WLC 4402 - Can't ping between devices
May 25th, 2010
I have a laptop connected to SSID1 and another to SSID2. Each can ping each other without a problem, but neither can ping a device on the SSID3 network. From a hard line (in this case off of one of the servers) I can ping the device on the SSID3 network without a problem.
There are no ACLs applied on the WLC or core switch where the VLANs are implemented.
Is there a setting somewhere on the SSID3 interface that could be blocking traffic?
We are running code 6.0.188.  All APs are 1242AG.
Thanks in advance for your help.
dancampb Wed, 05/26/2010 - 07:44
  • Cisco Employee,
Do you have P2P Blocking enabled on the WLAN?  Or maybe an ACL on the default gateway between the two VLANs?
voipis4me Wed, 05/26/2010 - 09:24
P2P blocking is disabled.
Turns out that the issue is with the clients and not the network.
Related Content
Trending Topics - Security & Network
