how i can see memory amount of AP lightweight
Answered Question
May 25th, 2010
in the network, i have a WLC 2112 and two access point lightweight, i need know how much flash an nvram have the access points?
you know what command i set in the WLC for know how much flash an ram have the access point and the Wireless Lan Controller??
thanks
Correct Answer by Leo Laohoo about 6 years 11 months ago
You have two options:  You can run debug command and/or enable Telnet/SSH.
To enable debug command on the WLC, run the following commands:
1.  debug ap enable ;
2.  debug ap command "dir" ; (you can also use "sh flash:")
When you are finish or satisfied with the result, disable the debug command.
3.  debug ap disable
To enable Telnet/SSH
Depending on the version of your WLC you do this via GUI or CLI.  The CLI command on the WLC is:  config ap [telnet/ssh] enable
Please don't forget to rate useful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Tue, 05/25/2010 - 15:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
3.  debug ap disable
Leo Laohoo Thu, 05/27/2010 - 15:45
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
