howto setup wpa2+aes+psk with mac-filter (radius) on WLC 4402
Answered Question
May 26th, 2010
HI
   I am try to setting wpa2+aes+psk with mac-filter (radius) on WLC 4402 (6.0.182),  with Lap - 1142
   on security , set L2 security wpa+wpa2 and check MAC filtering
   uncheck WPA
   check WPA2, AES, unckeck TKIP
  Auth key mgmt PSK
   psk fromat ASCII
  L3   none
  uncheck web policy
AAA servers
  select radius server enable accounting server
   It's work fine , when I using WEP with mac-filter(radius)
  but when I select WPA2  it's fail and  no log  both on WLC and radius server
Is this limitation or bug....
Thanks in advance for your help
Correct Answer by John Cook about 6 years 9 months ago
That sounds like it should work.  Maybe your client doesnt like wpa2/aes or the PSK doesnt match.  I'd try to associate with that same config, but without the mac filtering enabled to try to narrow down the problem.
-John
Overall Rating: 5 (1 ratings)
Correct Answer
John Cook Wed, 05/26/2010 - 05:19
-John
Trending Topics - Security & Network
