problem with MS IAS and 1140 wireless access point
I am facing problem to authenticate from wireless with MS IAS radius. error i am getting is
ser raj@rds.com was denied access.
Fully-Qualified-User-Name = rds.com/Users/raj
NAS-IP-Address = 10.1.2.92
NAS-Identifier = ap
Called-Station-Identifier = ec44.76b8.93e0
Calling-Station-Identifier = 0021.0063.fb97
Client-Friendly-Name = 10.1.2.92
Client-IP-Address = 10.1.2.92
NAS-Port-Type = Wireless - IEEE 802.11
NAS-Port = 292
Proxy-Policy-Name = Wifi-Windows
Authentication-Provider = Windows
Authentication-Server = <undetermined>
Policy-Name = WIFI
Authentication-Type = PEAP
EAP-Type = <undetermined>
Reason-Code = 16
Reason = Authentication was not successful because an unknown user name or incorrect password was used.
so please anybody help me to solve this problem.  I am not using WLC i am using standalone 1140 access point.
regards,
6 Replies 6
Jatin Katyal
I'm sure you are using the correct user name and password but the IAS is saying that the password and user name is not correct. The next reason could be that you have shared sceret mis-match on the IAS and stand alone AP.
Could you please manually retype the shared secret key on both the sides and try again. If that doesn't work please attach the "debug radius"  and debug aaa authentication" from the access-point
JK
Do rate helpful posts-
~Jatin
Dear Katyal,
         Please check the attached debug of access point.  I was assigned shared key on both access point and radius server.  I want toknow that is their any certificate i have to install on access point. how i can generate certificate on 1140 access point.
please update me.
*Mar  8 03:25:13.709: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 0021.0063.fb97 Reason: Sending station has left the BSS
*Mar  8 03:25:14.371: AAA/BIND(00000067): Bind i/f
*Mar  8 03:25:23.985: AAA/AUTHEN/PPP (00000067): Pick method list 'eap_methods2'
*Mar  8 03:25:23.986: RADIUS/ENCODE(00000067):Orig. component type = DOT11
*Mar  8 03:25:23.986: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:23.986: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:23.986: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:23.986: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:23.986: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:23.986: RADIUS:   33                                               [3]
*Mar  8 03:25:2raj@rds.com"
*Mar  8 03:25:23.987: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:23.987: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"3.986: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:23.986: RADIUS/ENCODE(00000067): acct_session_id: 103
*Mar  8 03:25:23.986: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:23.986: RADIUS(00000067): sending
*Mar  8 03:25:23.987: RADIUS(00000067): Send Access-Request to 10.1.10.244:1645 id 1645/70, len 140
*Mar  8 03:25:23.987: RADIUS:  authenticator 1E 97 EB 8D 68 D8 41 71 - 3A F6 CF 3E 1D A8 49 49
*Mar  8 03:25:23.987: RADIUS:  User-Name           [1]   13  "
*Mar  8 03:25:23.987: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:23.987: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:23.987: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:23.987: RADIUS:   68 C0 96 C3 CE EA 60 0B D7 3F 3A 30 23 11 03 4F  [h?????`???:0#??O]
*Mar  8 03:25:23.987: RADIUS:  EAP-Message         [79]  18
*Mar  8 03:25:23.987: RADIUS:   02 02 00 10 01 72 61 6A 40 72 64 73 2E 63 6F 6D  [?????raj@rds.com]
*Mar  8 03:25:23.987: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:23.987: RADIUS:  NAS-Port            [5]   6   355
*Mar  8 03:25:23.988: RADIUS:  NAS-Port-Id         [87]  5   "355"
*Mar  8 03:25:23.988: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:23.988: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:23.991: RADIUS: Received from id 1645/70 10.1.10.244:1645, Access-Challenge, len 77
*Mar  8 03:25:23.991: RADIUS:  authenticator 13 83 C6 3D 13 B6 99 90 - 92 7C 54 33 53 3E 9A DF
*Mar  8 03:25:23.991: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:25:23.991: RADIUS:  EAP-Message         [79]  8
*Mar  8 03:25:23.992: RADIUS:   01 03 00 06 19 20                                [????? ]
*Mar  8 03:25:23.992: RADIUS:  State               [24]  25
*Mar  8 03:25:23.992: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:23.992: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:23.992: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:23.992: RADIUS:   D6 78 5B 4E 35 46 E8 DE FB 5F DD 6F 03 62 E4 AB  [?x[N5F???_?o?b??]
*Mar  8 03:25:23.992: RADIUS(00000067): Received from id 1645/70
*Mar  8 03:25:23.992: RADIUS/DECODE: EAP-Message fragments, 6, total 6 bytes
*Mar  8 03:25:24.001: AAA/AUTHEN/PPP (00000067): Pick method list 'eap_methods2'
*Mar  8 03:25:24.002: RADIUS/ENCODE(00000067):Orig. component type = DOT11
*Mar  8 03:25:24.002: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:24.002: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:24.002: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:24.002: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:24.002: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:24.002: RADIUS:   33                                               [3]
*Mar  8 03:25:24.002: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:24.002: RADIUS/ENCODE(00000067): acct_session_id: 103
*Mar  8 03:25:24.002: RADIUS(00000067): sending
*Mar  8 03:25:24.003: RADIUS(00000067): Send Access-Request to 10.1.10.244:1645 id 1645/71, len 269
*Mar  8 03:25:24.003: RADIUS:  authenticator BB 97 68 F3 1C D5 24 46 - DF 4B D9 CE B2 8A FE B6
*Mar  8 03:25:24.003: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:25:24.003: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:24.003: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:25:24.003: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:24.003: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:24.003: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:24.003: RADIUS:   B7 C5 70 13 62 FA 2B 0D 47 BD 8A E8 B7 A4 7C C8  [??p?b?+?G?????|?]
*Mar  8 03:25:24.003: RADIUS:  EAP-Message         [79]  122
*Mar  8 03:25:24.003: RADIUS:   02 03 00 78 19 80 00 00 00 6E 16 03 01 00 69 01  [???x?????n????i?]
*Mar  8 03:25:24.004: RADIUS:   00 00 65 03 01 4C 03 B2 1D 9D 53 AD 7A 15 BA 3D  [??e??L????S?z??=]
*Mar  8 03:25:24.004: RADIUS:   6B FE 7B 65 74 E6 C4 7B FB D6 45 98 92 D2 0C 6E  [k?{et??{??E????n]
*Mar  8 03:25:24.004: RADIUS:   1D E1 02 D4 45 00 00 18 00 2F 00 35 00 05 00 0A  [????E????/?5????]
*Mar  8 03:25:24.004: RADIUS:   C0 13 C0 14 C0 09 C0 0A 00 32 00 38 00 13 00 04  [?????????2?8????]
*Mar  8 03:25:24.004: RADIUS:   01 00 00 24 00 00 00 10 00 0E 00 00 0B 72 61 6A  [???$?????????raj]
*Mar  8 03:25:24.004: RADIUS:   40 72 64 73 2E 63 6F 6D 00 0A 00 06 00 04 00 17  [@rds.com????????]
*Mar  8 03:25:24.004: RADIUS:   00 18 00 0B 00 02 01 00                          [????????]
*Mar  8 03:25:24.004: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:24.004: RADIUS:  NAS-Port            [5]   6   355
*Mar  8 03:25:24.004: RADIUS:  NAS-Port-Id         [87]  5   "355"
*Mar  8 03:25:24.004: RADIUS:  State               [24]  25
*Mar  8 03:25:24.004: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.005: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.005: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:24.005: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:24.006: RADIUS: Received from id 1645/71 10.1.10.244:1645, Access-Challenge, len 1477
*Mar  8 03:25:24.006: RADIUS:  authenticator D4 71 2A 35 8C AF 7D 5B - 9D D8 E0 7A 3C 57 44 3E
*Mar  8 03:25:24.006: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:25:24.007: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.007: RADIUS:   01 04 05 74 19 C0 00 00 0E F5 16 03 01 0E F0 02  [???t????????????]
*Mar  8 03:25:24.007: RADIUS:   00 00 46 03 01 4C 03 B1 A4 BE 0B 33 51 D1 4A 67  [??F??L?????3Q?Jg]
*Mar  8 03:25:24.007: RADIUS:   10 C4 24 49 CD 91 25 CD 2E B8 14 2A A7 30 6C 39  [??$I????.??*?0l9]
*Mar  8 03:25:24.007: RADIUS:   B6 A2 B2 F2 65 20 5A 19 00 00 1E 69 5E 78 DF A3  [????e Z????i^x??]
*Mar  8 03:25:24.007: RADIUS:   56 1C 85 C0 D5 CD DD 02 1C 4A 7D BB BA 41 53 63  [V????????J}??ASc]
*Mar  8 03:25:24.007: RADIUS:   1A BE 70 CA E7 0F 00 04 00 0B 00 01 FF 00 01 FC  [??p?????????????]
*Mar  8 03:25:24.007: RADIUS:   00 01 F9 30 82 01 F5 30 82 01 5E A0 03 02 01 02  [???0???0??^?????]
*Mar  8 03:25:24.007: RADIUS:   02 10 C5 A7 73 6E B3 6E 02 8B 41 1A 33 1C 83 A1  [????sn?n??A?3???]
*Mar  8 03:25:24.007: RADIUS:   46 9D 30 0D 06 09 2A 86 48 86 F7 0D 01 01 04 05  [F?0???*?H???????]
