First Level Password
Answered Question
May 25th, 2010
We are running IOS 8.2(2) on the ASA 5510.  Is there a first level password?  If there is, is there a way to find out what the first level password is?
Thanks.
Laura
Correct Answer by hdashnau about 6 years 11 months ago
Laura,
You can set passwords for telnet, ssh, console etc through the use of the "aaa authentication" commands. If you have these commands in your config, then you are requiring authentication. You can read more about this here:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgaccess.html#wp1042026
On top of this, you can also set an enable password to require passwords before allowing them into enable nmode of the ASA. This password is configured with "enable password"
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/ef.html#wp1922477
If you are being prompted for a password but do not know the password, you probably need to perform password recovery:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1049302
-heather
Overall Rating: 5 (1 ratings)
Correct Answer
hdashnau Tue, 05/25/2010 - 11:25
  • Cisco Employee,
Laura,
-heather
hdashnau Tue, 05/25/2010 - 16:12
  • Cisco Employee,
P.S. If I have answered your question please mark the post as resolved  and rate the responses. This helps us more easily identify which  questions remain unanswered and let us know how we are doing. Thanks in  advance!
