ACE 20 modules in 6509
May 26th, 2010
Hi Experts,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I am going to use ACE 20 service modules for load balancing. To be honest I don't know them ( Kind of design question)I am not getting in my head that where should I install these modules and who should be the gateway for the load balanced servers. And how technically it load balances in VSS enviroment.
Need help. & Please share link or document where I can find design and implementation guide.
Your help will be highly appreciated.
Thanks & Regards
Mudasir Abbas
Overall Rating: 3.5 (2 ratings)
Jon Marshall Wed, 05/26/2010 - 14:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mudasirabbas wrote:
Hi Experts,
Thanks & Regards
Mudasir Abbas
Mudasir
Start with this design document which covers the use of service modules in the data centre and the different options you have in their deployment -
Network services srnd
Jon
Mudasir Abbas Sun, 05/30/2010 - 07:29
Hello!!!
Does anyone have configuration example for ACE 20 on 6509 ?
Reza Sharifi Sun, 05/30/2010 - 09:21
    2017 LAN
HI Mudasir,
This is strictly my personnel opinion.  I would not use ACE in a VSS environment.  ACE is not easy to work with and not very easy to configure and in my opinion not a very solid product.  In addition, there are not that many Cisco SEs who know ACE really well  So adding ACE to VSS will create additional complexity you don't need. One other thing, I have not seen a whole a lot documentation/examples referencing ACE in VSS.
Reza
Related Content