*Mar  8 03:25:24.007: RADIUS:   00 30 1A 31 18 30 16 06 03 55 04 03 13 0F 77 69  [?0?1?0???U????wi]
*Mar  8 03:25:24.007: RADIUS:   6E 74 65 73 74 2E 72 64 73 2E 63 6F 6D 30 1E 17  [ntest.rds.com0??]
*Mar  8 03:25:24.007: RADIUS:   0D 31 30 30 35 32 34 31 30 30 34 32 38 5A 17 0D  [?100524100428Z??]
*Mar  8 03:25:24.007: RADIUS:   31 31 30 35 32 34 31 36 30 34 32 38 5A 30 1A 31  [110524160428Z0?1]
*Mar  8 03:25:24.008: RADIUS:   18 30 16 06 03 55 04 03 13 0F 77 69 6E 74 65 73  [?0???U????wintes]
*Mar  8 03:25:24.008: RADIUS:   74 2E 72 64 73 2E 63 6F 6D 30 81 9F 30 0D 06 09  [t.rds.com0??0???]
*Mar  8 03:25:24.008: RADIUS:   2A 86 48 86 F7 0D 01 01 01 05 00 03 81           [*?H??????????]
*Mar  8 03:25:24.008: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.008: RADIUS:   8D 00 30 81 89 02 81 81 00 B0 DA 09 95 3E 4C F4  [??0??????????>L?]
*Mar  8 03:25:24.008: RADIUS:   5F 3F 32 A8 CF 78 98 8B BB 0B C3 05 46 4B C1 B7  [_?2??x??????FK??]
*Mar  8 03:25:24.008: RADIUS:   70 39 8C 49 36 0B 59 9C A7 F4 24 20 31 1C 1A C6  [p9?I6?Y???$ 1???]
*Mar  8 03:25:24.008: RADIUS:   BC 72 65 97 06 57 2A BA CC D2 A2 AC D0 4D 51 70  [?re??W*??????MQp]
*Mar  8 03:25:24.008: RADIUS:   33 AE C6 89 1C 8E 55 FF 4A 2B 88 1C C5 70 93 4B  [3?????U?J+???p?K]
*Mar  8 03:25:24.008: RADIUS:   C8 C1 DF 81 22 01 A1 48 E6 52 C0 31 01 8B AA 2E  [????"??H?R?1???.]
*Mar  8 03:25:24.008: RADIUS:   2B 6A 4E 4A 43 86 D1 B6 23 82 30 DA 10 8D E5 1F  [+jNJC???#?0?????]
*Mar  8 03:25:24.008: RADIUS:   BD B6 4B 71 AC C9 E2 51 9C 74 72 F9 5D FB 9B 7E  [??Kq???Q?tr?]??~]
*Mar  8 03:25:24.009: RADIUS:   61 E4 96 A2 D5 59 40 2A FF 02 03 01 00 01 A3 3C  [a????Y@*???????<]
*Mar  8 03:25:24.009: RADIUS:   30 3A 30 13 06 03 55 1D 25 04 0C 30 0A 06 08 2B  [0:0???U????0???+]
*Mar  8 03:25:24.009: RADIUS:   06 01 05 05 07 03 01 30 23 06 03 55 1D 11 04 1C  [???????0#??U????]
*Mar  8 03:25:24.009: RADIUS:   30 1A 82 0F 77 69 6E 74 65 73 74 2E 72 64 73 2E  [0???wintest.rds.]
*Mar  8 03:25:24.009: RADIUS:   63 6F 6D 82 07 77 69 6E 74 65 73 74 30 0D 06 09  [com??wintest0???]
*Mar  8 03:25:24 72 F0 27 EC A9 4F 0A 59 1B 48 66  [?Ux??r?'??O?Y?Hf]
*Mar  8 03:25:24.009: RADIUS:   95 6F 4B 4C 06 C4 8D 6D 49 83 03 31 CF A3 74 46  [?oKL???mI??1??tF]4.009: RADIUS:   2A 86 48 86 F7 0D 01 01 04 05 00 0
*Mar  8 03:25:24.009: RADIUS:   E5 A4 95 01 D7 E5 B4 B4 EF 72 A2 83 2E 2A E6 6F  [?????????r??.*?o]
*Mar  8 03:25:24.009: RADIUS:   BA 64 D3 E2 5A 51 68 39 A8 98 FC DF 76 0F 72 2F  [?d??ZQh9????v?r/]
*Mar  8 03:25:24.010: RADIUS:   BC BD CA B4 6B 73 FD CF 15 C4 1B 43 32 F5 27 34  [????ks?????C2?'4]
*Mar  8 03:25:24.010: RADIUS:   35 FA 0D 00 0C 9B 02 01 02 0C 96 00 C4 30 81 C1  [5????????????0??]
*Mar  8 03:25:24.010: RADIUS:   31 0B 30 09 06 03 55 04 06 13 02 55 53 31 17 30  [1?0???U????US1?0]
*Mar  8 03:25:24.010: RADIUS:   15 06 03 55 04 0A 13 0E 56 65 72 69 53 69 67 6E  [???U????VeriSign]3 81 81 00 63  [* Inc.1<0:??U???]
*Mar  8 03:25:24.010: RADIUS:   33 43 6C 61 73 73 20 31 20 50 75 62 6C 69 63 20  [3Class 1 Public ]
*Mar  8 03:25:24.010: RADIUS:   50 72 69 6D 61 72 79 20 43 65 72 74 69 66 69 63  [Primary Certific]
*Mar  8 03:25:24.010: RADIUS:   61 74 69 6F 6E 20 41 75 74 68 6F 72 69 74 79 20  [ation Authority ]
*Mar  8 03:25:24.010: RADIUS:   2D 20 47 32 31 3A 30 38 06 03 55 04 0B 13 31 28  [- G21:08??U???1(]
*Mar  8 03:25:24.010: RADIUS:   63 29 20 31 39 39 38 20 56 65 72 69 53 69 67 6E  [c) 1998 VeriSign]?H????????????c]
*Mar  8 03:25:24.009: RADIUS:   06 58 E7 3D AB 4B 31 4F 60 0D A9 17 08 76 D4 77  [?X?=?K1O`????v?w]
*Mar  8 03:25:24.009: RADIUS:   8E 37 F8 6C 78 6A 5
*Mar  8 03:25:24.010: RADIUS:   2C 20 49 6E 63 2E 20 2D 20 46 6F 72 20           [, Inc. - For ]
*Mar  8 03:25:24.010: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.011: RADIUS:   61 75 74 68 6F 72 69 7A 65 64 20 75 73 65 20 6F  [authorized use o]
*Mar  8 03:25:24.011: RADIUS:   6E 6C 79 31 1F 30 1D 06 03 55 04 0B 13 16 56 65  [nly1?0???U????Ve]
*Mar  8 03:25:24.011: RADIUS:   72 69 53 69 67 6E 20 54 72 75 73 74 20 4E 65 74  [riSign Trust Net]
*Mar  8 03:25:24.011: RADIUS:   77 6F 72 6B 00 C4 30 81 C1 31 0B 30 09 06 03 55  [work??0??1?0???U]
*Mar  8 03:25:24.011: RADIUS:   04 06 13 02 55 53 31 17 30 15 06 03 55 04 0A 13  [????US1?0???U???]B EF 71 FA 1B F3 :??U???3Class ]
*Mar  8 03:25:24.011: RADIUS:   34 20 50 75 62 6C 69 63 20 50 72 69 6D 61 72 79  [4 Public Primary]
*Mar  8 03:25:24.011: RADIUS:   20 43 65 72 74 69 66 69 63 61 74 69 6F 6E 20 41  [ Certification A]
*Mar  8 03:25:24.011: RADIUS:   75 74 68 6F 72 69 74 79 20 2D 20 47 32 31 3A 30  [uthority - G21:0]
*Mar  8 03:25:24.011: RADIUS:   38 06 03 55 04 0B 13 31 28 63 29 20 31 39 39 38  [8??U???1(c) 1998]87           [?7?lxj[?q????]
*Mar  8 03:25:24.009: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.009: RADIUS:   8F 64 9B 39 30 E7 88 F0 15 97 73 60 94 CA BB F4  [?d?90?????s`????]
*Mar  8 03:25:24.009: RADIUS:   D9 55 78 E0 D
*Mar  8 03:25:24.010: RADIUS:   2C 20 49 6E 63 2E 31 3C 30 3A 06 03 55 04 0B 13  [,
*Mar  8 03:25:24.011: RADIUS:   0E 56 65 72 69 53 69 67 6E 2C 20 49 6E 63 2E 31  [?VeriSign, Inc.1]
*Mar  8 03:25:24.011: RADIUS:   3C 30 3A 06 03 55 04 0B 13 33 43 6C 61 73 73 20  [<0
*Mar  8 03:25:24.011: RADIUS:   20 56 65 72 69 53 69 67 6E 2C 20 49 6E 63 2E 20  [ VeriSign, Inc. ]
*Mar  8 03:25:24.011: RADIUS:   2D 20 46 6F 72 20 61 75 74 68 6F 72 69 7A 65 64  [- For authorized]
*Mar  8 03:25:24.011: RADIUS:   20 75 73 65 20 6F 6E 6C 79 31 1F 30 1D 06 03 55  [ use only1?0???U]
*Mar  8 03:25:24.012: RADIUS:   04 0B 13 16 56 65 72 69 53 69 67 6E 20 54 72 75  [????VeriSign Tru]
*Mar  8 03:25:24.012: RADIUS:   73 74 20 4E 65 74 77 6F 72 6B 00 D4 30           [st Network??0]
*Mar  8 03:25:24.012: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.012: RADIUS:   81 D1 31 0B 30 09 06 03 55 04 06 13 02 5A 41 31  [??1?0???U????ZA1]
*Mar  8 03:25:24.012: RADIUS:   15 30 13 06 03 55 04 08 13 0C 57 65 73 74 65 72  [?0???U????Wester]
*Mar  8 03:25:24.012: RADIUS:   6E 20 43 61 70 65 31 12 30 10 06 03 55 04 07 13  [n Cape1?0???U???]
