NIC teaming on Call Manager 7.1.5
May 25th, 2010
Is there any way to NIC teaming on Call Manager 7.x. I had read somewhere it is possible. If anyone know how to or point me to a guide will be helpful.
Thanks...
Overall Rating: 4.9 (6 ratings)
Rob Huffman Tue, 05/25/2010 - 12:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rohan,
"NIC Teaming for Network Fault Tolerance
The NIC teaming feature allows a  server to be connected to the Ethernet via two NICs and, therefore, two  cables. NIC teaming prevents network downtime by transferring the  workload from the failed port to the working port. NIC teaming cannot be  used for load balancing or increasing the interface speed.
Hewlett-Packard  server platforms with dual Ethernet network interface cards can support  NIC teaming for Network Fault Tolerance with Cisco Unified CM 5.0(1) or  later releases.
IBM server platforms with dual Ethernet network interface  cards can support NIC teaming for Network Fault Tolerance with Cisco  Unified CM 6.1(2) and later releases. "
And the command to do that as per  the CUCM OS CLI Reference Guide is:
"set network failover
This  command enables and disables Network Fault Tolerance on the Media  Convergence Server network interface card.
Command Syntax
failover  {enable | disable}
Parameters
enable enables Network Fault Tolerance.
disable  disables Network Fault Tolerance.
Requirements
Command privilege level: 1
Allowed  during upgrade: No "
The referenced guides:
SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043624
CLI Ref
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp40017
Cheers!
Rob
David Hailey Tue, 05/25/2010 - 12:04
  • Purple, 4500 points or more
Yes, you can.  It's NIC teaming but only for failover.  From the CLI, issue "set network failover enable".
Hailey
Please rate helpful posts!
Jaime Valencia Tue, 05/25/2010 - 12:06
  • Cisco Employee,
  • Hall of Fame,
    2011
Command Syntax
Parameters
Requirements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp40017
EDIT: You beat my searching skills guys
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Aaron Harrison Wed, 06/16/2010 - 11:05
  • Community Spotlight Award,
    Member's Choice, May 2015
No - the licensing system is clever enough to just take the first NIC physical MAC rather than the virtual team MAC. So nothing changes.
Aaron
Please rate helpful posts..
bijoyjackjesse Fri, 03/01/2013 - 22:04
Guys,
I have a issue with the NIC teaming..
Fault tolerance is configured in my cucm.
I'd like to set the Speed and Duplex from the CM's End..
iI've added the Show network failover
admin:show network failover
eth0 has been overridden by Network Fault Tolerance.
To view the Ethernet port configuration, please use following command:
Bond 0
DHCP         : disabled           Status     : up
IP Address   : 138.241.118.34     IP Mask    : 255.255.255.224
Link Detected: yes                Mode       : Auto disabled, full, 100MB/s
Ethernet 0
IP Address   :                    IP Mask    :
Link Detected: yes                Mode       : Auto enabled, Half, 100MB/s
Ethernet 1
DNS
Primary      :                    Secondary  :
Options      : timeout:5 attempts:2
Domain       : localdomain
Gateway      : 138.241.118.33 on Ethernet bond0
Now i need eth0 to be set to Full dupled and speed 100MB/s
would using the command #set network nic eth0 speed/duplex  solve my issue...
Any help highly appreciated...
Thank you guys
