NPIV enabling on MDS9513's
May 24th, 2010
Our AIX team wants to enable NPIV on both our Cisco MDS9513 directors to take advantage of there new VIOS servers.  I couldn't find any documents relating to the minimum firware requirements on the switches that support NPIV.  Does anyone know if there is a firmware minimum to support NPIV?
To enable NPIV issue these commands:
config t
npiv enable
Final question there are a lot of post on NPV and NPIV, just so I'm clear you don't need NPV enabled to use NPIV?
Thanks for any assistance.
calopez2 Tue, 05/25/2010 - 05:10
  • Cisco Employee,
MDS 9513 supports NPIV.
NPV is NOT required to enable NPIV feature.
I hope this has helped you.
Carlos
Valley911 Tue, 05/25/2010 - 08:22
My aplogizes for high jacking this thread, but I have similiar question...
We are currently using 2 MDS 9124's for our core SAN switches (A and B path). We would like to utilize NPIV on our ESX hosts/VM's. From the reading I have done we should just be able to enable NPIV via Device Manager per each switch. I would just like to confirm that this will not have any impact on the switch, ie needing a reboot etc...
Thanks in advance,
-Jason
dynamoxxx Thu, 05/27/2010 - 21:52
  • Silver, 250 points or more
no impact at all ..
rick.blankenshi... Thu, 06/03/2010 - 13:30
I'm using MDS 9513 with OS Release 4.1(1b). I do not see the command to enable NPIV with this version. Is NPIV already enabled?
Rick
dynamoxxx Sat, 06/05/2010 - 06:19
run "show feature" to see if NPIV is enabled.  If it's not you can run "feature npiv" to enable it.
rick.blankenshi... Mon, 06/07/2010 - 06:23
The command "show feature" is not valid on this release. I think that I will open a case with support and will post the solution once it is resolved.
rick.blankenshi... Thu, 06/10/2010 - 06:36
I looked in the running config to see if npiv was enabled which it wasn't.
show running config | inc npiv
To enable npiv run "feature npiv" in config mode.
To disable npiv run "no feature npiv" in config mode.
bfeeny Thu, 06/10/2010 - 18:14
You can enable npiv with no worries, it won't effect production.  It just allows the initiators to request multiple FCID's.
keystonecruiser1 Wed, 06/16/2010 - 15:08
I enabled npiv, and no impact to anything.  Actually much smoother than I expected.  Our AIX team is using the pvid feature and they are loving it.
c.walsh Fri, 02/24/2012 - 01:49
     What version of SAN-OS are you using on the 9513?
Colin
Related Content
Trending Topics: Storage Networking