*Mar  8 03:25:24.012: RADIUS:   09 43 61 70 65 20 54 6F 77 6E 31 1A 30 18 06 03  [?Cape Town1?0???]
*Mar  8 03:25:24.012: RADIUS:   55 04 0A 13 11 54 68 61 77 74 65 20 43 6F 6E 73  [U????Thawte Cons]
*Mar  8 03:25:24.012: RADIUS:   75 6C 74 69 6E 67 31 28 30 26 06 03 55 04 0B 13  [ulting1(0&??U???]
*Mar  8 03:25:24.012: RADIUS:   1F 43 65 72 74 69 66 69 63 61 74 69 6F 6E 20 53  [?Certification S]
*Mar  8 03:25:24.012: RADIUS:   65 72 76 69 63 65 73 20 44 69 76 69 73 69 6F 6E  [ervices Division]
*Mar  8 03:25:24.013: RADIUS:   31 24 30 22 06 03 55 04 03 13 1B 54 68 61 77 74  [1$0"??U????Thawt]
*Mar  8 03:25:24.013: RADIUS:   65 20 50 65 72 73 6F 6E 61 6C 20 46 72 65 65 6D  [e Personal Freem]
*Mar  8 03:25:24.013: RADIUS:   61 69 6C 20 43 41 31 2B 30 29 06 09 2A 86 48 86  [ail CA1+0)??*?H?]
*Mar  8 03:25:24.013: RADIUS:   F7 0D 01 09 01 16 1C 70 65 72 73 6F 6E 61 6C 2D  [???????personal-]
*Mar  8 03:25:24.013: RADIUS:   66 72 65 65 6D 61 69 6C 40 74 68 61 77 74 65 2E  [freemail@thawte.]
*Mar  8 03:25:24.013: RADIUS:   63 6F 6D 00 D2 30 81 CF 31 0B 30 09 06 03 55 04  [com??0??1?0???U?]
*Mar  8 03:25:24.013: RADIUS:   06 13 02 5A 41 31 15 30 13 06 03 55 04 08 13 0C  [???ZA1?0???U????]
*Mar  8 03:25:24.013: RADIUS:   57 65 73 74 65 72 6E 20 43 61 70 65 31           [Western Cape1]
*Mar  8 03:25:24.013: RADIUS:  EAP-Message         [79]  133
*Mar  8 03:25:24.013: RADIUS:   12 30 10 06 03 55 04 07 13 09 43 61 70 65 20 54  [?0???U????Cape T]
*Mar  8 03:25:24.013: RADIUS:   6F 77 6E 31 1A 30 18 06 03 55 04 0A 13 11 54 68  [own1?0???U????Th]
*Mar  8 03:25:24.013: RADIUS:   61 77 74 65 20 43 6F 6E 73 75 6C 74 69 6E 67 31  [awte Consulting1]
*Mar  8 03:25:24.013: RADIUS:   28 30 26 06 03 55 04 0B 13 1F 43 65 72 74 69 66  [(0&??U????Certif]
*Mar  8 03:25:24.013: RADIUS:   69 63 61 74 69 6F 6E 20 53 65 72 76 69 63 65 73  [ication Services]
*Mar  8 03:25:24.013: RADIUS:   20 44 69 76 69 73 69 6F 6E 31 23 30 21 06 03 55  [ Division1#0!??U]
*Mar  8 03:25:24.014: RADIUS:   04 03 13 1A 54 68 61 77 74 65 20 50 65 72 73 6F  [????Thawte Perso]
*Mar  8 03:25:24.014: RADIUS:   6E 61 6C 20 50 72 65 6D 69 75 6D 20 43 41 31 2A  [nal Premium CA1*]
*Mar  8 03:25:24.014: RADIUS:   30 28 06                                         [0(?]
*Mar  8 03:25:24.014: RADIUS:  State               [24]  25
*Mar  8 03:25:24.014: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.014: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.014: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:24.014: RADIUS:   53 1E 2D DC 52 54 F8 6D C2 81 7B DB 84 1A 13 AD  [S?-?RT?m??{?????]
*Mar  8 03:25:24.015: RADIUS(00000067): Received from id 1645/71
*Mar  8 03:25:24.015: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+253+131, total 1396 bytes
*Mar  8 03:25:24.030: AAA/AUTHEN/PPP (00000067): Pick method list 'eap_methods2'
*Mar  8 03:25:24.031: RADIUS/ENCODE(00000067):Orig. component type = DOT11
*Mar  8 03:25:24.031: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:24.031: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:24.031: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:24.031: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:24.031: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:24.031: RADIUS:   33                                               [3]
*Mar  8 03:25:24.031: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:24.031: RADIUS/ENCODE(00000067): acct_session_id: 103
*Mar  8 03:25:24.032: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:24.032: RADIUS(00000067): sending
*Mar  8 03:25:24.032: RADIUS(00000067): Send Access-Request to 10.1.10.244:1645 id 1645/72, len 155
*Mar  8 03:25:24.032: RADIUS:  authenticator D5 80 10 4D C9 3F 81 C5 - C5 A2 4E E7 8D D4 08 94
*Mar  8 03:25:24.032: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:25:24.032: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:24.032: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:25:24.032: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:24.032: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:24.032: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:24.032: RADIUS:   B3 D8 52 88 61 60 1E B8 A0 3F 63 21 45 BC E0 C0  [??R?a`????c!E???]
*Mar  8 03:25:24.032: RADIUS:  EAP-Message         [79]  8
*Mar  8 03:25:24.032: RADIUS:   02 04 00 06 19 00                                [??????]
*Mar  8 03:25:24.032: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:24.032: RADIUS:  NAS-Port            [5]   6   355
*Mar  8 03:25:24.033: RADIUS:  NAS-Port-Id         [87]  5   "355"
*Mar  8 03:25:24.033: RADIUS:  State               [24]  25
*Mar  8 03:25:24.033: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.033: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.033: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:24.033: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:24.034: RADIUS: Received from id 1645/72 10.1.10.244:1645, Access-Challenge, len 1477
*Mar  8 03:25:24.034: RADIUS:  authenticator 31 B7 35 B9 0A 21 59 BF - 29 25 9D 6B 15 91 C7 FE
*Mar  8 03:25:24.034: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:25:24.035: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.035: RADIUS:   01 05 05 74 19 40 09 2A 86 48 86 F7 0D 01 09 01  [???t?@?*?H??????]
*Mar  8 03:25:24.035: RADIUS:   16 1B 70 65 72 73 6F 6E 61 6C 2D 70 72 65 6D 69  [??personal-premi]
*Mar  8 03:25:24.035: RADIUS:   75 6D 40 74 68 61 77 74 65 2E 63 6F 6D 00 86 30  [um@thawte.com??0]
*Mar  8 03:25:24.035: RADIUS:   81 83 31 0B 30 09 06 03 55 04 06 13 02 55 53 31  [??1?0???U????US1]
*Mar  8 03:25:24.035: RADIUS:   2D 30 2B 06 03 55 04 0A 13 24 46 69 72 73 74 20  [-0+??U???$First ]
*Mar  8 03:25:24.035: RADIUS:   44 61 74 61 20 44 69 67 69 74 61 6C 20 43 65 72  [Data Digital Cer]
*Mar  8 03:25:24.035: RADIUS:   74 69 66 69 63 61 74 65 73 20 49 6E 63 2E 31 45  [tificates Inc.1E]
*Mar  8 03:25:24.035: RADIUS:   30 43 06 03 55 04 03 13 3C 46 69 72 73 74 20 44  [0C??U???*Mar  8 03:25:24.035: RADIUS:   61 74 61 20 44 69 67 69 74 61 6C 20 43 65 72 74  [ata Digital Cert]
*Mar  8 03:25:24.035: RADIUS:   69 66 69 63 61 74 65 73 20 49 6E 63 2E 20 43 65  [ificates Inc. Ce]
*Mar  8 03:25:24.036: RADIUS:   72 74 69 66 69 63 61 74 69 6F 6E 20 41 75 74 68  [rtification Auth]
*Mar  8 03:25:24.036: RADIUS:   6F 72 69 74 79 00 CE 30 81 CB 31 0B 30 09 06 03  [ority??0??1?0???]
*Mar  8 03:25:24.036: RADIUS:   55 04 06 13 02 5A 41 31 15 30 13 06 03 55 04 08  [U????ZA1?0???U??]
*Mar  8 03:25:24.036: RADIUS:   13 0C 57 65 73 74 65 72 6E 20 43 61 70 65 31 12  [??Western Cape1?]
*Mar  8 03:25:24.036: RADIUS:   30 10 06 03 55 04 07 13 09 43 61 70 65 20 54 6F  [0???U????Cape To]
*Mar  8 03:25:24.036: RADIUS:   77 6E 31 1A 30 18 06 03 55 04 0A 13 11           [wn1?0???U????]
