Unity connection 7.1.3 Backup issue
Answered Question
May 26th, 2010
Hi all,
looking for some advice, the situation is as follows:
I'm backing up a unity connection server to a windows server with winSCP installed (sftp). i'm doing a manual backup and cannot backup the 'connection_messages' it just gets stuck and i have to reset drf master/local services on ccmservice before i can re-attempt. to resolve this i've tried:
1. using a different sftp server (coreftp)
2. using a different machine to backup to.
3. doing the backups one feature at a time.
the message store gets up to 15mb at the most, and will then just disconnect from the SFTP server.
do u have any suggestions?
Thank you in advance
Correct Answer by David Hailey about 7 years 1 month ago
Scheduled vs. Manual doesn't matter - if one fails, so will the other.  Do you essentially see the message store backup get to 40% and then it hangs for a while and fails?
Overall Rating: 5 (13 ratings)
Rob Huffman Wed, 05/26/2010 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
This is a very common problem
From Brad @ Cisco
TAC has also written some instructions on how to use CoreFTP which has also been used in the past:
https://supportforums.cisco.com/docs/DOC-8142
A great thread with nice answers from Brad, Hailey and Derek;
https://supportforums.cisco.com/message/3036975#3036975
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
kalebaks86 Wed, 05/26/2010 - 06:18
Hi and thanks for the reply Rob.
I've seen and gone through the coreftp link you posted. I did a search on this forum prior to posting. the fix mentioned in the thread does not really apply to me however as i'm not trying to backup a callmanager cluster, are the files that big in comparison to the ones mentioned (mines are stopping around the 20mb mark). perhaps i missed some info in the thread?
thanks again rob, let me know what you think.
Rob Huffman Wed, 05/26/2010 - 06:30
  • Hall of Fame,
    Founding Member
Hi there,
No worries my friend
I think the answers in the thread are completely related to
Unity Connection 7.1(3) and are applicable to your issues.
Have another browse through there.
We took Hailey's great advice and have started backing up the messages
via the Sub instead of the Pub.Works sweet!!
Cheers!
Rob
David Hailey Wed, 05/26/2010 - 06:48
  • Purple, 4500 points or more
If this is a cluster, I've seen this a few times.  The only fix I found (as I only use CopSSH which does not have file limitation issues and I'm not a big fan of CoreFTP, either) is as follows:
Create 2 backup paths on your SFTP folder - ex: CUC Pub, CUC Sub
Set the backup target on each server to it's own separate location (avoid issues with backup retention, that's the point here).
On the Pub, backup everything except for the message store.
On the Sub, you can backup everything or optionally only the message store.
In a restore scenario, you'd be fine because the data is replicated between servers so you can restore the message store file from the Sub to the Pub without issue.
If it's a standalone server, you could set up 2 backup jobs.  One to do everything but messages and the other to only backup messages - then see what happens with that.
Hailey
Please rate helpful posts!
kalebaks86 Wed, 05/26/2010 - 07:23
just to further elaborate the scenarion here....
we do have a callmanager cluster. however there is more than one unity server in this cluster. some of those are not unity connection but full blow unity. This particular server is the one i want to backup just the one time (for now). when i go to do this backup i browse to https://address-of-unity-server/drf.  from there i've setup a backup device (a laptop with coreftp server installed). i then go to manual backup, select all features (four of them) then i start the backup.
initially it used to get stuck on the database feature, so i decided to do them one by one starting with database which now worked, i then tried messagestore on its own and that got stuck (again not talking GB's here these files are all under 50MB so far).
now with the post you posted above, i don't understand where the callmanager pub and sub get involved here because as i see it, i'm doing everything from the unity server. i can't see how i can backup unity connection from the CCM's. This can just be a lack of understanding (on my behalf) on how these servers actually integrate together in terms of DR etc so i'm open to further explanation if you'll all bare with me.
thanks for the advice so far guys.
