block internet access for remote access vpn users
May 25th, 2010
Currently we are allowing remote access vpn users access to the Internet, our setup is as follows:
group-policy VPN attributes
dns-server value
vpn-filter none
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
access-list split standard permit
We need to change this setup such that remote access vpn users can still access the internal network ( but NOT allow them Internet access, in other words everything should remain the same but we need Internet blocked.
what do we need to change on the group-policy?
Marcin Latosiewicz Tue, 05/25/2010 - 10:10
1. You need to change this:
to tunnel all traffic.
2. Apply vpn-filter option.
However in this case all traffic request for internet will go (and be dropped) by the ASA.
ronicisco770 Tue, 05/25/2010 - 10:28
You mean the following:
split-tunnel-policy tunnelall
vpn-filter none
what is the purpose of hte vpn-filter?
Do i need to specify a vpn-filter to block internet and allow internal access?
Marcin Latosiewicz Tue, 05/25/2010 - 10:44
Long story short.
You can drop traffic via ACL with vpn-filter.
You can make sure that traffic will not make a u-turn on the outside interface of ASA. (you need a seme-security-traffic permi intra-interface to allow u-turn)
If you need same-security command for some reason - you can remove NAT from outside-to-outside.
Paste more of the config - we'll be able to say more
