Need help in CUCM LDAP Auth
Answered Question
May 26th, 2010
Correct Answer by David Hailey about 7 years 3 days ago
Well, that was my next suggestion - sounds like you got that figured out.  SamAccountName it is, right?
Hailey
Correct Answer by Jonathan Schulenberg about 7 years 3 days ago
Have you delegated authority for that account to Read All Attributes on the user objects of the search base OU (and children)? The UPN attribute may not be accessible to the average LDAP query.
Overall Rating: 5 (3 ratings)
Jonathan Schulenberg Wed, 05/26/2010 - 08:17
  • Cisco Designated VIP,
    2017 IP Telephony
The UPN is not the same as the Distinguished Name (DN) in LDAP. UPN is an individual attribute on an LDAP object while DN is a fully-qualified object path within LDAP.
An example: CN=Example User,OU=Service Accounts,OU=People,DC=domain,DC=com.
In Active Directory the CN field is typically the Display Name field as shown in ADUC.
David Hailey Wed, 05/26/2010 - 08:19
  • Purple, 4500 points or more
Have you tried to put the name in the format of DOMAIN\User for the authentication piece?
Hailey
Please rate helpful posts!
markcarat Wed, 05/26/2010 - 08:32
Hi David
If i use Domain\user, I got  this error
Error while Connecting to ldap://10.10.10.15:3268/netlab\sys.netlab, javax.naming.InvalidNameException: netlab\sys.netlab: [LDAP: error code 34 - 0000208F: LdapErr: DSID-0C090654, comment: Error processing name, data 0, vece]; remaining name \'netlab\sys.netlab\'
if I use the suggestion from Jonathan,
I got this error
Login Failure to Host ldap://10.10.10.15:3268, Please Re-Enter LDAP Manager Distinguished Name and Password
Even though the password is correct.
Mark
Jonathan Schulenberg Wed, 05/26/2010 - 08:35
    2017 IP Telephony
Is this a global catalog DC? If not your port should be 389, not 3268.
markcarat Wed, 05/26/2010 - 08:39
Hi Jonthan,
It is a Global Catalog.  I tried using port 389 as well.  Same error.
Mark
markcarat Wed, 05/26/2010 - 08:42
Just to add to my last post.  If I use sAMAccountName not userPrincipalName in LDAP System Configuration.  The same user "sys.netlab" would work in LDAP Auth.
Mark
Correct Answer
Jonathan Schulenberg Wed, 05/26/2010 - 08:48
    2017 IP Telephony
Correct Answer
David Hailey Wed, 05/26/2010 - 08:48
Hailey
markcarat Wed, 05/26/2010 - 09:14
Hi Jonathan, Hi David
Thank you for your nice suggestions.  It is working now.
I use this in the LDAP Manager Distinguished Name in LDAP Auth
cn=sys netlab,ou=US,dc=netlab,dc=loc
It works with either port # 389 or 3268.
I swear to god I tried this but I must have brain fart..:-)
Again I appreciated all your help.
Mark
