Routing calls based upon ANI in H323
May 26th, 2010
I need to re-route calls into my H323 gateway based upon
the ANI.  Can this be done?  I know you can block the calls but not sure if I can re-route them to a different extension.
Rick Arps Thu, 05/27/2010 - 06:00
You can route calls on the incoming dial peer by matching using the 'answer-address'.  This will match the ani of the caller.  You can then use translation rules to change the called number within that dial peer.
Hope this helps
Rick
EDWARD GAWENDA Thu, 05/27/2010 - 08:25
I cant seem to get it to work, no matter what phone I call from it matches the dial-peer and tran
slates.  Doesnt seem to look at the ANI at all when callign from 2 different phnoes with different ANI's.  Assume 6666 is the main number but I want any call from 1000 to go to 7717 and not 6666 and any other call to ring 6666.
  Here is the config:
voice translation-rule 1
rule 1 /6666/ /7717/
voice translation-profile XfertoFax
translate called 1
dial-peer voice 12345 voip
translation-profile outgoing XfertoFax
answer-address 1000
destination-pattern 6666
session target ipv4:10.200.10.10
codec g711ulaw
Rick Arps Thu, 05/27/2010 - 09:20
It's not a match all, it's a match any.  If you have:
answer-address 1000
codec g711ulaw
It's going to match on the called number 6666 or the calling number 1000.
The matching order is:
1 - match incoming called number
2 - match answer address
3 - match destination pattern
Once you match a dial peer with one of these, it will route.  So you would need one dial-peer for each of your different answer addresses.
Also, this needs to be on the Incoming dial peer, I'm assuming this is coming from a pots line, so it would need to be on the pots dial-peer.
Hope this helps
Rick
EDWARD GAWENDA Thu, 05/27/2010 - 09:53
This is a test gateway where I am calling in/out to IP Phones.  If I dial from my 2 phones, I match the appropriate incoming dial-peer but it seems to randomly choose one or the other dial-peer for outbound and translation and the translated number rings.  Not sure how I can force the dest-pattern for outgoing.
XfertoFax should be:  Dial 6666 --> 7617 if dialed from Ext.1000
Forward should be:  Dial 6666 --> 2000 if dialed from Ext 7263
Latest Config:
answer-address 1000
codec g711ulaw
dial-peer voice 54321 voip
translation-profile outgoing Forward
answer-address 7263
codec g711ulaw
Thanks for your input.
Rick Arps Thu, 05/27/2010 - 10:03
It sounds like it's matching on the destination-pattern which is the same on both.  Since you don't have a preference set, it's going to round robin between the two.
Note, you need to match on the answer-address on the incoming dial-peer.  Having it on the outgoing dial-peer won't do anything.  So match by the answer address and translate your called number both on the incoming dial-peer, then have two separate outgoing dial-peers to send the resulting pattern to your device.
Hope this helps
Rick
Md. Mijanur Rahman Fri, 05/28/2010 - 05:37
I was reading this wonderful discussion with the idea 'routing against calling#', let me have an input here. Think of two call-legs, one is incoming which will match your calling# and will change your called# by translation-rule, second is the outgoing dial-peer with the converted called#. So your configuration might look like below:
incoming call-leg
dial-peer voice 1 voip
incoming called-number .
answer-address 1111 !!! in case 1111 is the ANI
translation-profile incoming Xslate-Called-1
rule 1 // /2222/
voice translation-profile Xslate-Called-1
translate called 1
outgoing call-leg (minimum configuration)
dial-peer voice 2 voip
destinationation-pattern 2222
session target ipv4: x.x.x.x
But you have to create multiple dial-peers for individual calling# pattern.
