192.168.25.0 0.0.0.255
crypto isakmp key cisco123 address 192.168.2.1 no-xauth
encryption 3des
hash md5
group 2
lifetime 86400
set peer 192.168.2.1
match address 106
ip local pool remote-pool 192.168.25.1 192.168.25.10
crypto isakmp client configuration group Birmingham
key cisco
domain cisco.com
pool remote-pool
acl 108
reverse-route
aaa new-model
username fred password flintstone
ip address 192.168.4.1 255.255.255.0
ip access-group 104 in
ip nat outside
crypto map VPN
no shut
match ip address 107
ip route 0.0.0.0 0.0.0.0 192.168.4.2
dial-peer voice 1000 voip
destination-pattern 1...
session target ipv4:192.168.1.1
codec g711ulaw
no vad
