Integrating Cisco CallManager 7.0 and CME using sip trunk
May 26th, 2010
I just installed CUCM 7.1.3 in my test lab and also have got CCME 7 on cisco 2811(IOS version 12.4(24(T)).
On CUCM 7 I have got range of number 6000-7000
registered phone 6000
ON CCME I have got 2000-3000
registered phone 2000
normaly in order to call to another ccme from ccme I used:
dial-peer voice 101 voip
description ##  ##
destination-pattern 5...
codec g711alaw
session protocol sipv2
session target ipv4:
dtmf-relay rtp-nte
but If I do the same with the CUCM I am getting a message unknown number(after calling 6000).
I also set up set trunk from CUCM to ccme and added route pattern for extention 2000 it should go to ccme,
but when I am getting bussy signal.
I have been checking this link __ and dont think it should be much different from above.
Can you help me with setting it up and get it working please?
Many thanks.
Vasily_Kr Fri, 05/28/2010 - 04:34
Problem was resolved.
I did use wrong session target ip address.
