Support Team Wed, 05/26/2010 - 05:59
You can download regular version ACS_v5.1.0.44.iso from CCO and request trial 90 day key from Cisco site.
Jatin Katyal Wed, 05/26/2010 - 08:29
Its working fine for me.Try in different browser....
You may also go to  Security  > Cisco Secure Access Control System 5.1  > Secure Access Control System Software > ACS 5.1
JK
Do rate helpful posts-
surcisco123 Wed, 05/26/2010 - 12:13
Hello Friends,
ACS_v5.1.0.44.iso
Release  Date: 11/Nov/2009
ACS  5.1.0.44 FCS Official version
Is this for windows OS ??? After opening a ISO file by winrar,do we will find a .exe file in that??????
Support Team Wed, 05/26/2010 - 23:38
ACS 5.1 work on appliance or in VMware. OS - Cisco hardened Linux. I you want to try, you can use VMware.
surcisco123 Thu, 05/27/2010 - 09:01
From ur below mail what i understand is In VMware i have to specify the path for the downloaded iso file to install it,Because all appliance ACS are preloaded with OS????????? Correct me if i m wrong.???
From where i can get the evaluation licence any link on cisco site?????
Jatin Katyal Thu, 05/27/2010 - 09:17
http://www.ciscosystems.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_vmware.html
Step 1 Go to the following link:
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
Step 2 Click the link available in the Licenses Not Requiring a PAK section.
You should have a valid Cisco.com login credentials to access this link.
Regds,
JK
cpradoscarvajal Wed, 02/01/2012 - 05:16
I tried to download the trial version but Cisco gives me the following message:
Cisco service contract information indicates you are not authorized to download software for the following product(s):
  • Cisco Secure Access Control System 5.1
To download software for other product(s), remove the software for the product(s) listed above.
camejia Wed, 02/01/2012 - 14:32
Go to Cisco.com > Products > Security > Identity Management > Cisco Secure Access Control System > Cisco Secure Access Control System 5.1 > Secure Access Control System Software-5.1.0.44 > Download "ACS_v5.1.0.44.iso"
You need to install the .iso file as described on the attached .pdf document.
After properly installing the ACS 5.1 as described on the .pdf you can generate an Evaluation License as described on the other .pdf document.
Hope this helps.
Regards.
Vinay Sharma Sat, 05/16/2015 - 05:17
Thank you Camejia for providing the information related to Eval ACS License 5+ :-).
As tools have changed, i have updated information and posted in a Document.
Vinay Sharma
Community manager
