Unity Connection Clustering across WAN
Answered Question
Hi all,
I am looking into deploying a Unity Connection cluster with the Publisher in Ca and the Subscriber in Tx. The Ca location and the Tx location are connected over a full 45MB DS3 connection and the round-trip latency is about under 40ms. There will be 48 voice mail ports total on each server.
I am trying to find out the minimum bandwidth requirement for replication and intra-cluster communication traffic between the Pub and Sub.
Has anyone deploy anything like this for Unity Connection ? Is this a supported deployment ? I appreciate any inputs / suggestions !!!! Thanks in advance !!!
D.
Correct Answer by William Bell about 6 years 7 months ago
When Unity Connectio
n cluster servers are deployed in separate buildings, the following requirements/best practices apply:
  • Bandwidth
    • 50 Mbps for 48 voice messaging ports on each server
    • 100 Mbps for 86 voice messaging ports on each server
    • 150 Mbps for 144 voice messaging ports on each server
  • Latency of 20ms or less RTT
Available here:  http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/requirements/7xcucsysreqs.html#wp151620
HTH.
Bill
Please remember to rate helpful posts.
Overall Rating: 5 (4 ratings)
Correct Answer
William Bell Tue, 05/25/2010 - 21:55
  • Bandwidth
HTH.
Bill
