UCCX 7.0(1) Jtapi resync
Answered Question
May 26th, 2010
  • Silver, 250 points or more
I'm getting a prompt when I try to resync the jatpi in UCCX 7.0(1).
When I click on  Subsystems -> Cisco Unified CM Telephone -> Cisco JTAPI Resync I get the following prompt :
"Please disable the Cisco Security Agent on the server Running the Cisco Unified CCX software (all servers in case of a high availablility setup) before you proceed with the Cisco JTAPI Resnc"
I can't this service anywhere in control centre, or in the list of processes in the serviceablitly tool. Where do I disable this?
Brian
Correct Answer by Kevin Przybylowski about 6 years 10 months ago
Yes - it's just a warning like Peter said.
If you don't see the "Cisco Security Agent" service in Administrative Tools > Service, then it's a safe bet whoever configured it didn't install it.
Correct Answer by Peter Gale about 6 years 10 months ago
Hi Guys
The "Please disable CSA..." message is a 'warning' only, it does NOT check the UCCX or IPIVR box, just click OK if you are SURE that CSA is either disabled or not running !
cheers
Peter
Peter  Gale
CCSI# 22524
Systems Instructor, AsiaPac Training
Housley Computer  Communications Pty Limited
Level 13, 132 Arthur Street
NORTH SYDNEY   NSW   2060
AUSTRALIA
Tel:  + 61 2 9954  4055
Mob: +61 (0) 413 44 99 70
http://www.housley.com.au
ABN  60 001 422 724
Overall Rating: 5 (3 ratings)
Phuong Hoai Huynh Wed, 05/26/2010 - 08:48
  • Bronze, 100 points or more
Hi Brian
What you want to do is look on the bottom right of your windows tool bar for a waving red flag.
Or go into the windows service and stop the Cisco Security Agent which will prompt you for a code to shut down.
Perform the Jtapi resync should go through smoothly once you do that.
brian1mcc Wed, 05/26/2010 - 08:54
Strange, I'm not seeing the red flag, or the Cisco Security Agent in the list of services. Is this installed by default in UCCX 7?
Phuong Hoai Huynh Wed, 05/26/2010 - 09:10
CSA is not installed by default onto the UCCX systems.
However that does sound unusual that your getting this prompt if you don't have the software at all.
Can you have a look under your add remove programs if there is a Cisco Security Agent there or in your msconfig
brian1mcc Wed, 05/26/2010 - 09:15
Thanks for your replies ...
I am not seeing CSA in add / remove programs or in msconfig.
Correct Answer
Peter Gale Wed, 05/26/2010 - 17:00
Hi Guys
cheers
Peter
Peter  Gale
CCSI# 22524
AUSTRALIA
ABN  60 001 422 724
Correct Answer
Kevin Przybylowski Wed, 05/26/2010 - 17:39
brian1mcc Thu, 05/27/2010 - 01:01
Thanks everyone for the replies .. resync worked perfectly.
Brian
antonio.fragoso Thu, 09/16/2010 - 05:56
Hi Bryan
Maby You can help me to sync the Jtapi
I am having the foolowing messag:
Cisco JTAPI Client
An error has occurred while trying to resynchronize the Cisco JTAPI Client. Please try Cisco JTAPI Resync in CRS Administration again.
brian1mcc Thu, 09/16/2010 - 06:45
Have you tried doing a data resync? If there are any errors post them here.
Brian
antonio.fragoso Thu, 09/16/2010 - 08:43
I receive the following
Unified CM Telephony Users
jtapi_1 -- Ok
Unified CM Telephony Port Groups
No Port Groups found
Unified CM Telephony Triggers
No Triggers found
Pablo Leiva Thu, 09/16/2010 - 09:36
Hello Antonio,
Could you let us know the exact UCCX version, 7.0(1) including any SR or ES?
Also please navigate in CUCM to the Cisco Unified Reporting (drop-down menu where you select CM Administration, serviceability, OS, etc). Please select the Unified CM Cluster Overview report.
- Please go into Unified CM Version and View Details. Please look for the CUCM Version on all servers
- Please go for the Unified CM Component Version and View Details. Please look for the cm-jtapi-plugin version for all the servers
Pablo
antonio.fragoso Thu, 09/16/2010 - 11:46
Hi Pablo
UCCX Cisco Application Administration - 5.0(2)_Build064
CUCM System version: 6.0.1.3000-7
  - I have only  CM Administration, serviceability, OS and Desater Recovery Sytem
Pablo Leiva Thu, 09/16/2010 - 12:35
Hello Antonio,
As per the compatibilty matrix, CUCM 6.0.1.3000-7 is not explicitely supported for 5.0(2):
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_device_support_tables_list.html
If upgrades are possible, I think you can try running compatible software.
Before that, by any chance you have McAfee VirusScan installed on this CRS? If it's installed, make sure that On-Access Scan is enabled while trying the JTAPI ReSync. If there's another AV software, make sure it's listed in the comp matrix.
Please open cmd and type CET.
- Look for the ClusterDependentConfig; double click on the first entry of the right side. From the second tab, please let me know the value of JTAPI Version.
We can try to manually download and install the JTAPI plug-in from CUCM.
1) Login into CUCM
2) Navigate to Application -> Plugins
3) Search for the plug-in that contains jtapi, download Cisco JTAPI for Windows
4) Install the plugin on the CRS server (Restart of CRS engine or CRS node manager is required).
Please check the version on CET again afterwards.
Hope that helps!
Pablo
antonio.fragoso Thu, 09/16/2010 - 19:06
HI Pablo
I follow you advice but it still apear like that:
"ClusterDependentConfig[schema=ClusterDependentConfig,time=Fri Sep 17 00:50:02 GMT-01:00 2010,recordId=492980589,desc=,node id=1,db version=8.00.2156,db edition=MSDE,crs service release=,crs release=5.0(2)_Build064,crs engineering special release=,icd language=Portuguese,jtapi client version=unknown,hd size=2048,rd size=2048]"
Pablo Leiva Fri, 09/17/2010 - 06:46
Hello Antonio,
If the manual JTAPI installation works without an error it might be that the registry entry is not being updated, although the JTAPI has been updated succesfully.
If you are running CUCM version 6.0.1.3000-7 = 6.0(1b), then the Cisco Unified Communications Manager JTAPI version is 6.0(1.1000)-5.
Please enter this value like that "6.0(1.1000)-5" (without the quotes) in CET> ClusterDependentConfig> JTAPI Version and try the JTAPI re-sync again.
Pablo
Pablo Leiva Fri, 09/17/2010 - 09:47
Antonio, another thing... did you installed this UCCX over a regular Windows 2003 server or using Cisco-provided OS? check if you have a C:\WINDOWS or a C:\WINNT ?
Pablo Leiva Mon, 09/20/2010 - 05:11
yeap, that should do it.
The Cisco-provided disc creates different folders than the standard Windows 2003 SW disc., like the WINNT folder.The system looking to
verify configuration data under the Java folder and cannot find it.
bvanbenschoten Sat, 08/24/2013 - 18:54
This worked for me.  I built a lab UCCX 7 system to test migration for a customer.  I didn't use the Cisco provided OS image.  Just a standard windows image.
Thanks for the tip.
Related Content
