David Hailey Wed, 05/26/2010 - 06:50
  • Purple, 4500 points or more
Could potentially be a memory leak - there were similar CUCM bugs in the early revs of 7.0 as well.  If the disk utilization is running too high, the only immediate recourse is to reboot the server.
Hailey
Please rate helpful posts!
Zaid Ahmaad Ibr... Wed, 05/26/2010 - 07:30
Thank you for your reply Mr. Hailey,
But the server is working perfect and users are not complaining at all knowing that there are more thabn 500 CUPC users in my organization.
I can schedule a download this is not a prblem.
Zaid,
David Hailey Wed, 05/26/2010 - 07:45
A memory leak can go undetected without your users being aware until the CPU or HDD utilization is pegged at 100% and becomes unresponsive or crashes.  So, you should use RTMT to monitor the CPU and disk utilization.  If it comes within normal ranges, then you're OK.  But if it continues to run super hot, you may want to reboot.
Just a note from experience.
Hailey
htluo Wed, 05/26/2010 - 09:31
  • Red, 2250 points or more
High percentage on "active" and "inactive" partition is normal.  Default alert threshold was 97%.  "active" and "inactive" partition are used to store binary codes.  Technically speaking, the percentage shouldn't change after install.
Memory leak will not change the hard dirve usage on "active" and "inactive" partition.  When there's a memory leak, the system will try to use "virtual memory", which is the swap file on hard drive.  The swap file is neither in "active", nor in "inactive" partition.
Michael
http://htluo.blogspot.com