David Hailey Wed, 05/26/2010 - 07:43
I didn't say anything about the CUCM cluster - I noted a CUC which is Cisco Unity Connection cluster (acronym is CUC).  In a cluster with CUC, you have 1 Pub and 1 Sub - they are active-active and you can set up backup jobs separately.
CUCM is not part of this equation.
Hailey
kalebaks86 Wed, 05/26/2010 - 07:47
this would be where my confusion lies (i knew there was something i just wasn't grasping). thanks for clearing this up. I'll take a look at it with that in mind. another question, are all unity connect servers setup with 1pub and 1 sub or do they sometimes come as just on server (i beleive in my case the latter is situation as i'm not aware of any other servers bar this one i'm webbing to.
Thanks!
David Hailey Wed, 05/26/2010 - 08:11
CUC does not have to be setup in a cluster configuration.  It can be a single, standalone server.  In that case, you may need to try the second method of having one backup job to backup everything BUT messages and then a second to backup messages only.
Additionally, CUCM and CUC can come in co-resident installation.  When they do this is called CUCM BE or Business Edition.  It's a single server, MCS 7828, that has CUCM and CUC installed on the same server and can support up to 500 users for IP telephony and voicemail services.
Hailey
kalebaks86 Wed, 05/26/2010 - 08:39
in this instance i believe there is just the one server.
so i've tried to run seperate manual backups. when choosing messagestore on it's own even this fails! did you mean to set them up as scheduled or would manual backups pretty much be the same thing?
i've also had a cisco TAC case open and all they recommend is trying different SFTP servers, they;ve currently got me trying titan (free trial) but i feel this is going up the wrong path. i've already tried 3 different ones.
Correct Answer
David Hailey Wed, 05/26/2010 - 08:47
kalebaks86 Wed, 05/26/2010 - 09:22
i pressed the correct answer accidentally on your last post.
but to continue - yes it does get stuck on 40% however when watching the file being transfered on the C:\ the file keeps increasing in size but will then just cut off.
David Hailey Wed, 05/26/2010 - 09:30
So, looking back at the whole thread - I see that you said you looked thru the CoreFTP info.  Personally, I've never had that issue with backups (file size limitations and such) because I use a known, proven application.  Anyway, I failed to ask you what SFTP server you are using for backups?  In addition, Rob was right when he said that even though that thread focuses on CUCM, it still applies to CUC because the two applications reside on the same exact platform.  The only difference is the app modules that get loaded when you choose to install CUC over CUCM and vice versa.  The platform components are, at heart, the same.
So, let's back up:
1) What SFTP client are you using?
2) Can you send me a screen shot from the system that shows the size of your mailstore?
Hailey
kalebaks86 Wed, 05/26/2010 - 09:44
I've used so far:
Freeftpd
Coreftp
winscp
titan (which i'm trying now)
i'll get you a screen shot in just a bit.
Thanks for your time on this hailey.
David Hailey Wed, 05/26/2010 - 09:51
Not a problem. I personally think there is a bug here but it has yet to be acknowledged.  I've seen this on a brand
new cluster and heard many compaints in NetPro as well.  You've been thru the gamut of servers.  Personally, I've used CopSSH for years without issue.  Technically, Titan is Cisco's recommended application but it's not free - not if you want to get functionality out of it.  I didn't like it, personally but we have a client who uses it for very large CDR file offloads to a billing server and they've been good with it.
Send me that screen shot and we'll go from there.  I can't promise we'll get this working on a single box - I could almost guarantee it within a cluster, but I'll try to figure something out with you on it.
Hailey
kalebaks86 Wed, 05/26/2010 - 10:17
it worked! Titan worked!
David, i really appreciate all the help and your willingness to spend more time on this. I'm also going to give copssh a try to see if that, as a free alternative, will also work.
just a note to anyone else that has this issue, if the backup stays at 40% or any percentage it doesn't mean it's not backing up, the only way to be certain is to watch the file as it's being incremented in the SFTP directory. Through the whole backup the CUC web page still said 40%, right until it finished.
thanks again for the help.
