udp broadcast across vlans
Jon Marshall Tue, 05/25/2010 - 17:20
[email protected]
I have entered ip forward-protocol udp 43968 on both core (6905) but still doesn't work. Am I missing anything here? Thanks
If you want to forward udp broadcasts at L3 you need to do 3 things -
1) configure an ip helper-address to point to the remote subnet broadcast address
2) configure the ip forward-protocol command
3) configure "ip directed-broadcast" on the receiving vlan interface
so as an example, vlan 10 is the source of UDP broadcasts and vlan 11 is the vlan receiving the udp broadcast. vlan 11 subnet is 192.168.5.0/24
int vlan 10
ip helper-address 192.168.5.255
int vlan 11
Jon