*Mar  8 03:25:24.036: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.036: RADIUS:   54 68 61 77 74 65 20 43 6F 6E 73 75 6C 74 69 6E  [Thawte Consultin]
*Mar  8 03:25:24.036: RADIUS:   67 31 28 30 26 06 03 55 04 0B 13 1F 43 65 72 74  [g1(0&??U????Cert]
*Mar  8 03:25:24.036: RADIUS:   69 66 69 63 61 74 69 6F 6E 20 53 65 72 76 69 63  [ification Servic]
*Mar  8 03:25:24.036: RADIUS:   65 73 20 44 69 76 69 73 69 6F 6E 31 21 30 1F 06  [es Division1!0??]
*Mar  8 03:25:24.036: RADIUS:   03 55 04 03 13 18 54 68 61 77 74 65 20 50 65 72  [?U????Thawte Per]
*Mar  8 03:25:24.036: RADIUS:   73 6F 6E 61 6C 20 42 61 73 69 63 20 43 41 31 28  [sonal Basic CA1(]
*Mar  8 03:25:24.036: RADIUS:   30 26 06 09 2A 86 48 86 F7 0D 01 09 01 16 19 70  [0&??*?H????????p]
*Mar  8 03:25:24.036: RADIUS:   65 72 73 6F 6E 61 6C 2D 62 61 73 69 63 40 74 68  [ersonal-basic@th]
*Mar  8 03:25:24.037: RADIUS:   61 77 74 65 2E 63 6F 6D 00 61 30 5F 31 0B 30 09  [awte.com?a0_1?0?]
*Mar  8 03:25:24.037: RADIUS:   06 03 55 04 06 13 02 55 53 31 17 30 15 06 03 55  [??U????US1?0???U]
*Mar  8 03:25:24.037: RADIUS:   04 0A 13 0E 56 65 72 69 53 69 67 6E 2C 20 49 6E  [????VeriSign, In]
*Mar  8 03:25:24.037: RADIUS:   63 2E 31 37 30 35 06 03 55 04 0B 13 2E 43 6C 61  [c.1705??U???.Cla]
*Mar  8 03:25:24.037: RADIUS:   73 73 20 33 20 50 75 62 6C 69 63 20 50 72 69 6D  [ss 3 Public Prim]
*Mar  8 03:25:24.037: RADIUS:   61 72 79 20 43 65 72 74 69 66 69 63 61 74 69 6F  [ary Certificatio]
*Mar  8 03:25:24.037: RADIUS:   6E 20 41 75 74 68 6F 72 69 74 79 00 61 30 5F 31  [n Authority?a0_1]
*Mar  8 03:25:24.037: RADIUS:   0B 30 09 06 03 55 04 06 13 02 55 53 31           [?0???U????US1]
*Mar  8 03:25:24.037: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.037: RADIUS:   17 30 15 06 03 55 04 0A 13 0E 56 65 72 69 53 69  [?0???U????VeriSi]
*Mar  8 03:25:24.037: RADIUS:   67 6E 2C 20 49 6E 63 2E 31 37 30 35 06 03 55 04  [gn, Inc.1705??U?]
*Mar  8 03:25:24.038: RADIUS:   0B 13 2E 43 6C 61 73 73 20 32 20 50 75 62 6C 69  [??.Class 2 Publi]
*Mar  8 03:25:24.038: RADIUS:   63 20 50 72 69 6D 61 72 79 20 43 65 72 74 69 66  [c Primary Certif]
*Mar  8 03:25:24.038: RADIUS:   69 63 61 74 69 6F 6E 20 41 75 74 68 6F 72 69 74  [ication Authorit]
*Mar  8 03:25:24.038: RADIUS:   79 00 61 30 5F 31 0B 30 09 06 03 55 04 06 13 02  [y?a0_1?0???U????]
*Mar  8 03:25:24.038: RADIUS:   55 53 31 17 30 15 06 03 55 04 0A 13 0E 56 65 72  [US1?0???U????Ver]
*Mar  8 03:25:24.038: RADIUS:   69 53 69 67 6E 2C 20 49 6E 63 2E 31 37 30 35 06  [iSign, Inc.1705?]
*Mar  8 03:25:24.038: RADIUS:   03 55 04 0B 13 2E 43 6C 61 73 73 20 31 20 50 75  [?U???.Class 1 Pu]
*Mar  8 03:25:24.038: RADIUS:   62 6C 69 63 20 50 72 69 6D 61 72 79 20 43 65 72  [blic Primary Cer]
*Mar  8 03:25:24.038: RADIUS:   74 69 66 69 63 61 74 69 6F 6E 20 41 75 74 68 6F  [tification Autho]
*Mar  8 03:25:24.038: RADIUS:   72 69 74 79 00 C4 30 81 C1 31 0B 30 09 06 03 55  [rity??0??1?0???U]
*Mar  8 03:25:24.038: RADIUS:   04 06 13 02 55 53 31 17 30 15 06 03 55 04 0A 13  [????US1?0???U???]
*Mar  8 03:25:24.038: RADIUS:   0E 56 65 72 69 53 69 67 6E 2C 20 49 6E 63 2E 31  [?VeriSign, Inc.1]
*Mar  8 03:25:24.038: RADIUS:   3C 30 3A 06 03 55 04 0B 13 33 43 6C 61 73 73 20  [<0:??U???3Class ]
*Mar  8 03:25:24.038: RADIUS:   33 20 50 75 62 6C 69 63 20 50 72 69 6D           [3 Public Prim]
*Mar  8 03:25:24.038: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.039: RADIUS:   61 72 79 20 43 65 72 74 69 66 69 63 61 74 69 6F  [ary Certificatio]
*Mar  8 03:25:24.039: RADIUS:   6E 20 41 75 74 68 6F 72 69 74 79 20 2D 20 47 32  [n Authority - G2]
*Mar  8 03:25:24.039: RADIUS:   31 3A 30 38 06 03 55 04 0B 13 31 28 63 29 20 31  [1:08??U???1(c) 1]
*Mar  8 03:25:24.039: RADIUS:   39 39 38 20 56 65 72 69 53 69 67 6E 2C 20 49 6E  [998 VeriSign, In]
*Mar  8 03:25:24.039: RADIUS:   63 2E 20 2D 20 46 6F 72 20 61 75 74 68 6F 72 69  [c. - For authori]
*Mar  8 03:25:24.039: RADIUS:   7A 65 64 20 75 73 65 20 6F 6E 6C 79 31 1F 30 1D  [zed use only1?0?]
*Mar  8 03:25:24.039: RADIUS:   06 03 55 04 0B 13 16 56 65 72 69 53 69 67 6E 20  [??U????VeriSign ]
*Mar  8 03:25:24.039: RADIUS:   54 72 75 73 74 20 4E 65 74 77 6F 72 6B 00 9C 30  [Trust Network??0]
*Mar  8 03:25:24.039: RADIUS:   81 99 31 0B 30 09 06 03 55 04 06 13 02 48 55 31  [??1?0???U????HU1]
*Mar  8 03:25:24.039: RADIUS:   11 30 0F 06 03 55 04 07 13 08 42 75 64 61 70 65  [?0???U????Budape]
*Mar  8 03:25:24.039: RADIUS:   73 74 31 27 30 25 06 03 55 04 0A 13 1E 4E 65 74  [st1'0???U????Net]
*Mar  8 03:25:24.040: RADIUS:   4C 6F 63 6B 20 48 61 6C 6F 7A 61 74 62 69 7A 74  [Lock Halozatbizt]
*Mar  8 03:25:24.040: RADIUS:   6F 6E 73 61 67 69 20 4B 66 74 2E 31 1A 30 18 06  [onsagi Kft.1?0??]
*Mar  8 03:25:24.040: RADIUS:   03 55 04 0B 13 11 54 61 6E 75 73 69 74 76 61 6E  [?U????Tanusitvan]
*Mar  8 03:25:24.040: RADIUS:   79 6B 69 61 64 6F 6B 31 32 30 30 06 03 55 04 03  [ykiadok1200??U??]
*Mar  8 03:25:24.040: RADIUS:   13 29 4E 65 74 4C 6F 63 6B 20 55 7A 6C           [?)NetLock Uzl]
*Mar  8 03:25:24.040: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:24.040: RADIUS:   65 74 69 20 28 43 6C 61 73 73 20 42 29 20 54 61  [eti (Class B) Ta]
*Mar  8 03:25:24.040: RADIUS:   6E 75 73 69 74 76 61 6E 79 6B 69 61 64 6F 00 47  [nusitvanykiado?G]
*Mar  8 03:25:24.040: RADIUS:   30 45 31 0B 30 09 06 03 55 04 06 13 02 55 53 31  [0E1?0???U????US1]
*Mar  8 03:25:24.040: RADIUS:   18 30 16 06 03 55 04 0A 13 0F 47 54 45 20 43 6F  [?0???U????GTE Co]
*Mar  8 03:25:24.040: RADIUS:   72 70 6F 72 61 74 69 6F 6E 31 1C 30 1A 06 03 55  [rporation1?0???U]
*Mar  8 03:25:24.040: RADIUS:   04 03 13 13 47 54 45 20 43 79 62 65 72 54 72 75  [????GTE CyberTru]
*Mar  8 03:25:24.041: RADIUS:   73 74 20 52 6F 6F 74 00 77 30 75 31 0B 30 09 06  [st Root?w0u1?0??]
*Mar  8 03:25:24.041: RADIUS:   03 55 04 06 13 02 55 53 31 18 30 16 06 03 55 04  [?U????US1?0???U?]
