Roaming WAP2000 and WRVS4400N
May 25th, 2010
I have 4 WAP2000 and a WRVS4400N and I'm trying to create a roaming wifi network but I seems to loose the connection for a short time when changing AP, am I missing something??
I have set up the WRVS4400N to handles DHCP and the internet connection (WAN port). The LAN port is connected to a Dell PowerConnect 3024 switch to increase the number of ports available, so everything else is connected here. I have configured port 1-8 to be fastlink ports (Should disable STP on the ports), and all the WAP devices and the WRVS4400N are connected to these ports.
All SSIDs and security settings are the same (different channels).
