RTR tracking without IP SLA feature
Answered Question
May 26th, 2010
We are using the following image on our production  layer-3 switch
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF11, RELEASE  SOFTWARE (fc1)
There is no support for IP SLA in the current  version. But it seems there is no support for "track 2 rtr 10 reachability" and "ip route x y z track 1"  type of commands either. While the following commands are accepted
# rtr 10
          # type echo protocol ipIcmpEcho  10.10.10.10
          # frequency 2
          # request-data-size 32
          # timeout 1000
# rtr schedule 10 life forever start-time now
How to make the following work on the current IOS.  Is there an alternative to achieve the same or is IOS upgrade a must???
# track 2 rtr 10 reachability
# track 1 list boolean and
          # object 2 not
ip route 11.11.11.0 255.255.255.0 12.12.12.12 track  1
P.S. The objective is to install a static route for  network 11.11.11.0/24 towards  12.12.12.12 when the device at 10.10.10.10 (not directly connected) is NOT reachable. This will be backup route for the remote 10 network. We don't have dynamic routing or vpn in between. Any ideas??
Thanks.
Correct Answer by Calin Chiorean about 7 years 1 month ago
Hi there!
I don't know if this is working 100% (and that your image support EEM) but look below.
I understand that you can type this:
# rtr 10
          # frequency 2
          # timeout 1000
          # threshold 100
EEM is used and you have a timeout occurence (10.10.10.10 is not reachable anymore):
event manager applet RTR_10_TIMEOUT
event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.10 get-type exact entry-op eq entry-val 1 exit-op eq exit-val 2 poll-interval 5
action 1.0 syslog msg "10.10.10.10 not reachable"
action 1.1 cli command "enable"
action 1.2 cli command "configure terminal"
action 1.3 cli command "ip route 11.11.11.0 255.255.255.0 12.12.12.12"
Explanation for OID value can be found here:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=rttMonCtrlOperTimeoutOccurred
The last .10 in the OID value is your RTR (or IP SLA) number.
Of course the problem is that route remains there even if 10.10.10.10 is reachable again. To remove it you need another EEM.
This example can be "fine tuned" to match your expectation.
Let me know if this helps you.
Overall Rating: 5 (3 ratings)
Correct Answer
Calin Chiorean Thu, 05/27/2010 - 01:30
  • Silver, 250 points or more
Hi there!
# rtr 10
          # frequency 2
          # timeout 1000
          # threshold 100
Calin Chiorean Thu, 05/27/2010 - 01:36
I think this will not work for you as according to the software advisory in Cisco EEM is supported from IOS versions SXI and SXH above. Anyway...try.
seabird505 Thu, 05/27/2010 - 23:39
Yes EEM is supported. Thanks so much for guidling me towards implementing it via EEM and generously providing me with the script for it.
For the reference of others who may need to acheive the same without IP SLA, the config is like this
rtr 10
  timeout 1000
  frequency 3
event manager applet EEM_PRIMARY_DOWN
  event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.10 get-type exact entry-op eq entry-val 1 exit-op eq exit-val 2 poll-interval 3
  action 1.0 syslog msg "Primary link DOWN - Failing over to backup link"
event manager applet EEM_PRIMARY_UP
  event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.10 get-type exact entry-op eq entry-val 2 exit-op eq exit-val 1 poll-interval 3
  action 1.0 syslog msg "Primary link UP - Failing over to primary link"
  action 1.3 cli command "no ip route 11.11.11.0 255.255.255.0 12.12.12.12"
Thanks again Calin !
Andreas Wittemann Fri, 06/30/2017 - 01:39
I am aware the problem is AAAAAGES SOLVED already, but just in case someone comes by and sees this...you can have this probably way easier, i do it like that for quite a while, always does the trick (in MY case)...and the first section is the same, so i refer to THIS particular example here:
rtr 10
  timeout 1000
  frequency 3
track 1 rtr 10
ip route 11.11.11.0 255.255.255.0 10.10.10.10 track 1
### HERE I AM REFERRING TO THE REACHABILITY OF MY TRACKING OBJECT ###
ip route 11.11.11.0 255.255.255.0 12.12.12.12 10
### WILL NOT BE USED USUALLY BECAUSE BAD METRIC, JUST WHEN TRACKING PUTS OTHER ROUTE DOWN ###
Hope this helps someone...keeping it easier ;)