*Mar  8 03:25:24.041: RADIUS:   0A 13 0F 47 54 45 20 43 6F 72 70 6F 72 61 74 69  [???GTE Corporati]
*Mar  8 03:25:24.041: RADIUS:   6F 6E 31 27 30 25 06 03 55 04 0B 13 1E 47 54 45  [on1'0???U????GTE]
*Mar  8 03:25:24.041: RADIUS:   20 43 79 62 65 72 54 72 75 73 74 20 53 6F 6C 75  [ CyberTrust Solu]
*Mar  8 03:25:24.041: RADIUS:   74 69 6F 6E 73 2C 20 49 6E 63 2E 31 23 30 21 06  [tions, Inc.1#0!?]
*Mar  8 03:25:24.041: RADIUS:   03 55 04 03 13 1A 47 54 45 20 43 79 62 65 72 54  [?U????GTE CyberT]
*Mar  8 03:25:24.041: RADIUS:   72 75 73 74 20 47 6C 6F 62 61 6C 20 52 6F 6F 74  [rust Global Root]
*Mar  8 03:25:24.041: RADIUS:   00 C6 30 81 C3 31 0B 30 09 06 03 55 04 06 13 02  [??0??1?0???U????]
*Mar  8 03:25:24.041: RADIUS:   55 53 31 14 30 12 06 03 55 04 0A 13 0B           [US1?0???U????]
*Mar  8 03:25:24.041: RADIUS:  EAP-Message         [79]  133
*Mar  8 03:25:24.041: RADIUS:   45 6E 74 72 75 73 74 2E 6E 65 74 31 3B 30 39 06  [Entrust.net1;09?]
*Mar  8 03:25:24.041: RADIUS:   03 55 04 0B 13 32 77 77 77 2E 65 6E 74 72 75 73  [?U???2www.entrus]
*Mar  8 03:25:24.041: RADIUS:   74 2E 6E 65 74 2F 43 50 53 20 69 6E 63 6F 72 70  [t.net/CPS incorp]
*Mar  8 03:25:24.042: RADIUS:   2E 20 62 79 20 72 65 66 2E 20 28 6C 69 6D 69 74  [. by ref. (limit]
*Mar  8 03:25:24.042: RADIUS:   73 20 6C 69 61 62 2E 29 31 25 30 23 06 03 55 04  [s liab.)1?0#??U?]
*Mar  8 03:25:24.042: RADIUS:   0B 13 1C 28 63 29 20 31 39 39 39 20 45 6E 74 72  [???(c) 1999 Entr]
*Mar  8 03:25:24.042: RADIUS:   75 73 74 2E 6E 65 74 20 4C 69 6D 69 74 65 64 31  [ust.net Limited1]
*Mar  8 03:25:24.042: RADIUS:   3A 30 38 06 03 55 04 03 13 31 45 6E 74 72 75 73  [:08??U???1Entrus]
*Mar  8 03:25:24.042: RADIUS:   74 2E 6E                                         [t.n]
*Mar  8 03:25:24.042: RADIUS:  State               [24]  25
*Mar  8 03:25:24.042: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.042: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.042: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:24.042: RADIUS:   06 4D 55 B8 CF 53 57 BD A5 7B DE 11 10 B6 33 41  [?MU??SW??{????3A]
*Mar  8 03:25:24.043: RADIUS(00000067): Received from id 1645/72
*Mar  8 03:25:24.043: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+253+131, total 1396 bytes
*Mar  8 03:25:24.095: AAA/AUTHEN/PPP (00000067): Pick method list 'eap_methods2'
*Mar  8 03:25:24.096: RADIUS/ENCODE(00000067):Orig. component type = DOT11
*Mar  8 03:25:24.096: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:24.096: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:24.096: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:24.096: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:24.096: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:24.096: RADIUS:   33                                               [3]
*Mar  8 03:25:24.096: RADIUS(00000067): Config NAS IP: 10.1.2.92
*Mar  8 03:25:24.096: RADIUS/ENCODE(00000067): acct_session_id: 103
*Mar  8 03:25:24.096: RADIUS(00000067): sending
*Mar  8 03:25:24.096: RADIUS(00000067): Send Access-Request to 10.1.10.244:1645 id 1645/73, len 155
*Mar  8 03:25:24.097: RADIUS:  authenticator 5F C6 D9 E2 B4 39 24 4B - AA 78 4F F2 46 51 61 B4
*Mar  8 03:25:24.097: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:25:24.097: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:24.097: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:25:24.097: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:24.097: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:24.097: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:24.097: RADIUS:   D0 0C 3F A1 17 80 E7 AC 14 92 7D 21 3A 1C 17 BB  [??????????}!:???]
*Mar  8 03:25:24.097: RADIUS:  EAP-Message         [79]  8
*Mar  8 03:25:24.097: RADIUS:   02 05 00 06 19 00                                [??????]
*Mar  8 03:25:24.097: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:24.097: RADIUS:  NAS-Port            [5]   6   355
*Mar  8 03:25:24.097: RADIUS:  NAS-Port-Id         [87]  5   "355"
*Mar  8 03:25:24.097: RADIUS:  State               [24]  25
*Mar  8 03:25:24.098: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.098: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.098: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:24.098: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:24.099: RADIUS: Received from id 1645/73 10.1.10.244:1645, Access-Challenge, len 1138
*Mar  8 03:25:24.099: RADIUS:  authenticator DD 1B E2 F5 0D 49 DF 7A - A2 E4 8C 85 4B A3 E9 37
*Mar  8 03:25:24.099: RADIUS:  Session-Timeout     [27]  6
*Mar  8 03:25:24.106: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+47, total 1059 bytes
*Mar  8 03:25:24.994: AAA/AUTHEN/PPP (00000067): Pick method list 'eap_methods2'
*Mar  8 03:25:24.995: RADIUS/ENCODE(00000067):Orig. component type = DOT11
*Mar  8 03:25:24.995: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:24.995: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:24.995: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:24.995: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:24.995: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:24.999: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:24.999: RADIUS:  NAS-Port            [5]   6   355
*Mar  8 03:25:24.999: RADIUS:  NAS-Port-Id         [87]  5   "355"
*Mar  8 03:25:24.999: RADIUS:  State               [24]  25
*Mar  8 03:25:24.999: RADIUS:   11 AD 02 5B 00 00 01 37 00 01 0A 01 0A F4 00 00  [???[???7????????]
*Mar  8 03:25:24.999: RADIUS:   00 03 30 5A 07 84 00                             [??0Z???]
*Mar  8 03:25:24.999: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:24.999: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:29.323: AAA/BIND(00000068): Bind i/f
*Mar  8 03:25:41.588: AAA/AUTHEN/PPP (00000068): Pick method list 'eap_methods2'
*Mar  8 03:25:41.589: RADIUS/ENCODE(00000068):Orig. component type = DOT11
*Mar  8 03:25:41.589: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:41.589: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:41.589: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:41.589: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:41.589: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:41.589: RADIUS:   33                                               [3]
*Mar  8 03:25:41.589: RADIUS(00000068): Config NAS IP: 10.1.2.92
*Mar  8 03:25:41.589: RADIUS/ENCODE(00000068): acct_session_id: 104
*Mar  8 03:25:41.590: RADIUS(00000068): Config NAS IP: 10.1.2.92
*Mar  8 03:25:41.590: RADIUS(00000068): sending
*Mar  8 03:25:41.590: RADIUS(00000068): Send Access-Request to 10.1.10.244:1645 id 1645/75, len 140
*Mar  8 03:25:41.590: RADIUS:  authenticator 45 BD 54 C6 E2 67 70 08 - 1F 43 64 8B A6 83 30 10
*Mar  8 03:25:41.590: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:25:41.590: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:41.590: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:25:41.590: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:41.590: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:41.590: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:41.590: RADIUS:   4C 17 CC 1E D1 FD 5A B6 CA C4 D9 89 39 06 F7 63  [L?????Z?????9??c]
*Mar  8 03:25:41.590: RADIUS:  EAP-Message         [79]  18
*Mar  8 03:25:41.590: RADIUS:   02 02 00 10 01 72 61 6A 40 72 64 73 2E 63 6F 6D  [?????raj@rds.com]
*Mar  8 03:25:41.590: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:41.591: RADIUS:  NAS-Port            [5]   6   356
*Mar  8 03:25:41.591: RADIUS:  NAS-Port-Id         [87]  5   "356"
*Mar  8 03:25:41.591: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:41.591: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:41.593: RADIUS: Received from id 1645/75 10.1.10.244:1645, Access-Challenge, len 77
*Mar  8 03:25:41.593: RADIUS:  authenticator AF C2 D7 1F 9D 68 5A 7E - 14 76 92 EE BB 9D 38 16
*Mar  8 03:25:41.594: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:25:41.594: RADIUS:  EAP-Message         [79]  8
*Mar  8 03:25:41.594: RADIUS:   01 03 00 06 19 20                                [????? ]
*Mar  8 03:25:41.594: RADIUS:  State               [24]  25
*Mar  8 03:25:41.594: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:41.594: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:41.594: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:41.594: RADIUS:   47 4E E1 5E 18 F2 AE 57 F6 AD 1A D1 C9 72 1A 1E  [GN?^???W?????r??]
