The phone keep ringing eventhough the caller hangs up
Answered Question
May 26th, 2010
I have 3825 CME with CUE, when a caller call and the autoattended played and route to whatever extension he want, and the caller hang-up before answering the phone keep ringing with no end.
I tried to configure the FXO to one of extension directly without autoattendant it worked fine “disconnect directly”.
I have attach you “show run” and “debug vpm signal”
Correct Answer by hiepnguyenho about 6 years 6 months ago
If you need the detail screenshot for each steps, you can check this link:
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
Hope this help
Overall Rating: 3.7 (3 ratings)
hiepnguyenho Wed, 05/26/2010 - 21:23
Try these configuration for disconnect:
voice-port 0/2/0
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
It works on most of my configured FXO voicegateway.
hiepnguyenho Sun, 05/30/2010 - 18:45
If your configuration is exactly like this:
voice-port 0/2/0
cptone BR
timeouts ringing 5
May be your frequency and cadence is wrong. Please make a custom tone and re-apply it to your voice-port.
For example:
*** please note that the parameters are for Vietnamese telco only ***
voice class custom-cptone vn
dualtone disconnect
  frequency 425 425
  cadence 500 500 continuous
voice-port 0/2/0
supervisory custom-cptone vn
no battery-reversal
timeouts call-disconnect 0
timeouts ringing 5
hiepnguyenho Wed, 06/02/2010 - 08:29
Note that the frequency and cadence I posted are just example. You need to find exactly what your parameters are.
Method 1: Ask your telco
Method 2: Get it yourself by capture the tone and analyze by some tools like CoolEdit Pro... If you need to do it, please contact me for the steps.
kingofshadows86 Tue, 07/13/2010 - 22:53
Sorry for late I was in vacation, now could you please help for the step to get the frequency and cadence.
And one more thing is this frequency and cadence effect on caller-id.
Appreciate your help.
