Transcoding question
May 25th, 2010
   I have a remote site with a T1 connection back to the main site. We decided to use G729 for the phones. All of our other sites are G711. I configured 2 HW transcoder resources on 2821 routers. I tested each transcoder individually and they both do the job. My question is, why am I exhausting the MRGL when I max out one of the transcoders?
My MRGL contain 5 MRG, each MRG has both transcoders. I expected that having 2 xcoders in one MRG would be fine, is this wrong? Should I have a different xcoder in each MRG?
gogasca Tue, 05/25/2010 - 21:24
Which devices and codecs are you transcoding?
Are you using xcodes for IP Phones?
Remember that they do support G729 also, maybe you can give us more detail
If you change order of xcoders (You need to add them to one MRG each one) anything changes?
Both transcoders same Device Pool or region?
