May 25th, 2010
Last year we migrated from a 4.1(3) CallManager to a new CUCM 7.1.3 appliance.  We recently discovered a few 7942G phones still boxed with the 1 RTU license (Part# CP-7942G-CH1).
Is there any way to use the RTU license on the new CUCM server? ie: convert the RTU to DLUs?
Also, going forward if/when we order new phones, I assume we should be ordering phones without RTU's and buying DLU's as needed?
Overall Rating: 5 (2 ratings)
rob.huffman Tue, 05/25/2010 - 10:50
Hey Rob,
Hope all is well!
You might be able to contact;
[email protected]
with your pertinant contact/billing/order info and have them re-issue
the appropriate DLU's for the 7942's. It's worth a try
Going forward the licensing model will be DLU's for 5.x,6.x and early
7.x versions and with 7.1(5) and 8.x Cisco are introducing a new licensing model
called User  Connect Licensing. This does away with the existing node/DLU  licensing model
and moves to a user based model.
Just to confuse things a little further
rcoote5902_2 Tue, 05/25/2010 - 12:13
Things are well Rob!
I can't find where I had read it, but I recall that phones without the RTU were cheaper to compensate for the new licensing (DLU) system.  It seems it would make more sense for us to order phones with no licenses and just add DLU's as needed...does that make sense?
Are phones without RTU's available or am I mistaken?
