band select white paper, technical doc?
May 25th, 2010
Hi all,
I've found a few info on how to configure the bandselect feature, I think I have an idea how it would work, but I was looking for some literature/documentation that would explain how does BandSelect work with some detail?
Can anybody point to some documentation? Config guides, etc, I've already brwsed through but they just say how to configure and what it achieves. It doesn't specify how does it get clients to be steered to the 5GHz band.
Gustavo
Leo Laohoo Tue, 05/25/2010 - 15:14
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Evaluating Key Architectural and Operational WLAN Strategies in the Era of 802.11n
www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/farpoin...
Don't forget to rate useful posts.  Thanks.
Gustavo Novais Thu, 05/27/2010 - 00:53
Hello, thanks for your prompt reply.
Unfortunately, I had found this document and it explains the purpose of the feature (that we all now by now) but it doesn't explain how do they achieve that.
My consideration is mostly the technology itself. Does it change beacons/probe replies in any way? How does it influence a client? Is it anything similar to AP load balancing of clients?
anyway I think I'll have to spend a bit of time labbing it up.
Gustavo
George Stefanick Thu, 05/27/2010 - 19:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
There is little info on this ... I do know the controller steers clients by ignoring the probe request from clients.. So if a client has a and g enabled, the controller detects a strong signal with a and will ignore the g probes... steering it to a...
Gustavo Novais Fri, 05/28/2010 - 01:18
Hi George,
That's pretty much what I also could gather.
Thanks for replying.
Gustavo
George Stefanick Fri, 05/28/2010 - 07:57
btw ... Ap load balancing doesnt work only because some clients ignore reason code 17 ...
Mazzola68 Thu, 06/03/2010 - 02:41
Hi George
what is a reason code 17 ?
Thanks in advance
Gustavo Novais Thu, 06/03/2010 - 03:00
Hi, status code 17 is actually the reason (status code) an AP can give to reject an association request.
If you check table 7-23 on 802.11-2007 document
Association denied because AP is unable to handle additional associated STAs.
When a client tries to associate, the AP can refuse its association request (a few times), hoping that the client will choose another AP to associate to.
Usually they would do that after they have reached a capacity threshold that was admin configured. Obviously they will not not refuse EVERY association request (after the third one, they'll let the client in), or else they'd be denying service.
Gustavo
Mazzola68 Thu, 06/03/2010 - 03:09
Thanks Gustavo
Where I can found other information about  check table 7-23 on 802.11-2007 document ?
Thanks.
Trending Topics - Security & Network
