WAAS in VRF\MPLS Environment
May 25th, 2010
I need to deploy waas  WAE7371 in VRF/MPLS environment. I have 2 sites, each one have 6500 router as  a CE\PE with multiple vrf. the wan interface is mpls enabled.
i need to deploy the WAE-7371 in only one VRF, let say VRF  netapp which is bounded to interface vlan x. i will create another L3 interface vlan with defferent subnet and bound it to vrf netapp (for the WAE).
because  wccp protocol is not vrf\mpls aware, can i configure IP wccp 61  redirect in & IP wccp 62 redirect out on the interface vlan x  and get the same results?
attached diagram for the deployment.
thanks,
Zach Seils Tue, 05/25/2010 - 07:31
  • Cisco Employee,
Avi,
Outbound redirection is not recommended on the Catalyst 6500 platform, since a portion of the processing occurs in software.
Is it possible to deploy the WAEs physically inline (requires the inline module) between the L2 switches and CE/PE switches?
Zach
Avi Yoshi Tue, 05/25/2010 - 07:35
not quite since the netapps are sitting directly on the CE\PE.
i know i can do it with vlan crossing but i cannot change the current configuration.
have another idea ?
Zach Seils Tue, 05/25/2010 - 08:12
  • Cisco Employee,
The diagram you provided shows the NetApp devices physically connected to the L2 switches.  Is that not the case?
Zach
Avi Yoshi Tue, 05/25/2010 - 10:41
correct.
but from the customer point of view he don't want to change the current design.
what could be the impact of using the "redirect out" although it is software based ?, can it crashes the C6K ?
Zach Seils Wed, 05/26/2010 - 05:49
  • Cisco Employee,
It won't crash the 6k, per se, but the elevated CPU utilization could cause severe performance issues that would affect other services.
Zach
