05-25-2010 05:28 AM - edited 03-15-2019 10:55 PM
if i am using VWIC2-2MFT-T1/E1 cards still we need WIC-2t card for serial connectivity or else VWIC2-2MFT-T1/E1 support both data & Voice in CISCO2851-CCME/K9.
05-25-2010 05:37 AM
If I understand the question correctly, the answer is that the VWIC2-2MFT-T1/E1 is a voice only card. Therefore, you would need the wic-2t or similar card for WAN/carrier connectivity.
HTH.
Bill
Please remember to rate helpful posts using the scale below.
05-25-2010 07:29 AM
Mohammad,
My apologies. A colleague informed me that I was a dumb *** ;-) I neglected to pay close enough attention to the question. Actually, you can mix voice and data applications. Depends on what is on the other end. Here is a Q&A link:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8028d2e5.html
HTH.
Bill
