Route Summarization
Answered Question
May 25th, 2010
All, we've created the following internal networks and want to ensure that we correctly advertise with route summarization accordingly. What should the correct summarized route statement look like?
Subnets
30 /24bit user data/voip networks 10.122.[1-30].0 /24
20 /26bit server/printer/data networks 10.122.[31-40].0 .64.128.192 /26
15 /27bit networks 10.122.[41-45].0 .32.64.96.128.160.192.224 /27
Any help would be appreciated
Correct Answer by Jon Marshall about 7 years 4 days ago
Subnets
You can't summarise in one statement unless you want to include more networks than you have ie.
10.122.0.0 255.255.192.0    would summarise  10.122.0.0 -> 10.122.63.0
If you only want to summarise the actual networks you have  -
10.122.0.0 255.255.224.0  =  10.122.0.0 -> 10.122.31.0
10.122.32.0 255.255.248.0  =  10.122.32.0 -> 10.122.39.0
10.122.40.0 255.255.252.0 =   10.122.40.0  -> 10.122.43.0
10.122.44.0 255.255.254.0  =  10.122.44.0 -> 10.122.45.0
note the last 4 entries above could be replaced by
10.122.32.0 255.255.240.0  but this would include a few extra networks at the end because it works out as  10.122.32.0 -> 10.122.47.0
Jon
Correct Answer by Ganesh Hariharan about 7 years 4 days ago
Subnets
Check out the below link for example on route summarization with step by step procedure to summarize a network to advertise.
http://www.ciscopress.com/articles/article.asp?p=174107&seqNum=3
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (2 ratings)
Correct Answer
Ganesh Hariharan Tue, 05/25/2010 - 09:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Subnets
Hope to Help !!
Ganesh.H
Correct Answer
Jon Marshall Tue, 05/25/2010 - 09:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Subnets
Jon
