4710 in one-armed mode
Answered Question
May 26th, 2010
is it possible to preserve the clients originating IP address somewhere while using the 4710 in one armed mode?  I have a situation where the client source ip is needed, and I am deciding between one-armed mode and inline.  I'd like to use one-armed, so that only load balanced traffic traverses the load balancer, but I haven't seen an example where that can be done without  loosing the clients src address.
Correct Answer by UHansen1976 about 7 years 1 day ago
Only thing I can think of is http header-insertion. Create an action-list, that inserts the original client src.ip/port into the http-header. The configuration is quite simple:
action-list type modify http name
  header insert both Host header-value %is:%ps
Then apply the action-list to your loadbalance policy-map.
Take a look at the url below for futher information:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1131842
But that depends on your situation. If is the original client src.ip/port is expected in the L3/L4 header, this won't cut it. Is this for logging purposes or some form of packet filtering ?
If you intend to run your ACE in one-arm mode, in my opponion, src.nat and header-insertion is your only option.
hth
/Ulrich
Overall Rating: 5 (1 ratings)
Correct Answer
UHansen1976 Wed, 05/26/2010 - 17:21
  • Bronze, 100 points or more
hth
/Ulrich
jbeltrame Wed, 05/26/2010 - 17:46
Thanks!!! That looks very promising.  The Original SRC IP will just be used for some statisical based information, the I don't need the original SRC ip in the L3 headers.  Thanks so much!!
Marwan ALshawi Sun, 05/30/2010 - 01:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
if u don't nat the
client source address you will preserve the source address but using this way with one arm topology u need to make sure u have a PBR in the interface/SVI facing the server ( server default gateway) to enforce the returning traffic of HTTP to go back to the ACE