*Mar  8 03:25:41.594: RADIUS(00000068): Received from id 1645/75
*Mar  8 03:25:41.594: RADIUS/DECODE: EAP-Message fragments, 6, total 6 bytes
*Mar  8 03:25:41.602: AAA/AUTHEN/PPP (00000068): Pick method list 'eap_methods2'
*Mar  8 03:25:41.603: RADIUS/ENCODE(00000068):Orig. component type = DOT11
*Mar  8 03:25:41.603: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:41.603: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:41.603: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:41.603: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:41.603: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:41.603: RADIUS:   33                                               [3]
*Mar  8 03:25:41.603: RADIUS(00000068): Config NAS IP: 10.1.2.92
*Mar  8 03:25:41.603: RADIUS/ENCODE(00000068): acct_session_id: 104
*Mar  8 03:25:41.603: RADIUS(00000068): sending
*Mar  8 03:25:41.603: RADIUS(00000068): Send Access-Request to 10.1.10.244:1645 id 1645/76, len 269
*Mar  8 03:25:41.604: RADIUS:  authenticator 07 34 1F 68 73 9E 8C AC - B9 96 29 C7 CA 3B F1 61
*Mar  8 03:25:41.604: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:25:41.604: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:25:41.604: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:25:41.604: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:25:41.604: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:25:41.604: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:41.604: RADIUS:   BC 95 7B 49 4A A6 BB BF 54 FA 32 7B 21 29 CB E9  [??{IJ???T?2{!)??]
*Mar  8 03:25:41.604: RADIUS:  EAP-Message         [79]  122
*Mar  8 03:25:41.604: RADIUS:   02 03 00 78 19 80 00 00 00 6E 16 03 01 00 69 01  [???x?????n????i?]
*Mar  8 03:25:41.604: RADIUS:   00 00 65 03 01 4C 03 B2 2E 5E 85 7E A1 CB 91 25  [??e??L??.^?~????]
*Mar  8 03:25:41.604: RADIUS:   BC ED E6 59 8B 0F E2 69 B7 9E DD 51 47 46 80 6D  [???Y???i???QGF?m]
*Mar  8 03:25:41.604: RADIUS:   36 2A 30 25 87 00 00 18 00 2F 00 35 00 05 00 0A  [6*0??????/?5????]
*Mar  8 03:25:41.605: RADIUS:   C0 13 C0 14 C0 09 C0 0A 00 32 00 38 00 13 00 04  [?????????2?8????]
*Mar  8 03:25:41.605: RADIUS:   01 00 00 24 00 00 00 10 00 0E 00 00 0B 72 61 6A  [???$?????????raj]
*Mar  8 03:25:41.605: RADIUS:   40 72 64 73 2E 63 6F 6D 00 0A 00 06 00 04 00 17  [@rds.com????????]
*Mar  8 03:25:41.605: RADIUS:   00 18 00 0B 00 02 01 00                          [????????]
*Mar  8 03:25:41.605: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:25:41.605: RADIUS:  NAS-Port            [5]   6   356
*Mar  8 03:25:41.605: RADIUS:  NAS-Port-Id         [87]  5   "356"
*Mar  8 03:25:41.605: RADIUS:  State               [24]  25
*Mar  8 03:25:41.605: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:41.605: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:41.605: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:41.605: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:41.607: RADIUS: Received from id 1645/76 10.1.10.244:1645, Access-Challenge, len 1477
*Mar  8 03:25:41.607: RADIUS:  authenticator 31 82 40 80 69 66 1A 55 - AF FF 07 D0 C7 E7 C9 4C
*Mar  8 03:25:41.607: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:25:41.607: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:25:41.607: RADIUS:   01 04 05 74 19 C0 00 00 0E F5 16 03 01 0E F0 02  [???t????????????]
*Mar  8 03:25:41.607: RADIUS:   00 00 46 03 01 4C 03 B1 B6 DD 09 4D 2A A9 11 DB  [??F??L?????M*???]
*Mar  8 03:25:41.607: RADIUS:   1D 72 6C BA CD B2 F0 D4 57 E7 26 11 5A 8E CA 76  [?rl?????W?&?Z??v]
*Mar  8 03:25:41.607: RADIUS:   4B 7F 8A 08 80 20 0E 21 00 00 A1 8D 19 EB 7E A1  [K???? ?!??????~?]
*Mar  8 03:25:41.608: RADIUS:   01 F5 4A 4D 13 19 1D 46 B4 D9 5B B3 8C F6 06 39  [??JM???F??[????9]
*Mar  8 03:25:41.615: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:41.615: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:41.615: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:41.615: RADIUS:   43 70 77 97 83 8C C4 3C CE 2D ED C9 80 03 F2 50  [Cpw????*Mar  8 03:25:41.615: RADIUS(00000068): Received from id 1645/76
*Mar  8 03:25:41.615: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+253+131, total 1396 bytes
*Mar  8 03:25:42.026: AAA/AUTHEN/PPP (00000068): Pick method list 'eap_methods2'
*Mar  8 03:25:42.027: RADIUS/ENCODE(00000068):Orig. component type = DOT11
*Mar  8 03:25:42.029: RADIUS:  State               [24]  25
*Mar  8 03:25:42.030: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:42.030: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:42.030: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:42.030: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:42.245: RADIUS: Received from id 1645/77 10.1.10.244:1645, Access-Challenge, len 1477
*Mar  8 03:25:42.245: RADIUS:  authenticator 3C 17 59 92 6E 6A 7F 51 - F4 9A EA 59 8D 50 7B EC
*Mar  8 03:25:42.245: RADIUS:  Session-Timeout     [27]  6
*Mar  8 03:25:42.253: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:42.253: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:42.253: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:42.253: RADIUS:   BE 41 3A 1C 20 05 B7 9A 7E BF 50 4F 57 A9 04 AC  [?A:? ???~?POW???]
*Mar  8 03:25:42.254: RADIUS(00000068): Received from id 1645/77
*Mar  8 03:25:42.254: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+253+131, total 1396 bytes
*Mar  8 03:25:43.081: AAA/AUTHEN/PPP (00000068): Pick method list 'eap_methods2'
*Mar  8 03:25:43.081: RADIUS/ENCODE(00000068):Orig. component type = DOT11
*Mar  8 03:25:43.084: RADIUS:  State               [24]  25
*Mar  8 03:25:43.084: RADIUS:   11 AF 02 5C 00 00 01 37 00 01 0A 01 0A F4 00 00  [???\???7????????]
*Mar  8 03:25:43.084: RADIUS:   00 03 30 5A 07 85 00                             [??0Z???]
*Mar  8 03:25:43.085: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:25:43.085: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:25:43.767: RADIUS: Received from id 1645/78 10.1.10.244:1645, Access-Challenge, len 1138
*Mar  8 03:25:43.767: RADIUS:  authenticator 8C BF 95 23 6F 56 5A 5F - 62 2B 45 38 4B 6B C8 4A
*Mar  8 03:25:43.767: RADIUS:  Session-Timeout     [27]  6
*Mar  8 03:25:43.774: RADIUS/DECODE: EAP-Message fragments, 253+253+253+253+47, total 1059 bytes
*Mar  8 03:25:44.819: AAA/AUTHEN/PPP (00000068): Pick method list 'eap_methods2'
*Mar  8 03:25:44.820: RADIUS/ENCODE(00000068):Orig. component type = DOT11
*Mar  8 03:25:44.820: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:25:44.820: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:25:44.820: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:25:44.820: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:25:44.820: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:25:45.375: RADIUS: Received from id 1645/79 10.1.10.244:1645, Access-Reject, len 44
*Mar  8 03:25:45.375: RADIUS:  authenticator 41 2D CD 08 64 62 A7 F9 - 4E 96 90 BA 01 91 07 C7
*Mar  8 03:25:45.375: RADIUS:  EAP-Message         [79]  6
*Mar  8 03:25:45.375: RADIUS:   04 07 00 04                                      [????]
*Mar  8 03:25:45.375: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:25:45.375: RADIUS:   C9 3D 3C 4B F0 99 28 32 6C C9 1E C7 FF 8E 94 1B  [?=*Mar  8 03:25:45.376: RADIUS(00000068): Received from id 1645/79
*Mar  8 03:25:45.376: RADIUS/DECODE: EAP-Message fragments, 4, total 4 bytes
*Mar  8 03:25:49.365: AAA/BIND(00000069): Bind i/f
*Mar  8 03:26:19.407: %DOT11-7-AUTH_FAILED: Station 0021.0063.fb97 Authentication failed
*Mar  8 03:26:23.445: AAA/BIND(0000006A): Bind i/f
*Mar  8 03:26:53.490: %DOT11-7-AUTH_FAILED: Station 0021.0063.fb97 Authentication failed
*Mar  8 03:26:57.503: AAA/BIND(0000006B): Bind i/f
*Mar  8 03:28:20.447: AAA/AUTHEN/PPP (0000006D): Pick method list 'eap_methods2'
*Mar  8 03:28:20.448: RADIUS/ENCODE(0000006D):Orig. component type = DOT11
*Mar  8 03:28:20.448: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:28:20.448: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:28:20.448: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:28:20.448: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:28:20.448: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:28:20.448: RADIUS:   33                                               [3]
*Mar  8 03:28:2raj@rds.com"
*Mar  8 03:28:20.449: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:28:20.449: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"0.448: RADIUS(0000006D): Config NAS IP: 10.1.2.92
*Mar  8 03:28:20.448: RADIUS/ENCODE(0000006D): acct_session_id: 109
*Mar  8 03:28:20.448: RADIUS(0000006D): Config NAS IP: 10.1.2.92
*Mar  8 03:28:20.448: RADIUS(0000006D): sending
*Mar  8 03:28:20.448: RADIUS(0000006D): Send Access-Request to 10.1.10.244:1645 id 1645/80, len 140
*Mar  8 03:28:20.449: RADIUS:  authenticator 46 86 77 61 08 E4 A4 ED - 4C 6B ED BE 90 F4 92 BF
*Mar  8 03:28:20.449: RADIUS:  User-Name           [1]   13  "
*Mar  8 03:28:20.449: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:28:20.449: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:28:20.449: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:28:20.449: RADIUS:   86 6F 05 C0 F5 F2 9D 6A A5 2B DA 71 55 87 1D 7D  [?o?????j?+?qU??}]
*Mar  8 03:28:20.449: RADIUS:  EAP-Message         [79]  18
*Mar  8 03:28:20.449: RADIUS:   02 02 00 10 01 72 61 6A 40 72 64 73 2E 63 6F 6D  [?????raj@rds.com]
*Mar  8 03:28:20.449: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:28:20.449: RADIUS:  NAS-Port            [5]   6   361
*Mar  8 03:28:20.449: RADIUS:  NAS-Port-Id         [87]  5   "361"
*Mar  8 03:28:20.449: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:28:20.450: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:28:20.453: RADIUS: Received from id 1645/80 10.1.10.244:1645, Access-Challenge, len 77
*Mar  8 03:28:20.453: RADIUS:  authenticator 1E 6B 8C 7D 84 20 A5 31 - 76 A8 86 E7 1C 11 CD 2B
*Mar  8 03:28:20.453: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:28:20.453: RADIUS:  EAP-Message         [79]  8
*Mar  8 03:28:20.453: RADIUS:   01 03 00 06 19 20                                [????? ]
*Mar  8 03:28:20.453: RADIUS:  State               [24]  25
*Mar  8 03:28:20.454: RADIUS:   11 B1 02 5D 00 00 01 37 00 01 0A 01 0A F4 00 00  [???]???7????????]
