Upgrading 6506E IOS
May 25th, 2010
I have upgraded IOS for 6506E Switch to AdvancedEnterprise edition. The IOS is located in CF memory(disk0:) but the problem is when the switch reboot, it did not boot IOS from the disk0 although I enterd the command below already:
boot system disk0:s720xx-advipservxxxxxxxxxxxxxxxx.bin
After backing up the origin IOS(in sup-bootflash) to TFTP server, I deleted it. By now, when the switch reload, it always go in rommon mode and I have to enter "boot" command manually.
Please show me the way to make the IOS in disk0: will be automatically booted in restart process.
Thank you very much !
Nguyen Huy Hung
Giuseppe Larosa Tue, 05/25/2010 - 02:06
  • Hall of Fame,
    Founding Member
Hello Hung,
post sh ver
and
sh bootvar
Hope to help
Giuseppe
nguyenhuyhung84 Tue, 05/25/2010 - 02:11
Dear giuslar,
This is the show command result:
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF1, R
E (fc1)
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF1, R
E (fc1)
cisco WS-C6506-E (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID SAL1003AFNK
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
Bridging software.
65 Virtual Ethernet/IEEE 802.3 interfaces
74 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
This is the show bootvar result:
BOOT variable = disk0:s72033-advipservicesk9_wan-mz.122-18.SXF1.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable =
Thank you.
