Warning message
DHCP Snooping Problem
Answered Question
May 24th, 2010
Hi All:
I have some problems once i enable dhcp snooping on my switches.
The dhcp server is other site, connect via layer 3 link to my core switch (vss cat65)
All edge switches(cat45) are using trunk link connect to my core switch. all vlan terminates on core switch, ip helper point to dhcp server.
i only enable the dhcp snooping feature on my edge switches (cat45), trunk link put in trust mode, user port put limit rate 15.  Then no user can get ip address. if i disable dhcp snooping, everything back to normal.
the command i have used.
ip dhcp snooping
ip dhcp snooping vlan [user vlan id]
interface gi 1/1 [uplink]
switch mode trunk
ip dhcp snooping trust
interface 2/1 [user port]
swi mode access
swi access vlan [user vlan id]
ip dhcp snooping limit rate 15
i thought the dhcp snooping feature is localized. no need to enable end-to-end.
thanks for your help in advance.
Correct Answer by Giuseppe Larosa about 7 years 2 months ago
Hello Jason,
you may need to add a command in order to make DHCP relay function to work correctly
see
>> If you are enabling trunking on uplink gigabit  interfaces, and the above routing configuration is defined on a  Catalyst 6500 series switch, you must configure the "trust" relationship  with downstream DHCP Snooping (on a Catalyst 4500 series switch) which  adds Option 82. On a Catalyst 6500 series switch, this task is  accomplished with ip dhcp relay information trusted VLAN  configuration command.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/dhcp.html#wp1073418
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 05/25/2010 - 02:05
  • Hall of Fame,
    Founding Member
Hello Jason,
see
Hope to help
Giuseppe