*Mar  8 03:28:20.454: RADIUS:   00 03 30 5A 07 86 00                             [??0Z???]
*Mar  8 03:28:20.454: RADIUS:  Message-Authenticato[80]  18
*Mar  8 03:28:20.454: RADIUS:   D1 CE C0 99 B9 D3 FB 01 B2 22 19 65 40 D7 B4 71  [?????????"?e@??q]
*Mar  8 03:28:20.454: RADIUS(0000006D): Received from id 1645/80
*Mar  8 03:28:20.454: RADIUS/DECODE: EAP-Message fragments, 6, total 6 bytes
*Mar  8 03:28:20.460: AAA/AUTHEN/PPP (0000006D): Pick method list 'eap_methods2'
*Mar  8 03:28:20.461: RADIUS/ENCODE(0000006D):Orig. component type = DOT11
*Mar  8 03:28:20.461: RADIUS:  AAA Unsupported Attr: ssid              [265] 9
*Mar  8 03:28:20.461: RADIUS:   4E 55 50 43 4F 2D 4C                             [NUPCO-L]
*Mar  8 03:28:20.461: RADIUS:  AAA Unsupported Attr: location-name     [552] 8
*Mar  8 03:28:20.461: RADIUS:   49 43 54 5F 41 72                                [ICT_Ar]
*Mar  8 03:28:20.461: RADIUS:  AAA Unsupported Attr: interface         [157] 3
*Mar  8 03:28:20.462: RADIUS:   33                                               [3]
*Mar  8 03:28:20.462: RADIUS(0000006D): Config NAS IP: 10.1.2.92
*Mar  8 03:28:20.462: RADIUS/ENCODE(0000006D): acct_session_id: 109
*Mar  8 03:28:20.462: RADIUS(0000006D): sending
*Mar  8 03:28:20.462: RADIUS(0000006D): Send Access-Request to 10.1.10.244:1645 id 1645/81, len 269
*Mar  8 03:28:20.462: RADIUS:  authenticator B3 73 E1 74 B8 A7 B4 1D - 9B 87 7C 00 6D C3 54 7D
*Mar  8 03:28:20.462: RADIUS:  User-Name           [1]   13  "raj@rds.com"
*Mar  8 03:28:20.462: RADIUS:  Framed-MTU          [12]  6   1400
*Mar  8 03:28:20.462: RADIUS:  Called-Station-Id   [30]  16  "ec44.76b8.93e0"
*Mar  8 03:28:20.462: RADIUS:  Calling-Station-Id  [31]  16  "0021.0063.fb97"
*Mar  8 03:28:20.462: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Mar  8 03:28:20.462: RADI 6C A5  [??e??L???8ZX?]l?]
*Mar  8 03:28:20.463: RADIUS:   77 E1 1D E6 C7 09 12 29 6A DF 1C BC 52 E4 CB C8  [w??????)j???R???]US:  Message-Auth
*Mar  8 03:28:20.463: RADIUS:   58 69 84 AB B3 00 00 18 00 2F 00 35 00 05 00 0A  [Xi???????/?5????]
*Mar  8 03:28:20.463: RADIUS:   C0 13 C0 14 C0 09 C0 0A 00 32 00 38 00 13 00 04  [?????????2?8????]
*Mar  8 03:28:20.463: RADIUS:   01 00 00 24 00 00 00 10 00 0E 00 00 0B 72 61 6A  [???$?????????raj]
*Mar  8 03:28:20.463: RADIUS:   40 72 64 73 2E 63 6F 6D 00 0A 00 06 00 04 00 17  [@rds.com????????]
*Mar  8 03:28:20.463: RADIUS:   00 18 00 0B 00 02 01 00                          [????????]
*Mar  8 03:28:20.463: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Mar  8 03:28:20.463: RADIUS:  NAS-Port            [5]   6   361                       enticato[80]  18
*Mar  8 03:28:20.462: RADIUS:   DF B0 5D 04 F0 C5 BE B6 E1 72 28 4C 67 EA 6F 05  [??]??????r(Lg?o?]
*Mar  8 03:28:20.462: RADIUS:  EAP-Message         [79]  122
*Ma 02 5D 00 00 01 37 00 01 0A 01 0A F4 00 00  [???]???7????????]
*Mar  8 03:28:20.464: RADIUS:   00 03 30 5A 07 86 00                             [??0Z???]
*Mar  8 03:28:20.464: RADIUS:  NAS-IP-Address      [4]   6   10.1.2.92
*Mar  8 03:28:20.464: RADIUS:  Nas-Identifier      [32]  4   "ap"
*Mar  8 03:28:20.465: RADIUS: Received from id 1645/81 10.1.10.244:1645, Access-Challenge, len 1477
*Mar  8 03:28:20.465: RADIUS:  authenticator 23 3D 52 94 DB C7 A6 D6 - 13 B7 6E 6B 6F D6 9E 8Br  8 03:28:20.463
*Mar  8 03:28:20.465: RADIUS:  Session-Timeout     [27]  6   30
*Mar  8 03:28:20.466: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:28:20.466: RADIUS:   01 04 05 74 19 C0 00 00 0E F5 16 03 01 0E F0 02  [???t????????????]
*Mar  8 03:28:20.466: RADIUS:   00 00 46 03 01 4C 03 B2 55 85 7B BE 7C CC 0F DD  [??F??L??U?{?|???]
*Mar  8 03:28:20.466: RADIUS:   53 94 A5 60 65 FA BC 2E 67 7A E4 F9 AD F6 C5 DD  [S??`e??.gz??????]
*Mar  8 03:28:20.466: RADIUS:   2E E3 7E AB 42 20 D6 04 00 00 DB 07 0A A7 93 77  [.?~?B ?????????w]
*Mar  8 03:28:20.466: RADIUS:   1D 8A 80 0C F6 3C B8 DD 2F 09 3E FB 5E 19 45 19  [??????^?E?]: RADIUS:   02 03 00 78 19 80 00 00 00 6E 16 03 01 00 69 01  [???x?????n????i?]
*Mar  8 03:28:20.463: RADIUS:   00 00 65 03 01 4C 03 B2*Mar  8 03:28:20.466: RADIUS:   02 10 C5 A7 73 6E B3 6E 02 8B 41 1A 33 1C 83 A1  [????sn?n??A?3???]
*Mar  8 03:28:20.466: RADIUS:   46 9D 30 0D 06 09 2A 86 48 86 F7 0D 01 01 04 05  [F?0???*?H???????]
*Mar  8 03:28:20.466: RADIUS:   00 30 1A 31 18 30 16 06 03 55 04 03 13 0F 77 69  [?0?1?0???U????wi]
*Mar  8 03:28:20.467: RADIUS:   6E 74 65 73 74 2E 72 64 73 2E 63 6F 6D 30 1E 17  [ntest.rds.com0??] CD 38 5A 58 12 5
*Mar  8 03:28:20.467: RADIUS:   0D 31 30 30 35 32 34 31 30 30 34 32 38 5A 17 0D  [?100524100428Z??]
*Mar  8 03:28:20.467: RADIUS:   31 31 30 35 32 34 31 36 30 34 32 38 5A 30 1A 31  [110524160428Z0?1]
*Mar  8 03:28:20.467: RADIUS:   18 30 16 06 03 55 04 03 13 0F 77 69 6E 74 65 73  [?0???U????wintes]
*Mar  8 03:28:20.467: RADIUS:   74 2E 72 64 73 2E 63 6F 6D 30 81 9F 30 0D 06 09  [t.rds.com0??0???]
*Mar  8 03:28:20.467: RADIUS:   2A 86 48 86 F7 0D 01 01 01 05 00 03 81           [*?H??????????]
