Giuseppe Larosa Tue, 05/25/2010 - 05:07
Hello Manuadoor,
it is a way (the old way) to advertise an aggregate address, the static to null0 allows to use under BGP a network command to advertise the prefix.
the modern way to do this is to use the aggregate-address command under BGP process
example:
ip route 196.196.0.0 255.255.252.0 null0
router bgp myASN
network 196.196.0.0 mask 255.255.252.0
it is also used for stability instead of relying on component routes learned by an IGP like OSPF if the objective is to advertise a block of IP addresses the static to null0 allows to use the corresponding network command to advertise the aggregate
modern way
router bgp myASN
network 196.196.1.0 mask 255.255.255.0
aggregate-address 196.196.0.0 255.255.252.0 summary-only
Hope to help
Giuseppe
Mohamed Sobair Tue, 05/25/2010 - 05:45
The static route to null 0 is needed to advertise networks into BGP,
BGP would advertise Networks using any of the bellow methods:
1- with the Network command set.
2- Redistribution into BGP.
3- Aggregate address command.
All of these methods needs an exact match in the routing table , except for the aggregation which needs at least one route part of the aggregate address exist.
However, the bellow example written by Guiseppe doesnt need the (network command under bgp) as long as the aggregate address along with one part of the aggregate address exist in the IP routing table.
modern way
router bgp myASN
aggregate-address 196.196.0.0 255.255.252.0 summary-only ))))
manuadoor Tue, 05/25/2010 - 06:08
You mean to say,, whenever we advertise some routes to BGP it should be pointed to a null0 interface..!! Cannot digest
Most of the time I have seen that the null0 route is for a /22 network, why it is so?
Giuseppe Larosa Tue, 05/25/2010 - 07:42
Hello Mohamed,
I wrote the example in this way for clarity it is easier to compare the two methods in this way
a) ip route to null0 + network command for the aggregate route
b) aggregate-address + network command for component routes (at least one) or other way to inject a component route in BGP table (for example redistribution or route learned by another BGP peer)
it is a way to create an aggregate = a summary route
Hope to help
Giuseppe
Mohamed Sobair Tue, 05/25/2010 - 06:18
No, what I meant is that you might not have the Network advertised by BGP in the routing table as static or connected, so you might need to advertis them using Nul0 static into BGP.  Now regarding the /22, this doesnt have to be , it could be any subnet redistributed into bgp without specifically saying /22.
Mohamed
manuadoor Tue, 05/25/2010 - 06:26
ok...
1. Even if the IGP route is down, because of this null route, the traffic will reach this router(I read that null0 is having the least preference), so that trouble shooting also will be easier, right??
2. I think we can use null0 for privisioning also..right?
3. I clarrified with some of my collegue they are using /22 because there is a HUB router having 3 spokes, so they summerise the spokes with /22
Related Content
