LMS 3.2 on VMWare ESxi 4.0
Michel Hegeraat Tue, 05/25/2010 - 00:07
Should work fine. OS is OK. ESXi 4.0 is OK.
Did all ciscoworks  services start?
If ciscoworks deamon manager is started try to run a pdshow and post the results here
Attached is pdshow.
I have encountered this problem before and it was suspected that the cwportal is corrupted. It was resolved when I deleted the files beginning in *portal in NMSROOT/MDC/tomcat/webapps/cwportal/db and then replaced it with the files from NMSROOT/MDC/tomcat/webapps/cwportal/db/orig folder. I tried doing this procedure again but it didnt work. I can only see a blank page after logging in the webgui.
Michel Hegeraat Tue, 05/25/2010 - 01:05
You should not do that like that.
There is a dbRestoreOrig.pl  script you should use for that.
So there are not warnings or errors during install?
Your processes look ok
if the portal is not working try another know url e.g.  :1741/cwhp/device.center.do">http://:1741/cwhp/device.center.do   should give the device center
You may wish to try the portal restore script   RestorePortal.pl
Related Content