David Hailey Wed, 05/26/2010 - 10:19
Excellent.  Glad you got it rolling.  +5 to you for your resolution update.
Hailey
mlpalmer Wed, 06/16/2010 - 07:15
We have the same problem exactly.  Titan works, but inconsistantly. I agree that there is a lack of urgency on Cisco's part to get this fixed.
David Hailey Wed, 05/26/2010 - 10:20
+5 to Rob for always being Quick Draw McGraw.
kalebaks86 Thu, 05/27/2010 - 03:14
Dave, following on from your SFTP recommendations - i tried to use COPSSH as a free alternative to Titan but found it's nothing like the other apps in the sense that it has no GUI, it's all CLI based and seems to be a port over from linux (which i'm not very familiar with in terms of usage). Do you know of any good simple tutorials that would explain how to utilise this as an SFTP server? or perhaps a quick guide of your own if you have the time.
perhaps i should create a new thread for this instead (?)
David Hailey Thu, 05/27/2010 - 06:46
Sure.  copSSH is essentially OpenSSH for Windows which is a Linux implementation (Cygwin) of SSH server for
Windows.  It is not GUI-based like many of the other clients; however, I never really cared about a GUI so you may not
like this.  But, to get started - after you've installed copSSH and launch it from the Programs menu there is a little menu that it gives to walk thru.  The most important and required step is to enable users for the program.  So, they need to be standard user accounts on your server/PC.  For clients, I typically set up something generic for them like "sftpuser" with a strong password and then tie that to copSSH.  The user is then set up with a home folder in the installation path.
Ex:  c:\Program Files\CopSSH\home\sftpuser
So, within that user's home folder you can create different folders to 1) pull files from (e.g., for upgrade) or 2) write files to (e.g., for backup).
Ex:  ...\home\sftpuser\upgrades --> upgrade files for could be stored here
Ex:  ...\home\sftpuser\backups\cuc\publisher --> you may have specific backup paths and then say a Publisher repository and a separate Subscriber repository
From within the CUCM apps, you will specify the IP address of the copSSH server (in your case, your PC).  The user name and password would be "sftpuser" and it's local password on your machine.  Then the path you specify would depend on what you are doing.  For example, if you want to set up DRS for the CUC Publisher then you would set the destination as "/home/sftpuser/backups/cuc/publisher/" (using my example above).
You can test that the server is working as expected by downloading an SFTP client (I used Putty's PSFTP).  From the client, you'd type "open " where would be the copSSH server (again, your PC in this case).  From there, you can use standard Linux commands like "pwd" (present working directory) to see where you're at, "lcd" (change directory), "file get ", and so on.  This stuff is easy to figure out by using the help within the client you decide upon.  With the UC applications, the client is the application you're using such as CUCM DRS, CUC DRS, the upgrade client, etc.
Hope this helps.
Hailey
kalebaks86 Thu, 05/27/2010 - 07:18
hailey,
thanks for your concise reply again. I'm going to give this a whirl and will report back to you on how it goes.
thanks yet again +5
kalebaks86 Fri, 05/28/2010 - 04:11
Just an update - copssh works just fine, thanks for the recommendation. It's amazing how simple copssh is to use once you've done it once. scrapping titan for this simple free alternative
Thanks for all your help on this hailey.
David Hailey Fri, 05/28/2010 - 05:04
Awesome, glad you like it.  I think it's the best choice out there but there are plenty of people who prefer others.  But, setup is simple, it runs as a service so you can always know its up, and it's easy to use once you poke around a bit.
Glad you got it worked out, my friend.
Hailey
Rob Huffman Wed, 05/26/2010 - 07:02
  • Hall of Fame,
    Founding Member
Hailey-Man,
Thanks for filling in the blanks! +5 points for your
excellent work here (as always!)
Cheers!
Huff