*Mar  8 03:28:20.467: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:28:20.467: RADIUS:   8D 00 30 81 89 02 81 81 00 B0 DA 09 95 3E 4C F4  [??0??????????>L?]D
*Mar  8 03:28:20.463: RADIUS:  NAS-Port-Id         [87]  5   "36159 9C A7 F4 24 20 31 1C 1A C6  [p9?I6?Y???$ 1???]
*Mar  8 03:28:20.467: RADIUS:   BC 72 65 97 06 57 2A BA CC D2 A2 AC D0 4D 51 70  [?re??W*??????MQp]
*Mar  8 03:28:20.467: RADIUS:   33 AE C6 89 1C 8E 55 FF 4A 2B 88 1C C5 70 93 4B  [3?????U?J+???p?K]
*Mar  8 03:28:20.467: RADIUS:   C8 C1 DF 81 22 01 A1 48 E6 52 C0 31 01 8B AA 2E  [????"??H?R?1???.]
*Mar  8 03:28:20.467: RADIUS:   2B 6A 4E 4A 43 86 D1 B6 23 82 30 DA 10 8D E5 1F  [+jNJC???#?0?????]"
*Mar  8 03:28:
*Mar  8 03:28:20.467: RADIUS:   BD B6 4B 71 AC C9 E2 51 9C 74 72 F9 5D FB 9B 7E  [??Kq???Q?tr?]??~]
*Mar  8 03:28:20.468: RADIUS:   61 E4 96 A2 D5 59 40 2A FF 02 03 01 00 01 A3 3C  [a????Y@*???????<]
*Mar  8 03:28:20.468: RADIUS:   30 3A 30 13 06 03 55 1D 25 04 0C 30 0A 06 08 2B  [0:0???U????0???+]
*Mar  8 03:28:20.468: RADIUS:   06 01 05 05 07 03 01 30 23 06 03 55 1D 11 04 1C  [???????0#??U????]
*Mar  8 03:28:20.468: RADIUS:   30 1A 82 0F 77 69 6E 74 65 73 74 2E 72 64 73 2E  [0???wintest.rds.]
*Mar  8 03:28:20.468: RADIUS:   63 6F 6D 82 07 77 69 6E 74 65 73 74 30 0D 06 09  [com??wintest0???]20.463: RADIUS:  State               [24]  25
*Mar  8 03:28:20.464: RADIUS:   11 B1
*Mar  8 03:28:20.466: RADIUS:   57 CF A9 7E 4C 3B 00 04 00 0B 00 01 FF 00 01 FC  [W??~L;??????????]
*Mar  8 03:28:20.466: RADIUS:   00 01 F9 30 82 01 F5 30 82 01 5E A0 03 02 01 02  [???0???0??^?????]
*Mar  8 03:28:20.467: RADIUS:   5F 3F 32 A8 CF 78 98 8B BB 0B C3 05 46 4B C1 B7  [_?2??x??????FK??]
*Mar  8 03:28:20.467: RADIUS:   70 39 8C 49 36 0B
*Mar  8 03:28:20.468: RADIUS:   2A 86 48 86 F7 0D 01 01 04 05 00 03 81 81 00 63  [*?H????????????c]
*Mar  8 03:28:20.468: RADIUS:   06 58 E7 3D AB 4B 31 4F 60 0D A9 17 08 76 D4 77  [?X?=?K1O`????v?w]
*Mar  8 03:28:20.468: RADIUS:   8E 37 F8 6C 78 6A 5B EF 71 FA 1B F3 87           [?7?lxj[?q????]
*Mar  8 03:28:20.468: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:28:20.468: RADIUS:   8F 64 9B 39 30 E7 88 F0 15 97 73 60 94 CA BB F4  [?d?90?????s`????]
*Mar  8 03:28:20.468: RADIUS:   D9 55 78 E0 D4 72 F0 27 EC A9 4F 0A 59 1B 48 66  [?Ux??r?'??O?Y?Hf]
*Mar  8 03:28:20.468: RADIUS:   95 6F 4B 4C 06 C4 8D 6D 49 83 03 31 CF A3 74 46  [?oKL???mI??1??tF]
*Mar  8 03:28:20.469: RADIUS:   E5 A4 95 01 D7 E5 B4 B4 EF 72 A2 83 2E 2A E6 6F  [?????????r??.*?o]
*Mar  8 03:28:20.469: RADIUS:   BA 64 D3 E2 5A 51 68 39 A8 98 FC DF 76 0F 72 2F  [?d??ZQh9????v?r/]
*Mar  8 03:28:20.469: RADIUS:   BC BD CA B4 6B 73 FD CF 15 C4 1B 43 32 F5 27 34  [????ks?????C2?'4]
*Mar  8 03:28:20.469: RADIUS:   35 FA 0D 00 0C 9B 02 01 02 0C 96 00 C4 30 81 C1  [5????????????0??]
*Mar  8 03:28:20.469: RADIUS:   31 0B 30 09 06 03 55 04 06 13 02 55 53 31 17 30  [1?0???U????US1?0]
*Mar  8 03:28:20.469: RADIUS:   15 06 03 55 04 0A 13 0E 56 65 72 69 53 69 67 6E  [???U????VeriSign]
*Mar  8 03:28:20.469: RADIUS:   2C 20 49 6E 63 2E 31 3C 30 3A 06 03 55 04 0B 13  [, Inc.1<0:??U???]
*Mar  8 03:28:20.469: RADIUS:   33 43 6C 61 73 73 20 31 20 50 75 62 6C 69 63 20  [3Class 1 Public ]
*Mar  8 03:28:20.469: RADIUS:   50 72 69 6D 61 72 79 20 43 65 72 74 69 66 69 63  [Primary Certific]
*Mar  8 03:28:20.469: RADIUS:   61 74 69 6F 6E 20 41 75 74 68 6F 72 69 74 79 20  [ation Authority ]
*Mar  8 03:28:20.469: RADIUS:   2D 20 47 32 31 3A 30 38 06 03 55 04 0B 13 31 28  [- G21:08??U???1(]
*Mar  8 03:28:20.469: RADIUS:   63 29 20 31 39 39 38 20 56 65 72 69 53 69 67 6E  [c) 1998 VeriSign]
*Mar  8 03:28:20.469: RADIUS:   2C 20 49 6E 63 2E 20 2D 20 46 6F 72 20           [, Inc. - For ]
*Mar  8 03:28:20.469: RADIUS:  EAP-Message         [79]  255
*Mar  8 03:28:20.470: RADIUS:   61 75 74 68 6F 72 69 7A 65 64 20 75 73 65 20 6F  [authorized use o]
*Mar  8 03:28:20.470: RADIUS:   6E 6C 79 31 1F 30 1D 06 03 55 04 0B 13 16 56 65  [nly1?0???U????Ve]
*Mar  8 03:28:20.470: RADIUS:   72 69 53 69 67 6E 20 54 72 75 73 74 20 4E 65 74  [riSign Trust Net]
*Mar  8 03:28:20.470: RADIUS:   77 6F 72 6B 00 C4 30 81 C1 31 0B 30 09 06 03 55  [work??0??1?0???U]
*Mar  8 03:28:20.470: RADIUS:   04 06 13 02 55 53 31 17 30 15 06 03 55 04 0A 13  [????US1?0???U???]
*Mar  8 03:28:20.470: RADIUS:   0E 56 65 72 69 53 69 67 6E 2C 20 49 6E 63 2E 31  [?VeriSign, Inc.1]
*Mar  8 03:28:20.470: RADIUS:   3C 30 3A 06 03 55 04 0B 13 33 43 6C 61 73 73 20  [<0:??U???3Class ]
*Mar  8 03:28:20.470: RADIUS:   34 20 50 75 62 6C 69 63 20 50 72 69 6D 61 72 79  [4 Public Primary]
*Mar  8 03:28:20.470: RADIUS:   20 43 65 72 74 69 66 69 63 61 74 69 6F 6E 20 41  [ Certification A]
*Mar  8 03:28:20.471: RADIUS:   75 74 68 6F 72 69 74 79 20 2D 20 47 32 31 3A 30  [uthority - G21:0]
*Mar  8 03:28:20.471: RADIUS:   38 06 03 55 04 0B 13 31 28 63 29 20 31 39 39 38  [8??U???1(c) 1998]
*Mar  8 03:28:20.471: RADIUS:   20 56 65 72 69 53 69 67 6E 2C 20 49 6E 63 2E 20  [ VeriSign, Inc. ]
*Mar  8 03:28:20.471: RADIUS:   2D 20 46
Just to make sure... you are not using the same username that is local to the access point correct?  All other users fail too?
Scott
-Scott
HI Scott,
           I am using right username and password of my domain.  I can login on domain using same username and password.  I was try to reset my domain password also, but still i am not success in these issue.  Just i am facing problem that i can't wireless authentication from domain.  If you know scott you can help in these issue.
What i done?
I have 1140 access point and Windows Radius server Installed.
I have done everything on radius server same shared key used in access point also.
Is their any certificate i have to used in radius or access point.
in 1140 i can generate certificate (Import Certificate).  Is thier any solution you can send me with snapshot if available.
If you need details about my access point configuration i can post here.
I am unable to access wireless access point through telnet, and just  i am using web interface only.
Please if you know help me in these issue.
regards,
take care scott.
Hi scott,
         I did not understand about local user on access point. i am using domain username and password to access wireless.  can you help in these issue.
waiting for your reply.
Just post your ap configuration and a screen shot of the IAS policy, event viewer error and the wireless device profile so I can take a look.
Scott
-Scott
